Author Topic: controls.dat (control label info in mame)  (Read 16658 times)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« on: October 01, 2002, 07:52:25 pm »
I asked mame.net what they thought about adding a controls.dat to mame.  R.Belmont, as usual, is against the idea because it serves no purpose to mame.  Though I responded neither does hiscore, history, and cheats then :) (This is just a joke mamers, don't flame me)
Some people are interested in the idea.
I've been looking into how to add a dat file to mame.  I don;t think it is that hard.  Just will take time.
First, we need the controller info.  Like HC said, KLOV is 90% accurate.  We need people to start filling in a dat file then.  So this will have to be organized.  Any suggestions?
Here's a suggested idea for the controls.dat
[romname]
P1 BUTTON1=JUMP
P1 DOWN=CROUCH
[end]
The left side should be listed just as the ctrlr files list them.  Look at std.ini in /mame/ctrlr.
[end] really isn't needed, just makes coding it ALOT easier.  You will see ends in mameinfo.dat and history.dat.
So, what could we do with this then.  Well, we all know how cool it would be in an FE to actually display the controls.  (That has become a little harder if you want to accurately portray them with your CP if you use ctrlr files)
However, this also would be useful in mame.  In the Config Controls UI instead of saying "P1 BUTTON1" it would say "P1 JUMP".  It would make understanding the controls of a game much easier.
Also, for the majority of the clones andsuch, they use the same labels.  So we should focus on the parents first.
Now, I don't have the facilities to host something like this or organize it.  We might have to figure that out.  If you are interested, PM me, I'll get a group of us together in the chat room to talk about it.
BTW, I've been playing with the mame source code lately, HC, that -lisfe taught me abit on how dto do a project like this.  Maybe we can talk PJ into letting us have a forum for this at mame.tk or planetjay.com.
« Last Edit: October 01, 2002, 08:05:27 pm by SirPoonga »
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:controls.dat (control label info in mame)
« Reply #1 on: October 01, 2002, 09:28:46 pm »
All though it wasn't an orignal idea... *sniff* I'm so proud the thread I started kicked this off...
Anyways... if need be I can create a forum on randomdrivel's forum... or add a total separate forum in the same webspace...  or if it was an gpl type license of this dat file sourceforge supplies all the same stuff for "Free"
*Shrug*
let me know what's needed.
rampy
SirPoonga
  • Puck'em Up
« Reply #2 on: October 01, 2002, 09:32:38 pm »
This idea has been around long before you were a member here too.  But it was all talk, Action needs to take place.
The problem with CVS, one person would have to be in control of it.  You couldn;t just let a bunch of people directly edit a file.  Problems occur then.  Though it may not be a bad idea.  Like mame, as long as there was one person to approve of a change that person can then add it to the final source.
I'd also like to add, part of the process then would be people would submit controls along with proof that those controls are accurate.
knobunc
  • Last login:October 02, 2002, 09:08:57 am
« Reply #3 on: October 02, 2002, 09:20:13 am »
I have started on this process.  I have done 108 out of 477 driver files over the last week.  I can post my current work if anyone is interested (is there a way to attatch files using this forum or should I stick it on a web site)?
Below is a sample of the format that I am generating:
[atarigt.c:primrage]
URL: http://www.klov.com/P/Primal_Rage.html
MOVE_URL: http://db.gamefaqs.com/coinop/arcade/file/primal_rage.txt
GAMEFAQID: 3575
LAYOUT: 2
PLAYERS: 2
IPT_JOYSTICK: Movement 8-way
IPT_START1: High Quick
IPT_BUTTON1: High Fierce
IPT_BUTTON2: Low Quick
IPT_BUTTON3: Low Fierce
NOTES: Hidden bowling game (look at gamefaqs.com for info)
Each block starts with the driver filename and the input definition (there are sometimes the specific game names as a further qualifier if each game that uses the same input has different controls).
I have been putting the gamefaq IDs in and the KLOV url for the game so that a front end can provide links if wanted.  Some games have the MOVE_URL if they have complicated button combinations that can be used.  Finally you can say BASE: filename:inputdef to establish a parent/child relationship between the input defs (occasionally useful when there are multiple clones of a game that are in a driver file that has input definitions that are generic and each game has different behaviors).
Anyway, I plan to keep chugging on this and hope to have it done in a couple of weeks.  Then I plan to write another program to validate the klov urls (sometimes I biff them when going from gamefaq to klov to the file).  If people have ideas for a better format or other information that would be useful to capture.
-ben
SirPoonga
  • Puck'em Up
« Reply #4 on: October 02, 2002, 12:37:54 pm »
GAMEFAQID: 3575
LAYOUT: 2
PLAYERS: 2
Interesting.  A little too much info needed for a controls.dat for mame.  For a FE, that would be ok.
A couple things I don't like about the format.
[driver:romname]  - Uhg, makes it fun trying to find a specific game in  language that doesn't have regular expressions.
Button nameing, IPT_BUTTON1.  What's the IPT?  I think it should follow the names in the ctrlr std.ini file.  The reason being amme used that, so it is a simple if statement to replace the text in the UI.
What's "IPT_JOYSTICK: Movement 8-way"  IS that to just get the type of controls?  True, mames -listinfo isn't 100% accurate, but I wouldn't call it LPT_JOYSTICK then.
Players, not needed, neither is the driver, all can be gotten in mame.
The URLs are good for an FE, if it wants links, but for controls.dat that acts like hiscore.dat it is information not needed.  Though I can see adding it.
knobunc, I'm not against your efforts.  I do like the URL stuff and the stuff in it for FEs, that can be skipped over in mame but it also useful information.  I just look at the format as a programmer and go eeeek.
I don't understnd the BASE thing, show and example.
