Author Topic: Linux trouble  (Read 1509 times)
TalkingOctopus
    • My Arcade
Linux trouble
« on: January 16, 2005, 03:12:34 am »
I finally upgraded from Redhat 7 to Fedora core 3.
lucindrea
  • Last login:July 28, 2005, 10:06:19 am
  • I dont think I'm a llama!
Re: Linux trouble
« Reply #1 on: January 16, 2005, 12:56:52 pm »
try booting linux single from grub , that should get you to the command line and not X , from their you can change your default run mode to 3 insted of the 5 it's in now ... then when you want to run X just do a startx from the command line , if that locks up on you you should still be able to do a ctrl-alt-f1 , or f2 , f3 etc and get to command.
TalkingOctopus
    • My Arcade
Re: Linux trouble
« Reply #2 on: January 16, 2005, 04:52:10 pm »
The problem is that when I go to the commandline, nothing is sent to my monitor.  There must be some kind of problem between my videocard and whatever vga mode it is using.  Nothing is locking up.  It just that nothing is displayed on the monitor.
TalkingOctopus
    • My Arcade
Re: Linux trouble
« Reply #3 on: January 16, 2005, 06:49:50 pm »
Well it turns out I can boot to x from grub by editing the load commmand.  I added linux 5 to get back into x.  However, linux 3 still does not work.  Nothing is displayed :(.
lucindrea
Re: Linux trouble
« Reply #4 on: January 17, 2005, 09:58:13 am »
ah ok ... hmm , their are vga stuff you can put on the kernel line in grub for the command prompt .. just dont know them off hand and i'm at work ATM , if i work it out i'll post
TalkingOctopus
    • My Arcade
Re: Linux trouble
« Reply #5 on: January 17, 2005, 01:15:59 pm »
I figured out what I needed to.  Thanks for the help.  I can only boot into X, but once in X, I can run sbin/init 3 and it takes me to the prompt - a visible prompt!
lucindrea
Re: Linux trouble
« Reply #6 on: January 17, 2005, 05:27:46 pm »
from the grub FAQ  ( i know you fixed your problem , but i'm posting this anyway  :P  )
root (hd0,1)
kernel /vmlinuz-2.4.16 root=/dev/hda2 hdd=ide-scsi vga=791
# VESA framebuffer console @ 1024x768x64k
vga = 791
# Normal VGA console
# vga = normal
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# VESA framebuffer console @ 1024x768x256
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
darklegion
  • Last login:February 11, 2005, 11:27:02 pm
Re: Linux trouble
« Reply #7 on: February 11, 2005, 12:05:05 am »
There are issues with the framebuffer with late 2.6 kernels,so you may want to disable it completely which will probably reuiqre you to compile your own kernel.Also fedora is bugged at the best of times,so be prepared for these issues coming up often.The main reason for this is the kernels after 2.6.7 are pretty much like development series kernels i.e frequently bugged and with lots of new features that aren't stable yet new schedulers,reiser4,memory management tweaks etc. Hopefully these will all be ready by 2.6.11,as some of these tweaks bring some nice performance improvements.
