Author Topic: miniPac - can you hook up a trackball AND spinner?  (Read 1176 times)
megashock5
  • Last login:May 19, 2015, 06:51:16 am
« on: January 04, 2005, 10:12:11 am »
Hello, I'm going to be using a miniPac for my interface and I already have the trackball. I'm trying to decide if I'm ambitious enough to attempt building a spinner. However, before I start I want to make sure both can run off of one miniPac. If not, looks like I'll make do with just the trackball.
thanks!
vputz
  • Last login:August 23, 2010, 08:16:05 am
  • I'm a llobter!
Re: miniPac - can you hook up a trackball AND spinner?
« Reply #1 on: January 04, 2005, 10:42:52 am »
I have a miniPac (and love it); you can indeed connect a trackball and spinner simultaneously, but you can NOT use them both at the same time.  The minipac is switched; if you move the spinner, trackball motions are not registered at all until you leave everything motionless for a bit (and then moving the trackball disables the spinner, etc).
-->VPutz
sWampy
  • Last login:February 02, 2010, 04:23:40 pm
« Reply #2 on: January 04, 2005, 11:03:23 am »
Make sure you talk to Andy before buying one with out a wiring harness, he said the new boards bought without wiring trackball wiring harness wouldn't support trackball or spinner.
megashock5
« Reply #3 on: January 04, 2005, 11:59:22 am »
I bought in the fall, but I did buy it with the wiring harness. So hopefully I'll be okay.
Is it hard to connect both (spinner and trackball) to it?
vputz
  • I'm a llobter!
« Reply #4 on: January 07, 2005, 05:50:59 pm »
Dead easy... provided you get the right trackball/spinner (in other words, if you bought a Happ/Vortex cable, buy a Happ trackball and a Vortex spinner).  You'll have two cables to the harness--one for the TB, one for the spinner.  Plug and go.
However, I do recall being confused about how to plug one of them in, but I don't remember what the specific problem was... so there may be some confusion.  Bleah, curse my fading memory.  It worked out fine, though.
-->VPutz
