Author Topic: *READ* FINALLY MY DREAMCAST WORKS ON MY ARCADE MONITOR!  (Read 13912 times)
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« on: December 09, 2004, 01:09:31 am »
Hey, I looking for someone who knows how to get the Dreamcast to display on my arcade monitor. I want someone who has done this before and has gotten the correct results. I will pay you to help me do this. Seriously. I'll pay really good money too. Check this out....
In my Mame Cabinet:
-WG 19'' inch arcade monitor (came out of an Arch Rivals cab)
-Arcadevga card with Ultimarc video amp
X-arcade stick...I gutted this beast and used the insides in my mame cab. (So I have a Dreamcast extention I would love to use!! ;D)
What I'm thinking is with the ultimarc video amp I could do this. Basically it seperates the R,G,B, Sync and Ground...for an easy install to the monitor. I've read that you can use the Dreamcast vga box to be converted to a 15hz video signal. So...Can I somehow use the video amp to help with this????? Someone help me or point me in the right direction or something. I'll pay someone some top $$$ to help me out with this. EMAIL ME AT ecousticforkris@insightbb.com
or just post on this topic. THANKS SO MUCH!!!
:D :D :D
-Ben
« Last Edit: December 23, 2004, 10:46:55 pm by stellarola »
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re: *READ* Get my Dreamcast to work on arcade monitor? I'll pay you! :D
« Reply #1 on: December 09, 2004, 03:28:39 am »
The instructions are posted in the Game Consles FAQ on this site:
http://arcadecontrols.com/arcade_consoles.shtml
Its pretty simple as you just open the VGA box and snip one wire...no soldering!
stellarola
« Reply #2 on: December 09, 2004, 10:56:24 am »
Dave would this work with the Ultimarc Video Amp???
stellarola
« Reply #3 on: December 09, 2004, 10:57:59 am »
Also Dave if this is the case..Can anyone out there sell me a hacked vga cable and a hacked vga box that I can use. Ill pay ya $$. :D :D :D
Dave_K.
    • Arcade Fever
« Reply #4 on: December 09, 2004, 04:55:46 pm »
The Ultimarc amp does not seperate RGBHV...its requires an RGBHV signal coming in and simply boosts on the other side.  From the pic it looks like a db15 vga extension cable.  Most arcade monitors use a 5 or 6 pin molex header.  So do you already have this cable hooked up to your monitor?
The DC hack should be compatible with this cable, as you get a 15khz rgb signal out the DB15 connector of the hacked VGA box.  But I've never had to use a video amp when hooking my hacked dc box up to a monitor before.  So I don't know if maybe the picture would be too bright or washed out with this cable.
« Last Edit: December 09, 2004, 04:59:12 pm by Dave_K. »
stellarola
« Reply #5 on: December 09, 2004, 09:32:31 pm »
Holy crap...I cant do this, wtf is wrong. AHHHH!! I give up. I will never get this dreamcast running on this arcade monitor. Thanks to everyone who looked at this topic. I give up. heh...  :-[
Dave_K.
    • Arcade Fever
« Reply #6 on: December 09, 2004, 11:46:17 pm »
Ben,  do you have a working Mame cabinet?  Is the monitor working with the ArcardeVGA and Ultimarc video amp cable?  If so, then hooking up a dreamcast to your monitor is a VERY simple operation.  Don't loose hope just yet.
stellarola
« Reply #7 on: December 10, 2004, 12:35:57 am »
Dave, my man. I've got the mame cabinet working fine with the Arcadevga and Videoamp. I connect a standard vga cable from the arcadevga to the videoamp, then the video amp to the r,g,b,ground and sync molex connectors...which go to the WG 19'' inch monitor. I just dont know what I'm messing up man. I seriously will pay you to make me a hacked vga cable and whatever I need to do this operation. Hope is almost lost, thanks in advance for the reply.
-Ben
Dave_K.
    • Arcade Fever
« Reply #8 on: December 10, 2004, 01:55:57 am »
Well the good news is you don't have to do any additional wiring.  So there is nothing to mess up.    All you'd be doing is unpluging the cable from your ArcadeVGA card, and pluging that into the hacked Dreamcast VGA box.  Thats it.
Now, hacking the VGA box is also very simple.   All you do is take out the screws, open it up, and snip 1 wire where the Dreamcast cable plugs into the circuit board.  To make it even easier for you, if you buy a Blaze DC VGA or Madness Gameware VGA box, I'll even tell you which wire to snip (since I have both of these model boxes and can confirm for you).  I just looked out on ebay and you are in luck as both are available (these are kinda rare nowadays).  So try and get one of these.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4303&item=8153240212&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41053&item=8152699448&rd=1
stellarola
« Reply #9 on: December 10, 2004, 12:21:30 pm »
Ok, i'll purchase one of these vga boxes. So even with the videoamp plugged in, I shouldnt have any problems?
