Author Topic: Grounding an Arcade Monitor  (Read 4392 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: December 27, 2004, 07:15:27 pm »
I am hooking up a Sharper Image arcade monitor (19") - Model SI-319s.  The unit does ot require an isolation transformer.
Regarding the a/c input, I have identified the hot leg and neutral, but there is no grounding wire directly connected.  Should I route my ground (from the 3 prong ac input plug to the monitor's metal frame?
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
Re: Grounding an Arcade Monitor
« Reply #1 on: December 27, 2004, 08:14:48 pm »
Yes.
Regards,
D
Ken Layton
  • Guru
  • Technician
« Reply #2 on: December 27, 2004, 10:50:03 pm »
Yes, always ground the monitor frame.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #3 on: February 06, 2005, 02:40:52 pm »
So even if my monitor uses a 3 prong plug, I should be running a ground wire to the monitor frame too? Like the drawing below?
I've never grounded the monitor frame, I thought the 3 prong plug did it for me. Have I been in danger of electrocution? I don't feel so smart all of a sudden.
D_Zoot
« Reply #4 on: February 06, 2005, 02:50:04 pm »
The third pin in your cord is the ground.  Running an additional ground wire would be redundant.
*Most* monitors don't use a three prong cord, so it's generally stated to ground the monitor frame.
If a cab is already wired with a ground strap for the monitor, and I install a monitor with a 3-prong cord, I usually hook up the ground strap too. A little bit of extra safety never hurts.   If you have a three prong monitor cord and no ground strap in the cab, I wouldn't bother installing one.
Regards,
D
Ken Layton
  • Guru
  • Technician
« Reply #5 on: February 06, 2005, 06:51:59 pm »
If the monitor is installed in a game cabinet there should already be a ground wire or ground strap in there. You should connect it to the frame.
