Author Topic: Alien Syndrome "head"  (Read 3138 times)
jfunk
  • Last login:October 24, 2018, 04:36:39 pm
  • BYOAC Wannabe
    • JFunk's Arcade
« on: January 05, 2005, 10:58:38 am »
I have an Alien Syndrome cabinet..  Fully working, in great shape.  I REALLY like the look of the cab..  Was thinking it might be cool to carry some of the same elements over to my upcoming MAME cab..  Specifically, the head (yeah, I know it's a bit cheesey, but I think it's great!  :)
Here are some pics of the cabinet:
http://www.e-funk.net/arcade/images/as/
Anyways, does anybody have any idea how to fabricate something like the head?   (Not it EXACLTY, but similar in nature...)
I thought about maybe a giant vacuform like this:
http://www.halloweenfear.com/vacuumformintro.html
But I wanted to see if anybody else had ever tried anything like that..?  Besides, I don't know how I'd create the original 'mold' for the vacuform..  If I could do that, I wouldn't need the vacuform because I'm not planning on mass-producing  :)
Anyways, anybody have any thoughts?
zorg
Re: Alien Syndrome "head"
« Reply #1 on: January 05, 2005, 11:02:57 am »
sorry I could not answer your question. I have no idea on how to perform such things.
but I have one request: could you provide us a scan of the marquee ??
I'm on the planning stage
jfunk
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #2 on: January 05, 2005, 11:05:35 am »
Hrm...  I can try..  I've never scanned anything like that..  It'll take me a while  (it's in my basement, and my computer/scanner are on the 2nd floor)...
Would the sideart be helpful, too?  CPO?  I'm guessing hi-res pics probably won't be good enough?
Any tutorials on scanning stuff like this?
Thanx.  :)
zorg
« Reply #3 on: January 05, 2005, 11:20:31 am »
moving the computer and scanner will be easier than moving the cab ;-)
but i guess things will become easier if if you can un-mount the marquee.
sure it will but the process of scannig a side art if far more complicated
you should ask ravage for the tips and trick of scanning, he is THE scanner man at the momment.
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #4 on: January 06, 2005, 03:09:56 am »
If you want to duplicate the shape of the head, probably the easiest way would be to use 2-part foam.  First find or build a box big enough to hold the piece.  Put plastic around the original and find a way to mount it face-down in the box.  Then put the 2-part foam in the box and it will expand and harden around the original.   There's your mold.
Then take the original out and cover the mold with plastic.  Pour more 2-part into the mold and when it finishes curing break the mold away and you've got a foam shape that should match the original head.  For best results fiberglass it or use some other hardening technique to make it more durable.
jfunk
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #5 on: January 06, 2005, 08:47:38 am »
Hrm..  That's definitely a thought..   I wonder if I'd still be able to "light it up" like the real head does...
I'll have to do some research..
Thnx for the idea!
Samstag
« Reply #6 on: January 06, 2005, 10:21:36 am »
The only way that might be lightable is if you can find a clear or very translucent hard coating over the foam and then dig the foam out.  A light fiberglassing with white cloth might do the trick.
If you can find someone local who can do that size vacuum molding, you'll get a much more lightable end result.  In that case you'll probably still want to do the foam molding trick to get a useable mold for them.
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« Reply #7 on: January 06, 2005, 11:51:39 am »
Any luck with the head would be interested to know how you got on.
ktulu
  • Last login:May 12, 2009, 06:47:24 pm
  • MonsterCabinets
« Reply #8 on: January 08, 2006, 11:02:30 am »
Im hunting for one of these if anyoine has one they want to part with please contact me!
I vacu-form and would love to try something this big. Not sure the dimensions but it looks pretty wide.