Dave_K.
    • Arcade Fever
« Reply #10 on: December 10, 2004, 01:00:11 pm »
I think it should be just fine.  Your monitor may be one that requires the gain boost.  Basically, the output of the DC VGA box should be at the same levels as the ArcadeVGA card...so in theory it should be just fine.
stellarola
« Reply #11 on: December 10, 2004, 01:56:45 pm »
Dave...your my demi-god. Thanks a lot man.   :D
stellarola
« Reply #12 on: December 10, 2004, 01:59:29 pm »
Check this out...what I plan doing is buying a vga switch box and just being able to switch from the dreamcast to the pc on the fly. I actually bought a serial switch box on eBay so I could go from the X-arcade (pc) to the dreamcast extention. I can't wait to see how it turns out...hey wanna sell me one of your vga boxes??? :P
Dave_K.
    • Arcade Fever
« Reply #13 on: December 10, 2004, 09:36:40 pm »
Regarding the switchbox, sounds like a good plan.  I don't want to sell you one of mine because I need them both  ;D.  Trust me you will have it hacked inside 5 minutes, and be all that much happier you did it yourself.
stellarola
« Reply #14 on: December 10, 2004, 11:35:48 pm »
You think you could do me a favor and show me a picture of the arcade monitor playing the dreamcast. :D  THAT WOULD BE GREAT DAVE!! :D
Dave_K.
    • Arcade Fever
« Reply #15 on: December 11, 2004, 01:16:50 am »
I plan on finishing up my latest cab project this weekend and will take some pics and post in the project forum.
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #16 on: December 11, 2004, 11:21:21 am »
How is the picture quality on the Arcade monitor? I have a hacked DC in my cab, but I am using a TV and hooking it up through an S-Video Cable. I am thinking of making a new 2 player Fighting Cab, and this time I will go with an Arcade monitor if the results on the DC are good. I just LOVE Cap VS SNK 2 and SF3! Enough to make a dedicated cab for them.
Thanks in advanced, Fred.
Dave_K.
    • Arcade Fever
« Reply #17 on: December 11, 2004, 02:09:03 pm »
Going RGBHV direct to an arcade monitor is the best quality you can get.  The difference over s-video should be better color, resolution wise it should be similar.  If you buy a multisync monitor that can do 31.5khz as well as the standard 15.7khz, then you can make the dreamcast output rgbhv in high res and have the absolute best quality period.
stellarola
« Reply #18 on: December 11, 2004, 05:20:10 pm »
Hey Dave. How do you know this vga box will work with the videoamp? You said it doesnt seperate the rgbhv, right? I forget. Lemme know, thanks man!
Dave_K.
    • Arcade Fever
« Reply #19 on: December 11, 2004, 06:59:18 pm »
The Dreamcast VGA box outputs RGB natively through the 15pin port (just like the ArcadeVGA card for your pc).  Its already seperated at that point.  The video amp just boosts the gain on the RGB signal before it goes to the monitor.  Thats pretty much it.
stellarola
« Reply #20 on: December 11, 2004, 07:57:34 pm »
Dave the Demi-god. Thanks man ;)
Dave_K.
    • Arcade Fever
« Reply #21 on: December 13, 2004, 01:35:45 am »
Just posted pics of my latest cab running with a Dreamcast.
http://forum.arcadecontrols.com/index.php/topic,28845.0.html
I also notice you won the auction for the gameware madness VGA box...sweet.  Let me know when you get it and I'll tell you which wire to cut for 15khz.
« Last Edit: December 13, 2004, 01:44:39 am by Dave_K. »
stellarola
« Reply #22 on: December 13, 2004, 03:57:41 pm »
Dave are those pics in 15khz or 31khz? Thanks! :D
Dave_K.
    • Arcade Fever
« Reply #23 on: December 13, 2004, 04:20:26 pm »
Those are pics with the dreamcast running in hires (31khz).  I take a comparison pic at 15khz tonight and post it to that thread.
stellarola
« Reply #24 on: December 13, 2004, 04:52:41 pm »
Hey anyone know how to hack a vga cable? Im trying to figure out which color wire does what...
I have wires that range from.....
Brown, Yellow, Gray, Purple, Pink, White, Blue, Red, Green, Black, Orange, Black (with white line on it), Brown (with white line on it), very light Blue wire, and some exposed wire (I suppose its a ground wire???)
