Author Topic: The Lowboy From Brazil (new pic - June 18, 2006)  (Read 50463 times)
hbm*rais
  • Last login:September 03, 2010, 08:43:44 pm
  • Relaxen und watchen das blinkenlichten!
« on: December 10, 2004, 08:01:32 pm »
This is my first project. It
« Last Edit: June 18, 2006, 02:37:09 pm by hbm*rais »
hbm*rais
Re: The lowboys from Brazil
« Reply #1 on: December 10, 2004, 08:21:19 pm »
This is the mock up made by my friend Fernando. It helped us alot in deciding that it was the right size of cabinet.
I
hbm*rais
« Reply #2 on: December 10, 2004, 08:38:53 pm »
And this is the current state of the cabinet...
« Last Edit: December 10, 2004, 08:41:22 pm by hbmorais »
Witchboard
« Reply #3 on: December 10, 2004, 09:57:36 pm »
Very cool.  I'm wanting to build one of those for my Neo-Geo MVS.  What size monitor are you going to put in it?
hbm*rais
« Reply #4 on: December 10, 2004, 10:07:14 pm »
I
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #5 on: December 11, 2004, 06:25:38 am »
Great job so far.  I can't believe how well it has come out, especially since my plans were pretty pathetic!  Let me know if there were any other measurements you needed.
TOK
  • The Game Always Wins
« Reply #6 on: December 11, 2004, 07:24:27 am »
Can you e-mail me the plans in PDF? My brother-in-law went crazy for my full sized cab, but has been having a lot of trouble finding trashed cabaret to convert. This is perfect for him! Really nice work!
hbm*rais
« Reply #7 on: December 11, 2004, 08:24:16 am »
Stuzza,
Your plans weren
« Last Edit: December 11, 2004, 08:48:16 am by hbmorais »
« Reply #8 on: December 12, 2004, 06:55:51 pm »
Looks good, I like these style cabs and they are fairly unusual too.  Good work :)
hbm*rais
Re: The Lowboys From Brazil
« Reply #9 on: December 12, 2004, 09:29:07 pm »
Thanks Minwah! I loved your System 1 cab too, it
hbm*rais
Re: The Lowboys From Brazil (Help with glass)
« Reply #10 on: December 12, 2004, 10:31:48 pm »
Well, this is the last week of classes, after that we lose access to the woodwork shop until sometime in January. So we have to try to finish as much as possible until Friday.
We
« Last Edit: December 12, 2004, 10:37:48 pm by hbmorais »
hbm*rais
Re: The Lowboys From Brazil (help with glass and painting)
« Reply #11 on: December 13, 2004, 11:32:33 pm »
It
« Last Edit: December 14, 2004, 12:21:45 am by hbmorais »
hbm*rais
Re: The Lowboys From Brazil (help with painting)
« Reply #12 on: December 13, 2004, 11:35:02 pm »
And the glass....
Witchboard
Re: The Lowboys From Brazil (new pics / help with painting)
« Reply #13 on: December 14, 2004, 12:03:31 am »
That glass will work fine.  Looks really good.  I don't know about the paint.  I'm in the middle of painting a 3/4" plywood shelf with black water based paint.  The reason I chose water based is because I'm painting in my garage and didn't want the fumes, and wanted an easy cleanup.  I'm pretty sure with MDF you're going to have to use a primer to keep the wood from constantly soaking in your paint.  If you have access to a spray gun, I would use that.  I've seen guys get mirror finishes on their cabs with that method.  Mmmmm... pretty.
hbm*rais
« Reply #14 on: December 14, 2004, 12:11:32 am »
Thanks for the input Witchboard.
I forgot to mention, I think I am going with a semi gloss finishing. Red or blue on the sides and black on all the rest. I still haven
zzsprade
  • Last login:September 05, 2023, 02:31:25 am
« Reply #15 on: December 22, 2004, 06:03:48 am »
hbmorais,
Fantastic work. I too am working on a lowboy in Australia... except it has been taking me way too long.