I would like to see what you have done.  My email is on my website, attach it.  You can not atach files here, just link to them.
knobunc
« Reply #5 on: October 02, 2002, 01:18:26 pm »
I figured that more information is better especially if it is easy to get now (whereas later it would suck to have to reget).  Haveing the IDs and URLs allows you to see the sources (besides the driver code and playing the games) that were used.
The format is a windows config file format.  I can easily rework it into a different form if needed (perl is good at that stuff).
The IPT_BUTTON1, etc. style comes from the input definitions in the drivers themselves.  They are the internal names mame uses (with some simplifications).  Again, they are easy to translate from if a different format is required.  I only put P1, P2 on them when the player controls are different for each player.  I do note how many sets of controls there are in the layouts (simultaneous players) and how many players can play total.
IPT_JOYSTICK: Movement 8-way indicates that the joystick for each player is a control for movement and allows you to move it in 8 directions.  I envision all of this being shown by a front-end (not necessarily mame) so it would signal to me that I need to make sure my controls are in 8-way position, not 4-way or 2-way.
As a note, the [atarigt.c:primrage] is the driver source file and the input definition, not the source file and driver name, there is an optional third item that allows you to specify a driver when multiple drivers use the same input.  Look at cave.c for instance.
I have mailed you the complete file as it stands now.  The links have not been validated yet and there are a bunch of notes to me where I need to complete the controls.
-ben
SirPoonga
  • Puck'em Up
« Reply #6 on: October 02, 2002, 01:49:12 pm »
Well, it looks like a controls.dat file will never be officially in mame.  Sigh, amazing wht the mame team allows and doesn;t allow into mame.
So most likely it will have to be an offshoot build.  This would probably be easier than other custom builds.  as this would really only affect the UI in mame and that rarely changes dramaticiclly enough that a build that supports controls.dat.
I'm looking into sourceforge.  I know HC, you don't like it, but it has its good points:)
I don't know who would be in charge, but I think you can setup sourceforge like this.
There would be a main build of mame that uses the controls.dat and the source.  That should only be updated by one person who can add final changes, like nicola with amme and torvalds with linux.  However there should be a few people that can add submissions to controls.dat to keep up with the initial demand.  The submissions would have to go through a process of verifying the controls are accurate.
SirPoonga
  • Puck'em Up
« Reply #7 on: October 02, 2002, 02:20:15 pm »
-ben
First, IPT_JOYSTICK.  That might better be named IPT_CONTROLS??  I could see since this controls.dat file will be used in mame and in FEs that having the CORRECT controls would be done here too.  I hate how dotron says trackball!!
Like I said, I am seeing who is all interested in contributing and getting a chat together.
The reason I suggest having that format I mentioned in the first post is that one, it can be parsed by any ini reader, the [end] will never be used and will not have any vars in it.  But for systems/languages that can;t use an ini reader and the dev has to make a parser the end makes it alot easier.  remember, this will have to be parsed in mame too for the control info.
Also I suggest the P1_BUTTON1 format because the ctrlr files use that and the code to parse is already in mame, copy and paste baby!
AND it's what shows up in the UI so a simple text replacement is easy to code.  With the IPT format there's alot of extra coding that really isn't needed then.  that's my reasoning.  Plus, just thought of this, for FE devs it's easier to.  Most likely if controls are going to be showed in an FE eache joy/button will have a value, like p1joy8way, p1button1.  So it will be really easy to map the controls.
Oh, there is a twist to this, especially with my ctrlr hacks.
I see an FE doing this.  Somehow someone can map out their control panel (like arcadefx util).  this would involve placing the default locations of buttons.  IE like on my panel the buttons are
456
123
But with my hacks for any 4 button game it it
XX4
123
and for 6 button games it is
123
456.
For mvsc its
123
4X5
This is all done in ctrlr files.  BUT if it was done in cfg files getting at the configs is near impossible:)  So, the FE would have to know about the ctrlr files (and/or the cfgs) to accurately dipaly the controls the user uses.  Then with controls.dat to accurately labels.  Which is pretty difiicult.  I think some sort of setup file is actually needed for the FE then, that would remap where P1_Button1 is according to the layout, number of buttons etc of the game.
That means what I said earlier is incorrect.  If we put the CORRECT controls in controls.dat (IE dotron will say it has a spinner and a joy with buttons) we will need the number of players, number of button from -listinfo.
knobunc
« Reply #8 on: October 02, 2002, 02:44:53 pm »
Since I am parsing the raw driver.c files I am effectively generating the same info as -listinfo, but mine happens to be more detailed about the specific control info.
I see that my .ini file format is bust, I should have =s rather than :s, but that can be fixed later.
The reason that I do not have 1 input definition per game is that that would generate a ton of definitions, this seems to cut it down by a quarter which makes maintenance a bit easier for the moment.  Internally mame knows which input definition it is dealing with (look at the code for -listinfo).   If needed we can expand the file out later, getting an input name to game name mapping is easy and then rewriting the definitions is easy too (but makes maintenance harder).
I am not sure waht you mean by renaming IPT_JOYSTICK to IPT_CONTROLS.  I would rather document the controls that mame has at the moment (and I plan to fix the controls if they are obviously bust in mame as doing this complete scan will turn up errors).
In the future I would love to add a more sophisticated controls mechanism to allow you to define your controller and have the controls be automapped to the mame ones in a more sophisticated manner so that if I have a spinner it will use that, if I don't I can choose to map it to buttons or a second joystick...  but that is a big task for the future.
