Author Topic: New MAMEWAH Config - looking for testers!  (Read 1948 times)
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« on: January 10, 2005, 05:42:49 pm »
Hey all! There's a new version of MAMEWAH Config out!
http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=19017&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1&new=1105339017
I'm looking for beta testers and am poised and ready for the onslaught of bugs! :)  If you have a few minutes and want to load (or already have) the latest version of MAMEWAH, please consider helping out!
-Steve
greywolf22
  • Last login:January 01, 2020, 12:45:06 am
  • My cab is always a work in progress
Re: New MAMEWAH Config - looking for testers!
« Reply #1 on: January 11, 2005, 05:33:25 pm »
Woo Hoo,
Thanks will give this a try as soon as I get the chance.  THANKS!!!
« Reply #2 on: January 11, 2005, 08:05:37 pm »
Yes get on it people, it is good :)
Also, last chance for your MAMEWAH bug reports - I'm *very* nearly done for a good while...  8)
Buddabing
« Reply #3 on: January 12, 2005, 09:46:30 am »
Please read the wiki!
« Reply #4 on: January 12, 2005, 10:42:13 am »
List generation sometimes puts "horizontal" where it should be "vertical". ASTROF is one example. The game is 240x240.
You can alter this with the correct_orientations setting (mamewah.ini)...set to:
'no' to leave as per MAME,
'horizontal' to list 1:1 games as Horizontal,
'vertical' to list 1:1 ratio games as Vertical.
Anything other than 'no' will also correct MAME's 'wrong' orientations.  I added this option to get maximum results (ie filtering) when using a monitor with fixed orientation.  I never really understood why MAME has 'wrong' orientations anyway - did some of the original games have the screen around the 'wrong' way compared to their resolution??
Buddabing
« Reply #5 on: January 12, 2005, 11:00:37 am »
« Reply #6 on: January 12, 2005, 11:37:39 am »
MAME's orientations are wrong for some games? I never noticed any games flipped on their sides or anything like that.
They don't have to be, but they can be incorrectly listed as horizontal/vertical (I don't know why).  See 'mame -wrongorientation' - I don't actually understand what this means exactly...I haven't been through the games to check.
Seems to me that orientation and resolution should be independent. Can't you have a 240x224 game that is vertical?
Well yes :)  But lets make an example: I use a horizontal screen, so lets l might want to display purely horizontal games, or more realistically games which will display well on a horizontal screen (as a rule games whose pixel width is greater than height) .  So based on your 240x224 vertical example above, this would be filtered out of my horizontal games list - BUT, it would display fine (arguable perhaps on how much of a purist you are) on a horizontal screen.  So, for this example this game would be best listed (for me) as horizontal, so it is not filtered out.
That alone is the reason I added this option - basically to maximise hits when filtering on orientation.  Granted I might be alone in my thinking here, but you can turn it off as I say :)
dagintm
  • Last login:October 14, 2007, 10:04:51 am
    • home page
« Reply #7 on: January 28, 2005, 10:19:33 pm »
I was checking out  MAMEWAH Config (great addition to a great front end  ;D) and ran accross the following error (see error.jpg) when selecting tools --> game list editor.
I'm running this on an XP sp2 machine that's barely configured, mame's not configured and I have no roms on this system.   I do have a dummy mame .ini that I was using.
Once I click continue I receive a blank application (see blank.jpg).  I then have click file --> quit or x out the application (bad short term memory  ;D) because I don't remember what I changed.
This issue is probably due to not having this system properly configured, but thought the error wasn't very graceful.  Wanted pass it on.
Thanks,
DaGintM