I just had some questions to ask you about how you went about mounting/holding the tv shown in the pictures. Also how are you looking at supporting the monitor once you get around to it. Brackets? Decasing it and using the frame around the monitor to support it?
The reason why I ask is that I am looking at installing a 20" or 21" pc monitor and any tips, tricks, or design ideas that you could share would be fantstic.
Thanks again and good luck!
-Alex
hbm*rais
« Reply #16 on: December 23, 2004, 11:16:44 am »
Thanks zzsprade,
The actual building took us around 2 weeks, plus 1 week for painting. But that
« Last Edit: December 23, 2004, 11:19:43 am by hbmorais »
hbm*rais
« Reply #17 on: December 23, 2004, 12:27:12 pm »
Zzsprade,
This picture is from the cabinet with the PC monitor. You can see the wood pieces we had to use to hold the circuit board under the monitor.
Before actually cuting the hole in the plywood panel for the monitor, I would mount that panel in the cabinet and draw some rough lines where you expect the screen to be. Fernando didn
hbm*rais
« Reply #18 on: December 23, 2004, 12:59:57 pm »
Finally, this is the current state of my cabinet. We finished painting it yesterday.
My intention was to use water based paint and a roll but so many people told me that using oil based paint and a spray gun would give better results that I had to go that way.
The result wasn't near as bad as I feared, but also not as good as I hoped.
The main problem was two fairly deep scratches that didn't appear on the raw MDF, neither when we sprayed it with the matte gray primer, but just jumped in my face after the first coat of shiny red paint. If we had the time, I would come back to fill and prime it. But we hadn't.
We gave it two coats of paint and that paint has a very good coverage, but I'd love to give it a third coat, just for good measure.
At the end of the day the result was pretty good and I
hbm*rais
Re: The Lowboys From Brazil (Painted!!)
« Reply #19 on: January 16, 2005, 12:15:09 am »
Well, after a slow start this year, I resumed work on my cabinet. I have had an awful amount of problems with the hardware. I guess that
« Last Edit: January 17, 2005, 11:43:24 pm by hbmorais »
Witchboard
Re: The Lowboy From Brazil and its $0,50 bezel
« Reply #20 on: January 17, 2005, 10:16:34 pm »
That's a nice bezel.
« Last Edit: January 17, 2005, 10:19:28 pm by Witchboard »
Tailgunner
« Reply #21 on: January 17, 2005, 11:47:53 pm »
Excellent work on your cab.  :)
hbm*rais
« Reply #22 on: January 18, 2005, 09:06:14 pm »
Thank you. Yes, that's exactly that kind of $2 bezel  ;D .
Yeah, the circuit board mounted to the wall looks slick. It makes it seem like a real cab not something home made. I couldn't do that to mine though. The wires that link the circuits to the tube in the PC monitor are much shorter than the ones in the TV.
Unfortunately Fernando has gone a bit overboard now and mounted the whole computer to the sidewall. I don't like the idea very much. I'm using an old PC case to keep the computer parts together in mine.
Note to self: I have to talk to him about that HD just inches away from the subwoofer. Looks like a bad idea.
Yes, I did consider the heat venting, although I have done nothing about it yet. Fernando installed a big 120mm fan on his one. I'm using mine opened until I have finished the configurations and resolved what to do about the coin door.
That's a nice bezel.  Is that the $2 kind from the new user FAQ?  Also, I like how the one cab has the monitor chassis mounted to the wall instead of having it hang off the tube.  Pretty slick.  Can't wait to see the finished products.
Oh... I guess it's a $.50 bezel.  ;D  Again.. looks great!
Also, have you considered your heat venting?  I didn't notice any fans or air holes.  The one with the amplifier for the bass escpecially.
« Last Edit: January 19, 2005, 01:31:10 am by hbmorais »
hbm*rais
« Reply #23 on: January 18, 2005, 09:13:19 pm »
Thank you tailgunner!
Your idea for the $2 bezel is incredible. I'm amazed by how well it worked.
