Author Topic: Where to buy replacement coin mech switches?  (Read 1527 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: December 31, 2004, 12:36:09 am »
Here's a pic:
Ixliam
  • Last login:December 01, 2018, 01:23:31 pm
  • DIY Skee-Ball Man
Re: Where to buy replacement coin mech switches?
« Reply #1 on: December 31, 2004, 12:45:28 am »
Happs has them, I was just looking there a few minutes ago since I might need those style switches for my own project.
Brad
Ken Layton
  • Guru
  • Technician
« Reply #2 on: December 31, 2004, 01:21:53 am »
That's what's called the "Busy B" coin switch and is used on the Coin Controls coin doors. Happ Controls sells it as their stock number 42-3257-00 (Coin Controls # 891-1116-16). It sells for around $5.
« Reply #3 on: January 01, 2005, 02:08:45 pm »
Happ also sells these switches with a straight wire which can be bent into shape.  I have ordered a few of those, although mine look the same as the one pictured (my mechs are indeed Coin Controls ones).
Dougmeister
  • Dig-Doug
« Reply #4 on: January 05, 2005, 10:13:34 am »
Thanks, guys.
How should this be wired up?
Ken Layton
  • Guru
  • Technician
« Reply #5 on: January 05, 2005, 10:53:12 am »
The terminals to be connected are the very bottom and very top ones.
C - common
N.O. - normally open
Dougmeister
  • Dig-Doug
« Reply #6 on: January 06, 2005, 12:03:03 pm »
Thanks, Ken.  I had the NC and the C both hooked up.
What does "NC" stand for?
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
« Reply #7 on: January 06, 2005, 12:23:54 pm »
normally closed.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
Dougmeister
  • Dig-Doug
« Reply #8 on: January 06, 2005, 03:33:47 pm »
Duh.  Brain fart.  Should have figured that one out myself.
Thx.
Dougmeister
  • Dig-Doug
« Reply #9 on: January 06, 2005, 03:35:04 pm »
C - common
So what is the NC terminal used for anyway?
Ken Layton
  • Guru
  • Technician
« Reply #10 on: January 06, 2005, 06:44:30 pm »
In 99.9% of commercial coin-op game applications the normally closed terminal is not used. You only need common and normally open. Originally the normally closed terminal was used in applications such as casinos where this terminal was used for cheating prevention.
Dougmeister
  • Dig-Doug
« Reply #11 on: January 07, 2005, 07:34:41 am »
Innnnnteresting.  Thanks.
