Author Topic: Need Software Recommendation  (Read 1499 times)
olsteve
  • Last login:March 24, 2012, 10:33:35 pm
  • To play or not to play, that is a stupid question.
« on: December 14, 2004, 07:30:47 pm »
I am looking for software that will do the following (I guess it would be called a front-end):
-When PC boots it would give an option screen to choose - mame, pinmame, console emulators, or just go to windows.
-I will be running windows XP, Mame32
I would like something to make it be 'not so windows' looking unless I tell it to go to windows.
Why is it when we talk to God we are praying, but when God talks to us we are put into the loony bin?
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re: Need Software Recommendation
« Reply #1 on: December 14, 2004, 07:34:12 pm »
http://forum.arcadecontrols.com/index.php/topic,19293.0.html
Also, I assume you meant MAME not MAME32 as MAME32 is a frontend.
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #2 on: December 14, 2004, 07:56:51 pm »
So you want it to skip windows?
olsteve
« Reply #3 on: December 14, 2004, 08:00:41 pm »
I want to be able to choose to go into windows if I want otherwise I don't want to see it. I want to have a 'choice' screen at boot-up. Listing mame-windows-anyconsoleemu-pinmame, so I can choose where I want to go.
Buddabing
« Reply #4 on: December 15, 2004, 09:07:56 am »
In old versions of windows you could set up config.sys / autoexec.bat to do what you are describing. Don't know about XP. What version of Windows are you running?
Please read the wiki!
Goz
  • KOTA
« Reply #5 on: December 15, 2004, 09:32:41 am »
In XP you could set up multiple users and go that route.
Example: User A = load into MAMEWAH or another FE, User B = regular XP no FE configured in registry or startup shortcuts.
Other than that you might be able to find a command line argument that passes a user acct in a boot manager like acronis, system commander, boot magic, etc...
Good Luck
-Goz
Lilwolf
« Reply #6 on: December 15, 2004, 10:06:50 am »
and dont forget about the active desktops.  Write HTML and I hear you can do what your asking.
There are also frontend frontends out there that do that.
But an all - in - one frontend that handles multiple emulators and applications is probably best.
