Author Topic: Sharp Image - SI-319S - Horizontal Hold / Position Problem  (Read 1853 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: December 28, 2004, 12:16:48 am »
So I just tested my monitor for the Omega Mame project.
DOS
Config.sys is setup to load arcmon.sys
ArcadeOS has "Incabinet = 1"
When arcade os starts, I
« Last Edit: December 28, 2004, 12:12:31 pm by 1hookedspacecadet »
RetroJames
Re: Sharp Image - SI-319S - Horizontal Hold / Position Problem
« Reply #1 on: December 28, 2004, 12:13:38 pm »
Uggghhh -
I have the week off and was hoping to get the Omega Mame running, but am now dead in the water.
I called Sharp Image electronics and thier service folks are out until Jan 3rd.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #2 on: December 28, 2004, 12:45:10 pm »
Try using a copy of advcab and see if you get a stable dos pic.
I had problems with arcadeos output before and used advmenu instead.
http://advancemame.sourceforge.net/
Later,
dabone
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
« Reply #3 on: December 28, 2004, 06:24:04 pm »
If the chassis in your monitor is the same or similar to the one on my 34" Sharp Image monitor, make sure you have the sync going to the right pin on the chassis. I had almost the same symptoms you're describing until I moved the sync wire to right next to the ground wire instead of one away.
www.wolfelectronics.ca
Cap Kits for Canadians!
RetroJames
« Reply #4 on: December 28, 2004, 11:21:41 pm »
You sir are a steely eyed missle man!  Troubleshooting 101 - check the physical layer.  I had my HS and VS wires discombobulated.  I am staring at a beautiful image on the screen.
Can't thank you enough!
- Now just an ever-so-slight glow in the neck and a tich of discoloration at the very far right border at the middle of the screen.  Not even noticable really, I will go with it for now but see if the SI techs have any suggestions.
Wife is out all day tommorow WITH the nipper.  I will be playing Defender by this time tommorow!
Grauwulf
  • Button Masher
« Reply #5 on: December 29, 2004, 06:51:13 am »
I'm glad it worked out for you. I messed around with mine for a few hours before I finally figured that out on my own.
The glow you're seeing in the neck of the tube is normal. That's the heater that warms the electron guns so they work properly.
