Author Topic: MAMEWAH - Can you have a .PIF execute TWO programs?  (Read 1206 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: January 04, 2005, 10:47:35 am »
This is regarding my other thread (using Daemon Tools on an arcade machine) -- it's been suggested that I only have two virtual drives and then load/unload CD's on-the-fly.
I'm using MAMEWAH which uses .PIF files to load PC Games.  Now as far as I know, a .PIF file can only load one program so how would I have it execute TWO programs? (eg. run a command-line command to have daemon tools switch CD's, and THEN execute the CD program)  I'm thinking I might need to use a .PIF to point a batch file but wouldn't the batch file window (eg. dos prompt) show on the screen before the game loads?
Re: MAMEWAH - Can you have a .PIF execute TWO programs?
« Reply #1 on: January 04, 2005, 10:53:43 am »
Why PIF's?  You should use shortcuts (.LNK's)...or at least shortcuts to PIF's if they are DOS games...
To my knowledge you are right, you would need to use a batch file.  Depending on the game, show_dos_box no would prevent the dos window showing, although it *may* prevent the game from being launched properly.
jcrouse
    • CPViewer
« Reply #2 on: January 04, 2005, 10:54:59 am »
How about a batch file? You need to mount an image in the device, then launch your emulator. The image will be called using a %1 variable to reference the commandline parameter that is send from MameWAH.
John.
sofakng
« Reply #3 on: January 04, 2005, 11:01:57 am »
Thanks for the replies...
I'm sorry, I confused .PIF and .LNK...  I did mean .LNK.
I'll try creating a .LNK file that runs a .BAT file (w/show_dos_box set to no) and see how that works -- hopefully it will work OK.  If that causes problems then maybe I'll just write a quick Delphi application that runs programs for me...  (there's a ShellExecute() parameter that hides any DOS windows)
By the way, MINWAH, what language is MAMEWAH written in?  (just curious)
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #4 on: January 04, 2005, 11:25:30 am »
I have a number of virtual drives (6) and the .lnk files work fine through Mamewah.  I think there is a limit to the number of drives you can have but that's not an issue for me currently.  I just have the drives mount on startup.
« Reply #5 on: January 04, 2005, 11:34:30 am »
Hopefully it will be fine, but some games work differently to others, so keep your fingers crossed!
VB6.  I think ShellExecute is similar to the method I use...the problem is when apps switch to fullscreen mode, or use a launcher app of their own (which runs another .exe) - the initial dos box can always be hidden but sometimes this causes problems after the game has actually launched - as I say each game is different so hard to say...
BTW if you are using the latest beta version of MAMEWAH then set {safelaunch} for best compatibility...if not ignore that :)
