Author Topic: Discoloration on Monitor - Sharp Image SI-319S  (Read 3260 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: December 30, 2004, 11:30:25 pm »
I have a Sharp Image 19" color raster monitor in an omega race cabinet.
« Last Edit: December 30, 2004, 11:43:23 pm by 1hookedspacecadet »
Ken Layton
  • Guru
  • Technician
Re: Discoloration on Monitor - Sharp Image SI-319S
« Reply #1 on: December 30, 2004, 11:53:03 pm »
Probably needs to be manually degaussed.
_Iz-
  • Last login:February 14, 2026, 04:43:16 pm
  • Time to coin up!
« Reply #2 on: January 01, 2005, 02:32:16 pm »
try removing the speakers...
RetroJames
« Reply #3 on: January 01, 2005, 03:57:36 pm »
I had them unplugged
Ken Layton
  • Guru
  • Technician
« Reply #4 on: January 01, 2005, 07:33:03 pm »
Unplugging the speakers won't stop the speaker magnet from affecting the monitor colors. If speaker magnetism is suspected of causing color problems you need to actually remove them from the cabinet and get them at least 4 feet away from the monitor. Then manually degauss the picture tube.
RetroJames
« Reply #5 on: January 01, 2005, 10:30:37 pm »
As it is an Omega Race cabinet and I mounted the monitor as the original would have been, that is using the reflective mirror arrangement, the speakers are already at the top of the cab while the monitor is at the bottom.
I did use an amp from pc speakers andmounted the internals near the topofthe monitor.  You can see them on the upper left, the small pcb and what might be some magnets?
Also note the switch is for the monitor and I routed the power from the switch to the rear of the monitor across the area above the coindoor which is where the top of the monitor rests when mounted.
Do you think it is possibly comming from one or more of those sources?
Ken Layton
  • Guru
  • Technician
« Reply #6 on: January 01, 2005, 11:48:21 pm »
Could be that fluorescent light ballast is too close to the monitor. Try disconnecting that light fixture.
RetroJames
« Reply #7 on: January 02, 2005, 07:56:49 am »
I did turn it off and tested again with same results.  Does the ballast have magnets in it as well?