So for dotron:
[mcr3.c:dotron]
URL: http://www.klov.com/D/Discs_Of_Tron.html
GAMEFAQID:
LAYOUT: 1
PLAYERS: 2
IPT_DIAL: Aim
IPT_TRACKBALL: Aim (Y) (hack)
IPT_BUTTON1: Fire
IPT_BUTTON2: Deflect
IPT_BUTTON3: Aim Down
IPT_BUTTON4: Aim Up
-ben
SirPoonga
  • Puck'em Up
« Reply #9 on: October 02, 2002, 03:01:02 pm »
Could you modify that to create a skeleton controls.dat file?  Like output the control info for each game, leave the right side of the = blank?
the driver file is nice for FEs, I added it to -listinfo for HC.  But it shouldn't be in the [] for ini files for FE use.  that way the FE just needs to use the romname as the key to the INI file parser.
1 input defination per game, when would you have more???
Also, technically mame doesn;t know the imput definition, it needs to be derived fromt he GameDriver object, hence that huge case statement:)
Ahhhh, I get it now, with one example I didn' understand what that was.
Shouldn;t it be IPT_JOYSTICK=JOY8WAY, what mame uses??  Or DOUBLEJOY8WAY, that use list of constants in that one source file....
Right, like that stuff I was talking about.  That can get very complicated, I have an idea to implement something like that, but it all depends on the final format of this project.
So for dotron:
[mcr3.c:dotron]
GAMEFAQID:
LAYOUT: 1
PLAYERS: 2
IPT_DIAL: Aim
IPT_BUTTON1: Fire
IPT_BUTTON4: Aim Up
Yeah, I can see how the IPT stuff is better inside of mame.  That;s why I need to get together people interested in this, and FE devs interested in this.  I see this being used more in FE than in mame, it;s just nice to add to mame, looks all pretty.  So it should be a format that makes life easier for the FE dev but still useful inside of mame.
SirPoonga
  • Puck'em Up
« Reply #10 on: October 02, 2002, 04:12:11 pm »
Well, and FE devs want to reply with what they'd like to see the format as?
knobunc
« Reply #11 on: October 02, 2002, 05:02:43 pm »
Sure, can you provide a snippet so I get an idea of what you want?
I think we both agree that the current format is not the final one.  Is a convenient format for the moment because each input definition requires quite a bit of hand editing.  I cna transform it later when I am done with the thing, and we come up with a good final format.
No. the other way around.  Some games share the same input definition.  Often these have the same control meanings so that it is easier for me to just do one input definition rather than duplicating it for all 3 games.  I can rewrite the file into a different format later.
Agreed.  Again it is way easier for me to do it this way.  This is not the final format and was never intended to be.
Nah..  the stuff to the right of the : is simply a text string that is intended to be displayed to the user as is.  I happen to try to keep the terminology consistent as much as possible.  I suppose I can add more fields that actually tell you what all of the attributes on the inputs are (toggle, 8-way, cheat, etc).
Cool.
Sure.  The IPT stuff is just a convenience for me at the moment.  I can transform that later, I hadn't realized that the ctrlr/std.ini had a different format.
Did you get the file I mailed to you with my current working copy?
-ben
« Reply #12 on: October 02, 2002, 06:39:25 pm »
Hows about this for eg:
tron
noplayers=2
nocontrollersets=1
description=8-Way Trigger-Stick & Spinner
controller1=joy8way
controller2=dial
JOYSTICK_UP=UP
JOYSTICK_DOWN=DOWN
JOYSTICK_LEFT=LEFT
JOYSTICK_RIGHT=RIGHT
DIAL=AIM LEFT
DIAL_EXT=AIM RIGHT
BUTTON1=FIRE
sf2
noplayers=2
nocontrollersets=2
description=8-Way Joystick
controller1=joy8way
JOYSTICK_UP=UP
JOYSTICK_DOWN=DOWN
JOYSTICK_LEFT=LEFT
BUTTON1=LIGHT PUNCH
BUTTON2=MEDIUM PUNCH
BUTTON3=FIERCE PUNCH
BUTTON4=LIGHT KICK
BUTTON5=MEDIUM KICK
BUTTON6=FIERCE KICK
Here's how it works:
noplayers: obvious
nocontrollersets: just means how many complete controllers there are - ie 1 for 2 player turn-based games, or 2 for 2 player simultaneous play etc).
description: this need only apply to games with wierd controllers, or controllers not catered for by MAME itself, eg '8-Way Rotary Joystick'.  It could be specified for ALL games tho (note my SF2 eg), for FE display purposes (?)  OR it could be used in similar format to MAME's: eg stick8way+dial ??
controller1,2 etc: this refers to how MAME handles the input for the game.  eg 'joy8way' AND 'dial' for say Ikari Warriors.
JOYSTICK_UP etc: this is the description for each input direction/button etc, in the ctrlr.ini format.  Note that P1_ would be used in front of these, and P2_, P3_ & P4_ if applicable (determined by noplayers).
Whaddya think?  :D
SirPoonga
  • Puck'em Up
« Reply #13 on: October 03, 2002, 01:00:49 am »
Minwah, very simular to my first.  Here' the problem I see with that format, games like firetruck that use different labels for 1 and 2 player, need to support that.
Plus, to be ini file compliant (vb, vcc, m$ have ini parsers, makes life easier) the romname would be in brackets.  Makes it easier to search for a rom then too:)
Otherwise yeah, including the actaul control info is needed.  This will most likely incluse something from everyone;s idea.
SirPoonga
  • Puck'em Up
« Reply #14 on: October 03, 2002, 01:07:33 am »
Well, you'd end up with a file with all the games in it, nothing on the right side fo the =.
Like
[mvsc]
BUTTON1=
BUTTON2=
etc, but in your format for now.  You say you get that info formt he driver.c so you'd end up with more correct controls for games like tron.
That's what I thought, like parent-clone information, for now unles the clone is undefined, it's use the parent's format.  Will save on work filling outall the data too.
