Author Topic: X-Arcade with Generic USB Adapter  (Read 9209 times)
mrbones
  • Last login:September 19, 2024, 12:25:11 pm
    • ATVFlorida.com
« on: January 07, 2005, 02:09:47 pm »
I did a search, but couldn't find an answer. So here it goes.
I'm about to buy an X-Arcade dual joystick and want to know if you can use a generic PS/2 to USB adapter with it? I want to hook this thing up to a notebook with Windows XP that doesn't have a PS/2 port. I tested the generic adapter with a standard keyboard and it works with no problems.
I know you can buy a USB adapter from X-Arcade, but it's $30. I already have one of these generic ones.
Thanks folks!
Pacific Ripper
  • Last login:May 14, 2008, 12:14:30 pm
  • Tearing it up like a rag doll.
Re: X-Arcade with Generic USB Adapter
« Reply #1 on: January 07, 2005, 02:33:42 pm »
I bought their PCB and according to their manual, it says that it's not possible. I don't know whether that would be true or not because in theory, if it works like a keyboard, the adapter should work.
Tokey
  • Last login:June 14, 2007, 07:52:16 am
« Reply #2 on: January 07, 2005, 02:44:41 pm »
Yea they say it won't.... but who knows?  I'll try it tonight and let you know, okay?
Lilwolf
« Reply #3 on: January 07, 2005, 02:55:52 pm »
When testing it... check to see if you get any ghosting or max number of keys.
usb keyboard standard suck.  They specify only like 3 keys are pressed at a time.  So most/all usb keyboards only handle that.
Anyway... usb joysticks dont have the problems that usb keyboards have... and that is probably why they have two.
mrbones
    • ATVFlorida.com
« Reply #4 on: January 08, 2005, 11:13:02 am »
I bought an X-Arcade joystick on eBay this morning for $100. It was a mint used one. It will kill me to have this joystick and not to be able hook it up, so if anyone can help me out, I'd appreciate it. If someone knows for sure that the generic adapter won't work, I'll put my order in for the official USB adapter at x-arcade.com so they will both arrive at the same time. I think $30 for this adapter is overpriced, though. Thanks for your time.
mrbones
    • ATVFlorida.com
« Reply #5 on: January 13, 2005, 02:22:04 pm »
I got the stick today and tried it with a generic connector. It kinda works but isn't playable. The stick isn't recognized until I plug in a keyboard into it. Then, you only get single keystrokes. So, for example, if you want to run in Berserk, you have to tap the joystick like crazy in the direction you want to go. Not a fun way to play a game.
So, off I go to x-arcade.com to order the USB adapter.
Thanks for getting back to me, Tokey, lol.
Grasshopper
« Reply #6 on: January 13, 2005, 02:25:52 pm »
Why not spend a bit more and replace the X-Arcade's encoder with an Ipac?
Just a thought.
Tokey
« Reply #7 on: January 13, 2005, 02:46:28 pm »
meh, forgot all about this over the weekend.  Well I'm glad you figured it out anyways.
I like the x-arcade because I can just plug my xbox into it and it works perfectly.  X2VGA means xbox games in high res on my pc monitor in my cab.  That makes the xarcade worth way more than an ipac to me.
mrbones
    • ATVFlorida.com
« Reply #8 on: January 13, 2005, 02:57:11 pm »
No problem. I have a PS2 I'd like to use it with someday, too. So I like the adapter idea.
At least we know the USB adapter they sell is the real deal.
mrbones
    • ATVFlorida.com
« Reply #9 on: January 13, 2005, 03:35:12 pm »
Oh, and if the USB adapter is just a USB to serial adapter, it's actually not a bad deal. A Belkin brand one is $75.40 at Compusa! The next decent one is $40.
Pacific Ripper
« Reply #10 on: January 14, 2005, 01:14:59 am »
Just a thought.
Well, to me, the X-Arcade PCB was the best option to get my CP to work with my Dreamcast. I don't see any other encoder with that option and it works well in conjunction with Happ controls.
mrbones
    • ATVFlorida.com
« Reply #11 on: January 18, 2005, 02:43:39 pm »
I got the USB adapter yesterday from X-Arcade. Simply put, this thing is lame. There's a noticable lag on the inputs. Certain combos in fighting games (SF2, MK1,2,3) just can't be done. I hate it.
I'll be sending it back for a refund. I just can't believe that they can't make a USB interface without lag. Come on....
So, I either have to put an Ipac USB board in there, or give up and sell it.  >:(
I even searched for a PCMCIA PS/2 card that would interface with a notebook, but nothing like that exists.  >:( >:(
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #12 on: January 18, 2005, 02:52:32 pm »
Probably a long shot with the same lack luster results but would something like this work:
http://www.networktechinc.com/usb-ps2.html
mrbones
    • ATVFlorida.com
« Reply #13 on: January 18, 2005, 03:06:09 pm »
That's a pretty beefy adapter. But, my guess is it probably won't work. I think the reason is that the Windows USB-Keyboard interface just isn't fast enough for a game controller. It could just be a driver issue, but there's no substitute driver to use or experiment with. The x-arcade usb adapter uses a standard HID USB keyboard driver written in '01.
mrbones
    • ATVFlorida.com
« Reply #14 on: January 18, 2005, 03:18:24 pm »
I just called X-Arcade tech support. They are sending me another USB adapter to try. All they said was it has different electronics inside. I'll give an update when I try it out. I hope it works!
adonis_minus_20
  • Last login:April 10, 2020, 02:32:20 am
« Reply #15 on: January 19, 2005, 01:43:16 pm »
When I bought my USB adaptor from Xgaming they sent me this one:
http://www.xkeys.com/ymouse/whym08.php
It works really well and is $50, although I do remember that I had to enter some code or something initially in notepad to get it to work properly.
Jim
