Author Topic: Wico Leaf Joystick Question  (Read 6682 times)
dag2000
  • Last login:May 21, 2020, 12:27:05 pm
  • One piece at a time.
« on: July 09, 2002, 05:00:59 pm »
Just bought some old control panels with buttons and joysticks included.  I am in the process of disassembling them to clean 'em up and have run into a problem.  There are two Wico leaf joysticks with a rubber diaphraghm attached.
How do I remove the diaphraghm?  Are these sticks just so old that the rubber has glued itself to the sticks?  Is there a secret?
-Dave
x-wing
  • Last login:March 28, 2003, 10:40:37 pm
  • I Built My Own Arcade Controls!!
Re: Wico Leaf Joystick Question
« Reply #1 on: July 09, 2002, 05:45:10 pm »
Yeah, the shafts should slide right out.  They most likely are pretty gummed up from the years of use.  Spray some silicone on them to loosen them up.  DON'T use WD-40 or penatrating oil, as that can break down the rubber in the old grommet.