-ben
Yeah, been busy today, haven;t looked at it yet, just file size, alot of work I see.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #15 on: October 03, 2002, 03:46:02 am »
I like the klov link...my fe can embed html pages in the info menus...a shame klov does not let you use their data straight then you would be able to make a custom look that fits with the fe skin. I love klov but think it looks ugly ;-)
Peter
« Reply #16 on: October 03, 2002, 09:49:46 am »
Yeah, you're right, I'd assumed that P1 & P2 controls are always the same  :-[
How about this:
[tron]
noplayers=2
nocontrollersets=1
P1description=8-Way Trigger-Stick & Spinner
controller1=joy8way
controller2=dial
P1_JOYSTICK_UP=UP
P1_JOYSTICK_DOWN=DOWN
P1_JOYSTICK_LEFT=LEFT
P1_JOYSTICK_RIGHT=RIGHT
P1_DIAL=AIM LEFT
P1_DIAL_EXT=AIM RIGHT
P1_BUTTON1=FIRE
[sf2]
noplayers=2
nocontrollersets=2
P1description=8-Way Joystick
P2description=8-Way Joystick
controller1=joy8way
P1_JOYSTICK_UP=UP
P1_BUTTON1=LIGHT PUNCH
P1_BUTTON2=MEDIUM PUNCH
P1_BUTTON3=FIERCE PUNCH
P1_BUTTON4=LIGHT KICK
P1_BUTTON5=MEDIUM KICK
P1_BUTTON6=FIERCE KICK
P2_JOYSTICK_UP=UP
P2_JOYSTICK_DOWN=DOWN
P2_JOYSTICK_LEFT=LEFT
P2_JOYSTICK_RIGHT=RIGHT
P2_BUTTON1=LIGHT PUNCH
P2_BUTTON2=MEDIUM PUNCH
P2_BUTTON3=FIERCE PUNCH
P2_BUTTON4=LIGHT KICK
P2_BUTTON5=MEDIUM KICK
P2_BUTTON6=FIERCE KICK
[firetrk]
noplayers=2
nocontrollersets=2
P1description=360deg Steering Wheel + Pedal + Buttons
P2description=360deg Steering Wheel + Button
controller1=dial
controller2=dial
P1_DIAL=STEER CAB LEFT
P1_DIAL_EXT=STEER CAB RIGHT
P1_PEDAL=ACCELERATE
P1_BUTTON2=HORN
P1_BUTTON3=TRACK SELECT
P2_DIAL=STEER TRAILER LEFT
P2_DIAL_EXT=STEER TRAILER RIGHT
P2_BUTTON1=BELL
OK so for games where P1 & P2 controls are the same (see sf2 above), there is a lot of stuff repeated (ie larger file size) - this just seemed the easiest way to me atm.
I'm not sure how MAME gets the descriptions 'Gas', 'Horn', 'Bell' & 'Track Select' in the tab menu (for Firetruck).  Could you enlighten me?
Also, I've never actually done any .ini file parsing - I realise this is the way to go, so I've added the brackets, and I'll do a little research on how to do it when I get a chance.
knobunc
« Reply #17 on: October 03, 2002, 09:55:19 am »
Good.  I hoped FEs would do that.  BTW the gamefaq ID is enough to make a URL from too...  Just replace the XXX in the following URL: http://www.gamefaqs.com/coinop/arcade/game/XXX.html
-ben
  • Last login:Today at 07:46:44 pm
« Reply #18 on: October 03, 2002, 10:20:57 am »
How about this:
[tron]
noplayers=2
nocontrollersets=1
controller1=joy8way
controller2=dial
P1_JOYSTICK_UP=UP
P1_DIAL=AIM LEFT
P1_BUTTON1=FIRE
[sf2]
noplayers=2
nocontrollersets=2
controller1=joy8way
P1_JOYSTICK_UP=UP
P2_JOYSTICK_UP=UP
[firetrk]
noplayers=2
nocontrollersets=2
controller1=dial
controller2=dial
P1_PEDAL=ACCELERATE
P1_BUTTON2=HORN
P2_BUTTON1=BELL
Minwah... as we discussed before simply putting joy8way won't work... we need to define each axis/input for a controller seperately.   So controller1, controller2 wouldn't work....
Also it would be a lot of repetition....
Firetruk would be a very special case so we would have to ignore it for now.   This is one of maybe 3 games out there that have this special case so I don't think it's worth worrying about just yet.
Probably what we will do is like the ctrlr .ini file and allow inputs like
p2xaxis=
when a game is two player simultaneous it only looks for player one by default and clones it....
but if player 2 is found it makes seperate inputs for each player.  That way typing can still be reduced. :)
knobunc
« Reply #19 on: October 03, 2002, 10:29:29 am »
Ugh.  The approach that I decided to take is if the controls are generic then I simply put the number of layouts in the file and the number of players total.  Then if the controls differ for some reason then I put a P1_ (or P2_ etc.) on the front.  There are also some controls where a single player's input spans multiple players in MAME due to limitations of the input system (e.g. cnemat.c's speedfrk).  In those cases I also prefix the controls with P1_, etc.
I am opposed to simply duplicating the control information because it makes the file huuuge and really hard to maintain.  However, I am not arguing my method is the best.  At the very least I should probably introduce more information about how the controls map to layouts to accomodate the three cases we have discussed (each layout is a duplicate of the others, different layouts for each player, one layout uses controls from multiple players).
It is possible to put an optional description in the input definition.  Very few drivers do this.  I am thinking about adding strings to most of them and submitting that as a patch.  However, I think putting the control type in the string is useful e.g. 'P1 - B1 -  Gas' otherwise it is difficult to tell at a glance what button the control is associated with.  Whereas when the descriptions are not present it is easy to tell what controls are in use but not what they do.
