Author Topic: Controls won't work after XP upgrade  (Read 1437 times)
rerstad
  • Last login:December 11, 2006, 01:25:57 pm
« on: January 03, 2005, 11:31:34 pm »
I just upgraded to Windows XP Home and now none of my controls, which are hooked up with an IPAC4 work.  It appears that the drivers are still there, etc., but they do nothing.
Any ideas?
Thanks.
Katana Man
  • Last login:September 22, 2024, 12:10:44 pm
Re: Controls won't work after XP upgrade
« Reply #1 on: January 04, 2005, 12:22:45 am »
Drivers?  You shouldn't need any for an IPAC4.  Are you using PS2 or USB connection?
rerstad
« Reply #2 on: January 04, 2005, 06:41:40 am »
Using USB.
mms332
  • Last login:October 13, 2006, 01:42:02 am
« Reply #3 on: January 04, 2005, 01:30:34 pm »
I don't know how an IPAC works, but here is an idea:
Check to see if Windows changed the naming labels of your IPAC's input commands. For example: maybe MAME is lookng for label "J1_X+" while Windows has this registered as "J1_JOYSTICK_RIGHT". You can do this with MAME by firing up a game and accessing the "input general" screen. Enter a new keystroke command to the list and compare the label with the old one.
If the IPAC is registered as a gamepad you could also check if the controller ID has changed.
Good luck!
Katana Man
« Reply #4 on: January 04, 2005, 01:39:34 pm »
The IPAC is seen as a keyboard, therefore the best test is to fire up notepad (or similar) and see if you are getting any keystroke output.
« Last Edit: January 04, 2005, 02:50:04 pm by Katana Man »
GGKoul
  • Cheesecake Apprentice
rerstad
« Reply #6 on: January 04, 2005, 06:56:14 pm »
Tried everything again, still  no luck.  In Notepad I get nothing out of the controls at all.  Tried uninstalling the USB driver, replugging, computer reinstalls driver or whatever, says it's installed and functioning fine--still nothing.
Tried watching the ipac during boot up and see no LED light described in the ultimarc website--I got the ipac used, so not sure how old it is, but I don't see an LED anywhere on it.
The ipac worked fine until the upgrade to XP, now, nothing at all.  AARRGH!
cdbrown
  • Bowowow
« Reply #7 on: January 05, 2005, 02:26:09 am »
Do you have anything else that is USB to test that the USB drivers are actually installed properly  XP.  Can you use the keyboard while it is plugged into the ipac pass-thru?
rerstad
« Reply #8 on: January 05, 2005, 06:37:21 am »
Plugged the keyboard into the pass-through and the keyboard works fine, so all seems to be working, except the ipac!
