Author Topic: flexisign pro  (Read 2582 times)
darkmavis
  • Last login:April 25, 2006, 04:33:37 am
flexisign pro
« on: January 15, 2005, 03:41:37 pm »
anyone used this proggy? is designrd to print on vynl costs a fortune and can be found here..
http://www.beacongraphics.com
ive had a copy for ages and suddenly thought it may be good for making sideart and cps, what you reckon?
acejas
  • Last login:June 20, 2021, 06:15:55 pm
Re: flexisign pro
« Reply #1 on: January 20, 2005, 01:45:04 am »
These sign programs are good but Illustrator can be used with the right RIP software - Have I lost you?  Id stick with illustrator as it known by all in here. At the end of the day they both output EPS files so no real gain IMO.
Ive tried most sign programs and the only limitation ive found is that I can't go bigger than 5.7 metres (hmm roughly 18 feet)
HTH
Mario
  • Last login:March 29, 2021, 08:55:12 pm
  • Mmmmm.....arcades!
    • Mario's Arcade Page
Re: flexisign pro
« Reply #2 on: January 23, 2005, 10:49:24 pm »
My bro-in-law using Flexisign for his business. He uses it to cut vinyl, not print onto vinyl. He's got a vinyl cutter; looks like a large printer but has a cutting point which cuts through the vinyl. In fact, once he gets it going again, I'm going to ask him to cut the some Mame logos for me for sideart.
Mario
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
Re: flexisign pro
« Reply #3 on: February 12, 2005, 02:23:19 am »
Hello,
Flexisign is designed for signmakers.  It costs 2-3 thoushand dollars per seat and depending on the version offers vinyl cutting & printing capabilities.  I use it everyday in my sign business for both.  If you aren't outputting to your own printer you should probably use illustrator.  The biggest difference is you will see lots of functions that signmakers would use in flexi.  As another poster said since illustrator is less expensive and used by so many people in this forum you are more likely to find help when you run into problems.