If there was a Mamey for the Best All Around Hack or Most Creative Use Of Card Paper, you should win it  ;D!
hbm*rais
Re: The Lowboy From Brazil (Update+pics)
« Reply #24 on: April 03, 2005, 04:09:43 am »
OK, this message is just to bring my thread back from the dead and show you the current state of my cab.
The control panel has been rewired and is now finished. I intend to move the start buttons to the vertical panel and put a spinner in there in the future, but it's finished for now.
I installed two 5" car speaker amplified through some El Cheapo 2.1 computer speaker. The speakers have blue cones that give a nice blue glow when the marquee is turned on.
No real marquee for now. Just a b&w Galaga mock-up as a place holder. I'm researching my options at the moment.
« Last Edit: April 03, 2005, 04:13:00 am by hbmorais »
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« Reply #25 on: April 03, 2005, 02:38:11 pm »
Very, very nice, one of my favorites. Two requests though, even if you aren't going to wire it up, put on a coin door to make it look authentic. Also, please dont put a "mame" marquee on their, make something unique, or put a single game marquee. GOOD WORK!
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
kcoleman
  • Last login:September 18, 2005, 01:29:01 pm
  • My Mame obsession is driving my wife crazy
    • My Cab Blog
« Reply #26 on: April 04, 2005, 12:02:16 am »
sweet cab.  I am thinking about buildng one of these myself.  I really like the design and dimensions
Witchboard
« Reply #27 on: April 04, 2005, 10:56:34 am »
Glad to see it's finished.  It looks really good.  I was wondering if your speakers were a distraction when playing games.  Normally it's not a big deal when the monitor is more upright, but do you get a reflection on the glass protecting your monitor, and if so, is it distracting?
hbm*rais
« Reply #28 on: April 04, 2005, 02:56:51 pm »
Thank you all for the positive comments!
the3eyedblindman: Your requests will be granted  ;D!
I do intend to use a coin door, but for cost reasons I'll have to make due with a used one, bought from a local operator I know. Importing one is out of que$tion. Brand new local ones are also pretty expensive.
The pictures show the door I'm probably going to buy and Fernando's cabinet equipped with a similar door. As you can see, they are much more "plain" than the American ones. The one I'm buying is also a bit damaged, but I should be able to fix it.
I still don't know if I'm gonna keep it polished steel or paint it red or black. Suggestions are accepted  :D.
I originally intended to use just a small coin plate in the front door, like in the Australian lowboys, but the door will allow me an easier access once I put the computer inside the cabinet.
« Last Edit: April 04, 2005, 08:35:08 pm by hbmorais »
hbm*rais
« Reply #29 on: April 04, 2005, 03:13:22 pm »
the3eyedblindman: Oh, and about the marquee... I'm leaning toward the Galaga marquee for now. In the future I may try to make something "unique" if I feel inspired  :D. The MAME marquee was never an option. I agree with you that it has been overdone and it really wouldn't make sense. This cabinet will be used to emulate old console games too and even when it comes to arcades, I'll probably use Kawaks and Raine alongside MAME, so there's no reason to give the whole marquee to MAME  ;).
hbm*rais
« Reply #30 on: April 04, 2005, 03:31:04 pm »
Thank you. No, the speakers are not distracting, at least not to me. You can't see the light coming from them directly while playing. You do see the reflection on the glass, but it is faint and located above the screen area. I was more worried about the light of the marquee shining in my face. I thought it would be uncomfortable, but I barely notice it while playing. All in all it makes for a nice "ambiance"   :).
the3eyedblindman
« Reply #31 on: April 04, 2005, 05:51:40 pm »
Dude, for real, nice cab. As for a coin door, all I did was post in the buy sell trade forum for a used over under coin door, and within minutes I got one like new for 5 dollars, a new coat of black paint and new coin door stickers and it looks great. As for a marquee, I had one made with 40 mini marquees of my favorite games by snaake, I try making it look authentic as possible, I consider myself very "high standard", I only like the best, and I wanted people to think it was a real arcade machine. Your machine looks great, I love it, keep up the GREAT WORK!
miikeboyle
  • Last login:November 05, 2020, 06:49:27 pm
« Reply #32 on: June 17, 2006, 08:49:12 pm »
Hey,
Sorry to drag up an old post.
