Author Topic: Recording sounds in mame.  (Read 1843 times)
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« on: December 13, 2004, 01:10:11 pm »
How does one do it? I found most sounds on the net but I need the xevious start up sound. Reason for this is my mobile takes wav files for ring tones I already have the Galaga start up sound as my ringer.
Curls in the squat rack !?!?!
Tiger-Heli
    • Tiger-Heli
Re: Recording sounds in mame.
« Reply #1 on: December 13, 2004, 01:15:15 pm »
I think you can do this with M1 or Total Recorder - http://www.highcriteria.com/
« Reply #2 on: December 13, 2004, 07:09:33 pm »
I don't think Xevious is supported by M1 atm, Total Recorder should do it tho.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #3 on: December 13, 2004, 07:12:37 pm »
There's an option in Mame to output to a WAV file. It's been in there since 0.84 but I've never used it.
From the 0.84 WhatsNew.txt:
- New option in the Windows version: -wavwrite to save sound output to a WAV file.
Edgedamage
« Reply #4 on: December 14, 2004, 12:15:35 am »
Thank you.
  • Last login:Yesterday at 01:44:40 pm
« Reply #5 on: December 14, 2004, 09:56:52 am »
What I do, which is far simplier to manage, is to run mame in a windowed mode while windows sound recorder is up at the same time.  When the sound effect I need is about to be played I pause the game, switch over to the recorder, start recording, unpause and then switch back and save the wav file.  It makes for far more effecient editing later.
« Reply #6 on: December 14, 2004, 12:14:28 pm »
IIRC Sound Recorder has a limit to how long you can record for though  - might be an issue if recording long periods of music/effects.  Total Recorder (or similar) shouldn't have this restriction...
Biff Byford
  • Last login:September 23, 2005, 07:34:54 pm
« Reply #7 on: December 16, 2004, 09:50:08 pm »
While we're at it -- how do you capture a video?
« Reply #8 on: December 17, 2004, 10:18:06 am »
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: December 18, 2004, 08:53:02 am »
http://www.mameworld.net/emuadvice/ripsguide.html
Basically MAME32 V37b16 or previous
« Reply #10 on: December 18, 2004, 06:00:31 pm »
sound recorder gives you a full minute of time at high quality, if you need more than that then you must need background music, and it's impossible to get a clean clip from mame (due to sound effects).
« Reply #11 on: December 19, 2004, 12:05:35 pm »
Yeah, but as I said, you can't get a clean sample due to sound effects getting in the way.  I'm a perfectionsit, there's no way I'd use dirty samples for anything.
« Reply #12 on: December 20, 2004, 01:51:48 pm »
