Author Topic: cheap amplifier/subwoofer??  (Read 4688 times)
thrdbace
  • Last login:January 30, 2005, 07:21:02 pm
« on: January 05, 2005, 06:57:44 pm »
Hey helpful people,
ive got two 3" cube speakers...but no amp/subwoofer....
sooo, i need something to plug them into, then into the headphone jack on my cabinet's computer...
any ideas??
thrdbace
Re: cheap amplifier/subwoofer??
« Reply #1 on: January 06, 2005, 02:15:56 am »
seriously, no one has any ideas?
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« Reply #2 on: January 06, 2005, 12:04:40 pm »
I dunno.  I'm looking for a cheap, used boombox or stereo with inputs for my cab.
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #3 on: January 06, 2005, 02:53:33 pm »
Buy a pair of el cheapo computer speakers, bust them open, get the amp from inside those speakers and hook up your 3'' speakers to that amp. Hook the amp up to the computer and you are set.
thrdbace
« Reply #4 on: January 06, 2005, 05:48:32 pm »
how much electrical knowhow is involved in that?
probably just soldering my speakers to where the others were located on the pc speaker amp....right?
thrdbace
« Reply #5 on: January 06, 2005, 05:49:01 pm »
oh yeah, and do all pc speakers have an amplifier inside them?
Hiub1
« Reply #6 on: January 06, 2005, 07:29:08 pm »
Yeah all PC speakers should have one. You can go from the hard way of soldering new audio wire to the existing amp PCB or use the wires already there, solder them to some quick connects and attach them to the speakers.
thrdbace
« Reply #7 on: January 07, 2005, 12:09:11 pm »
this site is the BEST!
thanks for the suggestion - i bought a pair of pc speakers at walmart for $10....unscrewed the back, snipped the wires going to the speakers, twisted my wires around that with those plastic twisty connectors!
voila!  they work like a charm!
it was almost too easy.
thanks for the advice.
Lilwolf
« Reply #8 on: January 17, 2005, 01:40:03 pm »
The hard part is lining up the circuit board to allow for the volume control to be changed from outside your cab.
jcrouse
    • CPViewer
« Reply #9 on: February 09, 2005, 07:16:03 pm »
http://www.acscontrol.com/index_ACS.asp
Click on the PC Audio Amp link in the left hand column.
Then for volume control go to:
www.valcoelectronics and look at these two part numbers:
AT-10
AT-10D
These are L-Pads that are able to handle volume adjustment for an amplified signal. This makes for a great setup. I have this in two cabinets and am getting ready to install it in my third cabinet.
Enjoy,
John
mflint
  • Last login:March 01, 2014, 08:47:03 am
  • Shocking
« Reply #10 on: March 16, 2005, 08:30:14 am »
Hello;
all you need to do is go to
http:\\www.happcontrol.com
and in the search area type amplifier and check out what they have. page 2 at the bootm of the page is the best ones.
36watt- 2channel o
36 watt- 5.0 or 6.0 6channel with sub woofer support