-ben
« Reply #20 on: October 03, 2002, 01:32:48 pm »
I think I was asleep during that part  :D
Seriously tho, I only just really started thinking about HOW it would work within our FE's...
Harder than it first seems
SirPoonga
  • Puck'em Up
« Reply #21 on: October 03, 2002, 01:42:52 pm »
I like Minwah's format.  It does define each axis/input seperately, AND you also need to know what type of control, like joy8way.
Just take out the controller1 and controller2 stuff.
I'd see soemthing like
[tron]
CONTROLS=DIAL|JOY8WAY
Then if the game had somethign like up was jump add
P1_UP=JUMP
« Reply #22 on: October 03, 2002, 02:18:43 pm »
I read that one post a little wrong... the controller type=joy8way would be ok, but I think that it would only be useful for reference and not using the dat file to display a layout. But since we also want to preseve the contoller information that should also be in there.
Btw I am almost finished with a skeleton dat file maker so no one has to bother with that... I only have to add the trackball and spinner generation and it's done. :)
SirPoonga
  • Puck'em Up
« Reply #23 on: October 03, 2002, 02:21:19 pm »
Ahhh, but it is useful information.  Especially if FEs are goin to start allowign a person to layout their CP in the FE.  If someone has a dedicated 4way...
Make the dat file thing accept a list of of drivers/games so whena  new version of mame is out you can just generate the new stuff.
« Last Edit: October 03, 2002, 02:22:35 pm by SirPoonga »
« Reply #24 on: October 03, 2002, 05:37:20 pm »
Well it's good for putting a caption on a graphic but that's about it.   I'll explain that one later, it's complicated.
Anyway... I've finished the app, which rihgt now simply takes one of my masterlist files and converts it.  I can eventually convert this again to parse directly form mame, but for now this is good. :)
I have a skeleton file ready that I will make available and link on this post.  It includes all working drivers from .61, even the ones that are commented out. ;)
Based on what we had talked about I added a few extra fields.  I added the game name for obvious reasons, and [end] bracket as we had discussed earlier, and a Misc entry for special case games that need an explaination about the controls.
« Reply #25 on: October 03, 2002, 05:52:14 pm »
Ok here it is....
http://www.oscarcontrols.com/lazarus/files/controls.zip
It's completely blank and ready for you to fill in...
Btw, I've also started work on a klov extractor but it needs some work.  So far I can extract button labels, the number of simultanious players and the controller type fairly well, but the problem is actually finding the name of the page for a given romname....
Klov doesn't use the revision names as does mame, so it's hard to extract data... I'm looking into a way of removing the revision information on the mame descriptions.  I will probably split at "(" and use the first field in the array as the url to search for.  any other ideas on this?
)p(
« Reply #26 on: October 03, 2002, 05:59:59 pm »
Ok here it is....
Mmm...I will look if I still have it somewhere but I actually had a conversion table for a lot of games made for a personal build of my fe that did retrieve the html page and converted it to something fitting the Emulaxian theme...
format was simple
romname|klov url|
Peter
SirPoonga
  • Puck'em Up
« Reply #27 on: October 03, 2002, 06:22:58 pm »
You;ll have to explain more then.  Cause I see it useful for mapping the FE to the controls.dat to the joy4way, joy8way, trackball, steering wheel, etc on the control panel.  Otherwise think about it, if a person has a dedicated 4way, how will you distinguish between the player 1 8way and the player 1 4way??
edit: after looking at your skeleton, I think we are tlaking about sperate things....
« Last Edit: October 03, 2002, 06:41:09 pm by SirPoonga »
SirPoonga
  • Puck'em Up
« Reply #28 on: October 03, 2002, 06:40:25 pm »
Ok here it is....
I took a look at it, cool, but issues.  As knobunc is doing he'd getting the controls out of the drivers, not mame.  That's why his dotron is a more correct.  I think a combo of the two will be needed.
A couple of issues I see with HC's format, but I like it.
First
[vsyard]
Description=10 Yard Fight (Vs. version 11/05/84)
numPlayers=2
alternating=
P1ControlType=8-way Joystick
P2ControlType=8-way Joystick
P1ControlType=4-way Joystick
P2ControlType=4-way Joystick
P1_JOYSTICK_UP=Up
P1_JOYSTICK_DOWN =Down
P1_JOYSTICK_LEFT =Left
P1_JOYSTICK_RIGHT =Right
P1_BUTTON_ 1=
P1_BUTTON_ 2=
MiscDetails=
[end]
So, what control type does it use??????
Yep, had to bring this up:)
[dotrone]
Description=Discs of Tron (Environmental)
numPlayers=3
alternating=
P1ControlType=Trackball
P2ControlType=Trackball
P1_TRACKBALL_Y=Up
P1_TRACKBALL_Y_EXT=Down
P1_TRACKBALL_X=Left
P1_TRACKBALL_X_EXT=Right
P1_BUTTON_ 1=
P1_BUTTON_ 2=
P1_BUTTON_ 3=
P1_BUTTON_ 4=
MiscDetails=
[end]
And finally there is really nothing correct in
[firetrk]
Description=Fire Truck
numPlayers=3
alternating=
P1_BUTTON_ 1=
P1_BUTTON_ 2=
P1_BUTTON_ 3=
MiscDetails=
[end]
I know I am bringing up the difficult ones, but I noticed with knobunc's it is much more correct.  It has to be a format that can support unique control interfaces, who knows what additional games are going to put in mame in the future anyway?
(what's upt with the '_ ' at the end of P1_BUTTON_ 1 =)
I do like the alternating idea, that;s a very good thing to know.