Living in Aus, Ive grow up playing on lowboys.
I really like you cab.
Could you please share you plans with me?
miikeboyle@hotmail.com
Mike
hbm*rais
« Reply #33 on: June 18, 2006, 02:29:44 pm »
(@ Mike: I just sent you the plans)
I've been meaning to wake up this post myself for a long time.
The cabinet is more or less finished (do they ever?) for about an year now. In the mean time I got married, moved, had to take care of a lot of repairing and refinishing in my old apartment, so there hasn't been much new on the cab. It did see a lot of play, though ;-).
What's new:
I installed the coin door. It's the kind we use in Brazil. I debated if I should paint it red or black, but decided to keep in unpainted. I like the stainless steel finishing. It had lots of scratches and some dents. I took care of most of the superficial damage, the rest adds to the "real arcade" feel ;-).
I also printed (ink jet) a Galaga marquee for it. My plan is to eventually have half a dozen marquees laser printed for it and keep changing them now and then. All real games, no custom or MAME marquee.
What's in the (hopefully near) future:
A new 2-player CP. I already have the controls. I'm working on the design.
So here it is, my lowboy in its new home:
zzsprade
« Reply #34 on: June 19, 2006, 06:47:52 am »
Hey,
Mike
I am sure there is a fair amount of interest here hbm*rais if you could put the plans up on the board some how.
From memory the last set have disppeared off the page they were previously, on which was from someone here in Australia.
Any chance you wouldn't mind sharing them?
-Alex
hbm*rais
Re: The Lowboy From Brazil (new pic - June 18, 2006)
« Reply #35 on: June 19, 2006, 08:22:43 am »
Alex,
I'm glad to see the interest in the plans.
They were previously hosted in my old ISP here in Brazil ("down under", but not Australia ;-) ). They're nowhere to be found on the web now, unless someone "mirrored" them. I will still e-mail them to anyone who wants though.
As for making the plans available, I certainly don't mind sharing them. If anyone wants to host them, be my guest! However, this plans consist of just a Illustrator 1:1 file (I also did some work on "translating" the plans to SketchUp)
. Lot's of measures and angles are not stated clearly, they have to be "measured" using Illustrator tools to retrieve the information. It world be cool if someone with technical training would take a look at them and make something more professional.
Anyone up to the task?
« Last Edit: June 19, 2006, 08:24:36 am by hbm*rais »
holdennut
  • Last login:January 16, 2015, 04:53:06 am
  • Aussie lowboy cab finished!
    • Australian Cocktail Pac-Man Project
« Reply #36 on: June 19, 2006, 10:48:29 am »
hbm*rais, you Lowboy is awesome, you've finished it off so well.
Thanks for your advise on my cabinet it was very helpfull. Just one other question, what type of glass did you use to cover the monitor? I've heard people talk about something called greylight...
I can host your plans on our server at work if you wish.
hbm*rais
« Reply #37 on: June 19, 2006, 11:33:42 am »
Thank you Simon.
I used 6mm grey tinted glass. The kind you find in any glass shop. It works great for me. I also don't think safety glass is really necessary in this design.
I have heard of greylite, but don't anything about it. It's probably called differently around here.
Feel free to put the plans on your server.
I'm using SketchUp to produce some detailed 3D images of some parts of the project, I think it will make it easier to understand the plans. I'll send them your way if I think they turn out OK.
« Last Edit: June 19, 2006, 09:43:34 pm by hbm*rais »
holdennut
« Reply #38 on: June 19, 2006, 08:31:24 pm »
hbm&rais: I have hosted your Illustrator plans here:
http://users.on.net/~holdennut/lowboy2.zip
« Last Edit: August 07, 2006, 05:04:15 am by holdennut »
zzsprade
« Reply #39 on: June 22, 2006, 12:54:08 am »
Would it be possible for anyone to convert the plans hbm*rais has klindly put together into pdf or another format? Having some problems with illustrator.
-Alex
P.S. Thanks again hbm*rais
