Author Topic: Sega Virtua Racing Deluxe Monitor Problem  (Read 3033 times)
keinert
  • Last login:January 09, 2005, 03:38:02 am
« on: January 04, 2005, 07:40:18 pm »
Hi All,
I have a Sega Virtua Racing Deluxe cabinet (the sitdown with the big red plastic moldings and the air bags in the seat). It can be seen by taking the link at the bottom of www.keinert.com (My Collection). It uses a special wide screen NANAO display. Sega P/N 200-5240. A problem has recently occurred. When I power the game on, occasionally the monitor is dead. Upon inspection, I have found that sometimes the relay on the "PCB-POWER" board does not energize. When this happens, I have no buzzing of the flyback and no picture on the display. If I cycle power, sometimes the relay will energize (in which case the monitor works fine) and sometimes it does not energize (dead monitor). I have no schematics for this board (NANAO P/N 05A00516B1) but I'm guessing that the relay energizes only when all correct voltages are present on the board and that it energizes to allow these voltages to leave the PCB-POWER board and supply power to the rest of the monitor's circuitry??? If so, the relay is probably OK and my problem is that the voltages are not always coming up properly on the PCB-POWER board as they should. My questions are:
1) Does anyone have any experience with the VR Deluxe monitor?
2) Anyone have a phone number or website for NANAO?
3) Anyone have the schematics?
Thanks for your time, Kevin.
www.keinert.com
keinert
Re: Sega Virtua Racing Deluxe Monitor Problem
« Reply #1 on: January 05, 2005, 12:31:37 am »
Additional info, when it works, I hear the buzzing of the flyback before the relay energizes (on power up). So my initial theory about the relay supplying power to the rest of the circuitry is not correct. The monitor runs on 100VAC. One interesting thing I found is that if I plug it into 120VAC, it works every time. If I hit it with 120VAC the first power up and then power it up on 100VAC right after that, it will work every time. It's only when I let it sit powered off for a few minutes and then try to power it up on 100VAC that it fails (no flyback buzz and no relay click). When that happens, I have to wait 15 or 20 minutes and then power it up with 120VAC to make it work again. Any thoughts????
Thanks, Kevin.