So, I suggest,, we list the requirements and uses people will get out of the controls.dat first.  Then from there start to decide a format that is best suited for those requirement.
What I can think of off the top of my head
Should use label type found in std.ini, will make it really easy inside of mame to replace labels in the config UI.  That I think is the only reason to have it in mame, unless someone else has a bright idea.
For the future (and now), the format will need to be flexible enough to handle odd controls.  this might me redundance like labels for P1_BUTTON1 and P2_BUTTON2 even though the label is the same.  Hey, these only have to be edittedonce, theoretically so I don;t think a copy and past would hurt:)  (I noticed HC you don;t incluse other player controls in your skeleton file, not flexible enough in my opinion)
What other info can FEs use?  I like the alternating HC put in, that means in an FE just one joystick can be highlighted and both player start buttons too to indicate 2 players.
KLOV link is interesting, some FEs will probably use that.
Has to be in ini format for windows dev, the [end] is nice for non-windows apps, makes it easier for manual parsing.
It will have to list multiple control types, like for dotron.  So something like P1CONTROLS=DIAL|JOY8WAY or for firetrk P1CONTROLS=DIAL  P2CONTROLS=DIAL and another line would say P1_PEDAL=ACCELERATE.  Unless one thinks PEDAL should be listed in the CONTROLS sting so FE's don;t have to look for P1_PEDAL, P2_PEDAL, etc....
Edit:
Oh, one might think,since DIAL can mean many things, in mame, like steering wheel, spinner, etc.  I don't think that belongs in this file, especially if the file is used to change the UI in mame.  Another file formatted somthing like
[romanme]
control=MAME_CONTROL
Description=description
[firetrk]
control=P1_DIAL
description=360 Wheel
That format will work for not just DIAL, obviously.  It's be a simple lookup then.
« Last Edit: October 03, 2002, 06:46:32 pm by SirPoonga »
SirPoonga
  • Puck'em Up
« Reply #29 on: October 03, 2002, 08:08:16 pm »
Ok, I started looking in mame on how the UI labels are displayed.  Here's what I got.
look in /src/inptport.h and .c
line 381 (of .61)
struct ik input_keywords[] =
Interesting struct.  The ik struct is just name, type, value.  Example:
   { "KEYCODE_A",               IKT_STD,      KEYCODE_A },
   { "KEYCODE_B",               IKT_STD,      KEYCODE_B },
   { "KEYCODE_C",               IKT_STD,      KEYCODE_C },
   { "P1_JOYSTICK_UP",         IKT_IPT,      IPF_PLAYER1 | IPT_JOYSTICK_UP },
   { "P1_JOYSTICK_DOWN",      IKT_IPT,      IPF_PLAYER1 | IPT_JOYSTICK_DOWN },
   { "P1_JOYSTICK_LEFT",      IKT_IPT,      IPF_PLAYER1 | IPT_JOYSTICK_LEFT },
   { "P1_JOYSTICK_RIGHT",      IKT_IPT,      IPF_PLAYER1 | IPT_JOYSTICK_RIGHT },
   { "P1_BUTTON1",            IKT_IPT,      IPF_PLAYER1 | IPT_BUTTON1 },
   { "P1_BUTTON2",            IKT_IPT,      IPF_PLAYER1 | IPT_BUTTON2 },
This struct is used witht he ctrlr files to match the name, then set the controls based on the value.  So in a ctrlr file you will see
P1_BUTTON1  "KEYCODE_A"
What the ctrlr parser will do is look at P1_BUTTON1.  It will see that in the srtuct is is of type IKT_IPT (input) and has the value of the TWO constants, IPF_PLAYER1 and IPT_BUTTON1 ORed together.
Note: that's how the driver defined controle, from topspeed driver
PORT_BIT( 0x80, IP_ACTIVE_HIGH, IPT_BUTTON1 | IPF_PLAYER1 )   /* main accel key */
OK, we know what control to set, now what to set it to.  that's the next value in the input, KEYCODE_A.  So, we look that up in the struct, It is has a name of "KEYCODE_A", type IPK_STD, value of KEYCODE_A (A constant holding some value).  Well, now we can assign the control to the constant:)
Now, you want to know why I bring this up?  If we want controls.dat to work in mame UI, It is alot easier to keep witht he ini file format if we use the name and not value.  (knobunc, this is why I wouldn;t use IPT_XXXX in the dat file).
If you use the IPT format in the dat file because then we probably would have to nest data, like:
[firetrk]
IPT_PLAYER1:
IPT_BUTTON1=Horn
IPT_PLAYER2:
IPT_BUTTON1=Bell
[end]
Ahh, that won't work with an ini parser:(
However this will
[firetrk]
P1_BUTTON1=Horn
P2_BUTTON2=Bell
[end]
Now, there is issues.  We know -listinfo lists "wrong" controls.
That is because in the driver they do this (dotron example)
   PORT_START   /* fake port to make aiming up & down easier */
   PORT_ANALOG( 0xff, 0x00, IPT_TRACKBALL_Y, 100, 10, 0, 0 )
But also in that driver we know dotron uses a dial and joystick
   PORT_START   /* IN1 */
   PORT_ANALOGX( 0xff, 0x00, IPT_DIAL | IPF_REVERSE, 50, 10, 0, 0, KEYCODE_Z, KEYCODE_X, 0, 0 )
   PORT_START   /* IN2 */
   PORT_BIT( 0x01, IP_ACTIVE_LOW, IPT_JOYSTICK_LEFT  | IPF_8WAY )
   PORT_BIT( 0x02, IP_ACTIVE_LOW, IPT_JOYSTICK_RIGHT | IPF_8WAY )
   PORT_BIT( 0x04, IP_ACTIVE_LOW, IPT_JOYSTICK_UP    | IPF_8WAY )
   PORT_BIT( 0x08, IP_ACTIVE_LOW, IPT_JOYSTICK_DOWN  | IPF_8WAY )
   PORT_BITX(0x10, IP_ACTIVE_LOW, IPT_BUTTON3, "Aim Down", IP_KEY_DEFAULT, IP_JOY_DEFAULT )
   PORT_BITX(0x20, IP_ACTIVE_LOW, IPT_BUTTON4, "Aim Up", IP_KEY_DEFAULT, IP_JOY_DEFAULT )
   PORT_BIT( 0x40, IP_ACTIVE_LOW, IPT_BUTTON2 )
so, if we can make a skeleton file that uses the info from the drivers, it's more correct, but still not 100%.  It will still take man power.
