Author Topic: Metal Slug System Requirements  (Read 5125 times)
sasuke_kun12
  • Last login:March 10, 2009, 09:05:13 pm
  • Its been to long... I'm never leaving this place!
« on: December 12, 2004, 06:00:11 am »
would Metal Slug run on a p1 133 no mmx?
Why are all the good, cheap lowboys in brisbane?
LordDamo
  • Last login:December 10, 2008, 04:26:05 am
  • Damn it Jim, im a doctor not a machine . . .
    • The Kinddom of Damo
Re: Metal Slug System Requirements
« Reply #1 on: December 12, 2004, 06:14:52 am »
probally not - it would be verrry slow. The lowest end PC ive had all the Metal Slug games running on well was a P3 750 Mhz. It was a little slow but but (just) playable on a P2 400 Mhz.
Hope this helps
Religious war is like two kids fighting over who has the stronger imaginary friend . . .
sasuke_kun12
« Reply #2 on: December 12, 2004, 07:28:01 pm »
ok cool i'm gettin a p2 333 and i'll overclock it
peace out
mnm1200
  • Last login:March 10, 2006, 05:55:34 pm
  • IANAL: I am not a llama!
« Reply #3 on: December 12, 2004, 08:14:26 pm »
Man, I must be doing something wrong. MS2 grinds to a halt on busy screens, and I'm on Athlon 2700+!
Demon Dog? Urusai! ...Baka
Apollo
    • Eight Bells
« Reply #4 on: December 12, 2004, 08:23:40 pm »
How are you running MAME? That shouldn't happen.
mnm1200
« Reply #5 on: December 12, 2004, 08:29:19 pm »
It's MAME32 .86
I plan to steer clear of MAME32 as soon as the cab starts coming together. It's just an intermediate solution (the easiest to set up)...
Sys specs:
Athlon 2700+
512MB PC-3200 RAM
RADEON 9600Pro 256MB
ABIT NF7-S mobo (integrated sound)
WinXP SP2
(planning on the same setup in the cab but with an ALL-IN-WONDER instead)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #6 on: December 12, 2004, 08:39:49 pm »
nebula and kawaks run neogeo better than mame.
Apollo
    • Eight Bells
« Reply #7 on: December 12, 2004, 08:48:48 pm »
I'm running Windows command line MAME 0.86 on a 1.7GHz Duron with 256MB RAM. Metal Slug games run fine. I am running ArcadeVGA video card. Try changing to command line or what about frame skipping?
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #8 on: December 12, 2004, 09:58:35 pm »
Metal Slug 2 grinds to a halt in the arcade!
spongebue
  • Last login:April 20, 2006, 03:50:32 pm
« Reply #9 on: December 12, 2004, 10:40:55 pm »
I just got MS2 to work on an AMD-K6 450MHz (PII 300, basically) at a tiny bit below fullspeed.  I don't quite see how it would be that bad on an Athlon 2700+
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #10 on: December 12, 2004, 10:55:20 pm »
On my first Mame cab, Metal Slug played perfectly; and that was a slot-A Athlon 500mhz running DOS Mame 37b12 (as far as I can remember). I doubt it could play all so well on a P1 133, but it'd be interesting to see. If all you want the PC to play is that one game, you should try using an emulator other than Mame (a dedicated DOS Neo Geo emulator should give much better results).
Have a look here for DOS Neo Geo Emu's : http://www.zophar.net/neo-geo.html
TalkingOctopus
    • My Arcade
« Reply #11 on: December 13, 2004, 12:11:53 am »
Exactly.
Gunstar Hero
  • Back in action!
« Reply #12 on: December 13, 2004, 03:14:03 am »
Yep.
For a change, slowdown actually equals accurate emulation.
Who knew??
LordDamo
« Reply #13 on: December 13, 2004, 07:09:31 am »
It's MAME32 .86
Sys specs:
Athlon 2700+
512MB PC-3200 RAM
WinXP SP2
Wow! that thing blows my mame PC outa da water! Im using a PIII 850Mhz with 128Mb RAM and a Nvidia 64mb video card. I can play all (including 5) on this machine. Im using the command line version of mame though. The mame32 version slowed down on me too (MS2 I mean). For Metal Slug 5 I use neo rage. My OS is Windows 2k (SP 3).
Hope this helps
LD
mnm1200
« Reply #14 on: December 13, 2004, 04:35:07 pm »
That's quite interesting. Thanks for all the help guys! :D
