Author Topic: Running Windows Vertically?  (Read 3711 times)
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« on: October 05, 2002, 07:14:00 pm »
On a Vertically mounted monitor..is there an easy way to run Windows vertically?
".....its like a Koala crapped a rainbow in my brain!"
BobA
  • What Me Worry?
Re:Running Windows Vertically?
« Reply #1 on: October 05, 2002, 07:19:48 pm »
Get pivot pro software.  Free trial download at:
http://us.portrait.com/products/tbub.htm
Worked well but since I dont run anything but mame on my vertical monitor I didn't need it.
BobA
BobA
  • What Me Worry?
« Reply #2 on: October 05, 2002, 09:01:02 pm »
Sorry forgot to add I used it on my 15 inch CRT and it worked fine.  Not just for LCD screens as the program seems to indicate.
However not all CRTs are created equal. Some dont like it on their sides.  I had to cut holes in the case to get proper cooling of my monitor since there were none on the sides and I could not remove the whole case without loosing proper support of the CRT for this particular model.
BobA
  • Last login:Yesterday at 07:12:04 pm
« Reply #3 on: October 06, 2002, 01:15:10 pm »
As bob said it depends upon the monitor.  The best thing to do is sit it in the aproximate postion you will want it and let it run for a few hours.  If the picture is still clear then it should be ok.  If not then you will hae to find anohter monitor.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #4 on: October 06, 2002, 03:54:30 pm »
If you have an nvidia geforce 2 or better card you can use the new line of detonator 40.xx drivers. They support rotation. And the best thing, unlike pivot software, with full hardware support so it is way faster...I don't see any noticable speed hit anymore with these drivers when running windows rotated.
Peter
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #5 on: October 06, 2002, 04:41:19 pm »
Peter
Questions, doe sthe detonator drivers rotate just windows?  so if you use mame you still have to rotate vert games??
)p(
« Reply #6 on: October 06, 2002, 04:50:00 pm »
Peter
These rotate everything...this means that everything is rotated also mame and that is why you will have to use rotate for vertical games...ie as the display is rotated what was vertical before is now horizontal...a horizontal game will appear horizontal when you look at the vetical screen...hehe is this making sense ;-)
SirPoonga
  • Puck'em Up
« Reply #7 on: October 06, 2002, 05:13:13 pm »
I think you said it backwards, I still don;t know if you NEED to use -ror for vert games.  You say it rotates everything, yet say you have to rotated.  But if it rotated everything, wouldn;t the vert games be displayed correctly since it would be rotated by the drivers????
)p(
« Reply #8 on: October 06, 2002, 06:26:32 pm »
if you have norotate set to 1 then you run mame dkong if you have set it to 0 then you run mame dkong -rol
Peter
SirPoonga
  • Puck'em Up
« Reply #9 on: October 06, 2002, 07:05:02 pm »
Peter
What if it is set to 1 though?  Then nothing?
nOGHRI
  • Last login:January 20, 2003, 05:41:50 am
  • Life is a ---smurfette---, and then you DIE!!
« Reply #10 on: October 07, 2002, 03:21:37 am »
There is rotating in newer ATI Radeon driver also..   ;D
A *person* is smart.
People are dumb, panicky, dangerous animals and you know it.
mrhowell
  • Last login:August 01, 2025, 09:42:31 pm
« Reply #11 on: October 07, 2002, 12:36:07 pm »
Is this the driver you used on the radeon cards "Driver Build 4.13.01.9039" ?
What is that pappy?
HeadRusch
« Reply #12 on: October 09, 2002, 08:31:08 pm »
Yeah I must be looking right through it..I just put a Radeon 8500 into my primary MAME PC (unbuilt cab), and I'm putting a Radeon 7500 into my mini-mame cab (also, unbuilt, but due to begin prototyping this week!)......on the 8500 I'm not seeing a monitor rotation option anywhere.
Does the DVI port have to be engaged for that option to appear!!??!?!?!?!
nOGHRI
« Reply #13 on: October 10, 2002, 04:57:34 am »
I am running a ATI Radeon 7500 on WinXP with the latest drivers. Driver Build 6.13.10.6166 ant the ATI Control Panels. And if i click the ati icon in the taskbar i have the option to turn the picture 90, 180 or 270 degres..     ;D
Works lika a charm..