Oh, I think I could have mame itself output the skeleton file.  Kinda like -listinfo.  This might help out too, since, with the dotron and firetrk examples, some of the labels are already.
Actually, MAMe can store the labels!!!  That;s what PORT_BITX is.  It's an extended version of PORT_BIT.
Someone want to do an experiment for me., I'm a little busy right now with other tasks (this post took me forever to right)  Take a game where you know the control labels.  Replace PORT_BIT with PORT_BITX in the driver.
Like fine
INPUT_PORTS_START( ddragon )
Ok, this might be a bad example, but do this anyway.
You see in INPUT_PORTS_START(ddragon) there is
COMMON_INPUT_PORTS and
COMMON_PORT4
If you look just above you see that's where the buttons are defined for ddragon.  hehe, this won;t work well with the ddragon example since ddragon1 and 2 are slightly different labels.  Anyway, do this.  Replace
PORT_BIT( 0x10, IP_ACTIVE_LOW, IPT_BUTTON1 )
with
PORT_BITX( 0x10, IP_ACTIVE_LOW, IPT_BUTTON1, "Punch", IP_KEY_DEFAULT, IP_JOY_DEFAULT  )
compile, run ddragon.  See if in the UI it says Punch for button 1.  If so, hmmmm...  I'm not suggesting all the drivers need change, I doubt mamedevs will will allow that.  Just curious.
« Reply #30 on: October 03, 2002, 08:15:58 pm »
Actually my skelton file includes all of the std entries with the exception of vertical spinners and paddles.
The other things you saw were glitches in the program that i didn't catch simply because those few games you choose are so freakin wierd.  Btw those example would have to be entered manually anyway, so I don't see the big deal there.  There isn't any way you can get the information of those particular games automatically.
Remember sirp this is beta... I posted it so others could find glitches.  :)
SirPoonga
  • Puck'em Up
« Reply #31 on: October 03, 2002, 08:21:18 pm »
Actually, thinking about it, having labels in the MAME UI will make things confusing.  Though P1_BUTTON1 is easier to use in the ini file format:)
What do you guys think?  If you have the label, you don't know which button number in mame it is, SO it would be confusing to know exacly which button on your CP should be the "jump" button, etc...
Plus this really does have more of an advantage in FEs than in mame itself.
SirPoonga
  • Puck'em Up
« Reply #32 on: October 03, 2002, 08:26:39 pm »
And I pointed out the glitches:)  I know it isn't final!
yeah, there's alot that would have to be updated.
Hence there would have to be a process to update it.  Like a CVS type thing with submissions.  A couple of people in charge verify the submissions and add them to the master dat file.
« Reply #33 on: October 03, 2002, 08:32:21 pm »
Download the controller.zip again... i fixed the bugs in the parser and those games you mentioned are much more accurate now...
As for your above comment I have no clue where you are going.  The inital idea of this project was to make a file that a front-end or similar program could parse and display a control panel layout based upon it's findings.  Other than using the ctrlr files to get the actual keyboard keys assigned to said controls, I don't think mame has any relivance.  (Although it would be really nice to be able to get the data via parsing mame.)  Yes descriptions would be nice, but the user interface of mame would have to be reworked in order to make use of it in mame.  Think about it, anything longer than a few characters gets cut off in mame's ui.  And as you pointed out the only way to add these would be to also show the button number along with it's descripton, which would be way too long to display in mame.  I wish it could be done, but right now I don't think it can.
SirPoonga
  • Puck'em Up
« Reply #34 on: October 03, 2002, 08:35:27 pm »
HC is right, I went off in lala land there:)  To sum up, this looks like it will only be a FE thing, IMHO.  It isn;t that relevant in mame.
SirPoonga
  • Puck'em Up
« Reply #35 on: October 03, 2002, 09:06:31 pm »
HC has a cool idea of putting alternating in it.  That means the game alternates between players, and in most of those games in mame you use the same controls for player 1 and player 2.
I'll let him explain his idea on how the dat file should be formatted and the algorithm a FE would use to get at the info.
Here's my idea.  180 degree turn.  The labels will look like mame labels, but don't think of them that way, IF we believe this actually doesn;t have a usefulness in mame.  Labels would be too big for the UI.  These are descriptions for the FE, it will look like mame descriptions BECAUSE it is easy to get the control info from mame:)  But if you look at my firetrk example you will see it doesn't match what mame says it's controls are, more like what they are in real life.
First, examples to work with
[firetrk]
numPlayers=3
alternating=0
P1ControlType=Dial
P2ControlType=Dial
P1_DIAL=Left
P1_DIAL_EXT=Right
P1_BUTTON1=Horn
P1_BUTTON2=Track Select
P2_BUTTON1=Bell
START1=Player 1 Start
START2=Player 2 Start
START3=Both Start
MiscDetails=
[end]
[ddragonb]
Description=Double Dragon (bootleg)
numPlayers=2
alternating=0
P1_JOYSTICK_UP=Up
P1_JOYSTICK_DOWN=Down
P1_JOYSTICK_LEFT=Left
P1_JOYSTICK_RIGHT=Right
P1_BUTTON1=Punch
P1_BUTTON2=Jump
P1_BUTTON3=Kick
MiscDetails=
[end]
Ok, here's how it would be used (my idea) in an FE.