Dave_K.
    • Arcade Fever
« Reply #25 on: December 14, 2004, 12:58:34 am »
I tried taking comparison pictures of the dreamcast at 15khz and 31khz, and you can't really notice a difference with the camera.
Regarding the VGA cord, do you happen to have the end that you hacked off?  IF you still do, then you could look at the diagram of the pinouts and tell which color maps to which pin.  Otherwise you will have to use a multimeter on continuity test to see which wire maps to which pin.
stellarola
« Reply #26 on: December 14, 2004, 01:16:29 am »
how would i match the pins with the wires? I dont get that part.
Dave_K.
    • Arcade Fever
« Reply #27 on: December 14, 2004, 03:41:18 am »
Well I was assuming you still had the end you hacked off, and could just open that up to see which wires go to which holes/pins....and then use this picture to map that what each wire is. http://www.bbdsoft.com/video.html
stellarola
« Reply #28 on: December 14, 2004, 11:14:59 am »
I used a mulitimeter. Now...which ground wire do I want to use?
Dave_K.
    • Arcade Fever
« Reply #29 on: December 14, 2004, 11:40:31 am »
Use pin 10 (see the picture in the link above).
stellarola
« Reply #30 on: December 14, 2004, 06:14:40 pm »
Yo. I Hooked up the hacked vga cable to my monitor...I got like a sorta distorted srambled video....so in turn does that mean I need the video amp, or is this another problem?
Dave_K.
    • Arcade Fever
« Reply #31 on: December 14, 2004, 10:56:50 pm »
Are you using the arcadevga card? and is it in 15khz mode?  if you can still see a picture on a normal monitor, then you aren't putting it in the proper mode for arcade monitors.  Anyway, I thought you said you already had that part working!?  And were wondering how to hook up the Dreamcast?
stellarola
« Reply #32 on: December 14, 2004, 11:22:55 pm »
Yes I'm using the arcadevga card on my arcade monitor, it only works on it. It is in 15khz mode. Also when I looked at some of these pics of the vga pinouts...its like they were turned upside down or some crap.
Witchboard
« Reply #33 on: December 15, 2004, 10:10:17 am »
I noticed that the FAQ said that some games won't work with the VGA box.  Is there a list somewhere?
Oddfeld
  • Last login:October 26, 2024, 04:46:39 pm
  • I was Jeff Minter's llama!
« Reply #34 on: December 15, 2004, 12:21:05 pm »
You might like to go read this too:
http://www.mameworld.net/pc2jamma/arc_dc1.html
Dave_K.
    • Arcade Fever
« Reply #35 on: December 15, 2004, 01:23:25 pm »
I've never seen a list yet.  There are a lot of games that do not natively support the VGA box...but you can still get it to display on a VGA screen using a "swap" trick: turn on dreamcast with VGA box in TV mode, wait till you hear the short beep, then wait 1 second and flip it to PC mode, you will then see the Sega Logo on the PC monitor.
Witchboard
« Reply #36 on: December 15, 2004, 02:56:27 pm »
Nice link Oddfeld.  That sheds some light on some things.  Thanks for the trick Dave_K.
/threadjack
stellarola
« Reply #37 on: December 20, 2004, 02:22:52 pm »
Hey Dave, I got that vga box in the mail today...its the Transparent Orange one. Says "DC-VGA ADAPTER" on it. Which wire do I snip?
Dave_K.
    • Arcade Fever
« Reply #38 on: December 20, 2004, 07:52:57 pm »
Ok, this is exactly the same box I have.  So open the vga box by unscrewing the 4 screws on the back.   On the PCB will be one (or two) more screw that holds the other side on, so unscrew those as well.  You should now be able to seperate the case completely.  Looking at the PCB where the plug wires go into the board (its called "con16"), pin #1 is the yellow wire on the end.  You need to cut wire #6, which if you count from yellow, turns out to be the black wire.
I suggest making the cut in the middle of the black wire between where the wire comes out of the cable, to where it connects to the board.  The reason being, if you ever want to put this back into 31.khz mode, just open the box, and twist the two halves together.
Have fun!
« Last Edit: December 21, 2004, 04:57:39 am by Dave_K. »
stellarola
« Reply #39 on: December 22, 2004, 09:03:10 pm »
No, I didnt get any picture on my monitor. :(  The vga box I bought on ebay had problems with its vga, when I hooked it up to a standard pc monitor. So I dunno if thats the problem. I guess I have to buy another one...:(