The FE will first look at the number of player.
If players > 1 then
Check for alternating
If alternating only label controller 1
if not alternating
get controls into some structure.
the structure will contain labels for all the CP objects.
So ther would be in that structure a P1_BUTTON1 and P2_BUTTON1.
now, in ddragon, no P2_BUTTON2 is defined.  So in the structure it will be left blank.  Now, when it comes time to display 2nd playe controls in the FE, since it is blank use P1 labels.
int he firetrk example P2_BUTTON1 is defined so that structure's P2_BUTTON1 value will be set, no need to us P1's label.
Final step, go throught he structure updating the labels the user sees in the GUI of the FE.
« Reply #36 on: October 03, 2002, 09:42:10 pm »
Ok my big fancy search routine, as requested. ;)
for each game you have soem supplimentary data that is used for outputting the display that looks something like this:
numPlayers=2
alternating=No
What this entry tells us is this....
There are two players and they both play at the same time.  Also they both use the same type of controller, so we can assume that the layout is mirrored for player 1 and 2.  Therefore we only have to define all of the inputs for player 1 and the fe will duplicate the same inputs for player 2
Now for those special case games in which player one doesn't have the same type of controller as player two, we ntoe that in the controller type and the fe knows to look for both players input definitions and NOT to mirror them.  This system should work with 95% of the games.  Also this controller type is useful for displaying graphics... in mame a steering wheel is the same as a dial, but obviously they look different.  If you have both a wheel and a spinner on your control panel it would be useful to know which one the game actually uses.  :)
And the inputs are just like mame, so remember how the graphics are linked to the outputted layout is irrelevant to our data collection.  If we can accutately document a good descripton of the controller and the actual input definition that mame uses, I can take care of the rest.  The viewer I make will be totally open source too, so it's logic can be integrated into front ends or used to develop fancier viewers.
SirPoonga
  • Puck'em Up
« Reply #37 on: October 03, 2002, 09:57:35 pm »
yah, my algorithm is VERY simular to HC's, the only difference really is dat file format.
i forgot to put my dotron example,
the thing I wanted to show in that example it the contorls.
My format would work for practically all of the games.  Try and find something it wouldn;t work wit, so we can tweak the format.
The format needs to be flexible, as we don't know what mame will have in the future.
That's why I think my way of overdising players > 1 labels is more flexible, it;s an override system, not a system based on just characteristics of the game.
What do others think?  Is there something HC and I overlooked?
[/qiote]
Right, but since eventually someone will use it to do jsut that, to me my way is easy (in my opinion).   Actually,  HC's idea is a subset of mine, you can still implement HC's idea with my style of formatting, putting the P2, P3, P4 labels in the dat.  HC's algorithm wouldn't look at that as much, but still could be done:)
Which brings up another point, it;s flexible enough to use different implementations.
BTW, I'm writing an ActiveX dll to handle the dirty work of parsing this.  It will work alot like the XML 4.0 stuff form M$.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #38 on: October 03, 2002, 11:04:45 pm »
Small, non normal questions:
What about mahjong games?
They don't use mame's BUTTON1...9 input types, but make their own custom inputs with no reference to a standard mame input (see the zero (0), below):
Code: [Select]
PORT_BITX( 0x02, IP_ACTIVE_LOW, 0, "P1 Kan", KEYCODE_LCONTROL, IP_JOY_NONE )
#define PORT_BITX(mask, default, type, name, key, joy)
Also, I don't understand the games with one real player, but use player 2 (and higher) inputs because of mame's limits.  Take Pole Position for instince: gas is P1_PEDAL and brake is P2_PEDAL and steering is P1_DIAL.  P2_DIAL is not used.  Will:
Code: [Select]
[polepos]
Description=Pole Position
numPlayers=2
alternating=no
P1ControlType=Dial
P2ControlType=Pedal
P1_DIAL=Left
P1_DIAL_EXT=Right
P1_PEDAL=Gas
P2_PEDAL=Brake
MiscDetails=Player 1 uses both pedals
[end]
be the way to do this?  (Should Pedal be added to P1ControlType?  Or should Pedal be removed from P2ControlType?)
Robin
Knowledge is Power
SirPoonga
  • Puck'em Up
« Reply #39 on: October 03, 2002, 11:21:01 pm »
Code: [Select]
No, don;t think in terms of mame labels, this is probably no longer for mame, just for FEs.  It uses mame labels because we can generate a skeleton easily form mame.
so for a majong you might have
[maj]
P1_BUTTON1=Kan
P1_Button23=Ugh
[end]
The user of the FE, if he has a majong panel defined, would know where to put those.
Code: [Select]
[polepos]
numPlayers=2
alternating=no
P1ControlType=Dial
P2ControlType=Pedal
P1_DIAL=Left
P1_DIAL_EXT=Right
P1_PEDAL=Gas
P2_PEDAL=Brake
[end]
That might be the way to do this, but like I said, since this is most likely no going to only be for FEs that can be defines like
P1_PEDAL1=Gas
P1_PEDAL2=Brake
Read up, I say why I think this won;t go in mame anymore, summary, label for the UI would get too long for mame.  essentially, there's more to it than that.
Could you give a full example of what would be in the dat file for a majong game?
See, there needs to be a standard punched out, for most games that's easy, but it also needs to handle interesting setups too, and future games.
« Last Edit: October 03, 2002, 11:23:17 pm by SirPoonga »
