Author Topic: sanwa 5 wire stick layout/orientation question  (Read 1518 times)
gique
  • Last login:April 25, 2018, 10:07:51 pm
  • I <3 my egret
« on: December 07, 2004, 06:50:13 pm »
can anyone shed some light on the wiring layout on the SANWA 5 pin joysticks?
I just bought 2 and noticed the difference in the wiring layout in comparision to the 8 wire sticks I have right now...
I need to know which pins are what direction, and in what deirection I should have the stick oriented!
thanks!!!
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
Re: sanwa 5 wire stick layout/orientation question
« Reply #1 on: December 07, 2004, 07:32:36 pm »
My guess is Up/Down/Left/Right & Gnd.
Teamwork - A group of people running around doing what I say.
« Reply #2 on: December 07, 2004, 07:40:40 pm »
Do you have a pic?  I've never heard of a Sanwa 5 pin stick before - is it a digital stick?
gique
  • I <3 my egret
« Reply #3 on: December 07, 2004, 09:50:50 pm »
from himuragames
the thing is.. which way does it go? i mean which way is UP???
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #4 on: December 07, 2004, 10:04:50 pm »
The Black Wire is the Ground.  Just look at the circuit board and trace the line going from a pin to see which microswitch they go to. The lines on the circuit board are fairly big so this should be an easy task.  If you don't have the 5 pin connector that Himura sells then just solder your wires to the microswitches directly like you would on any other joystick.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #5 on: December 08, 2004, 12:10:36 am »
It doesn't matter which way you orient/mount the stick.  Just use a multimeter on continuity test to see which pin goes to which direction after you mount it and wire accordingly.
gique
  • I <3 my egret
« Reply #6 on: December 08, 2004, 12:54:15 am »
ahh ok.. I don't posess one of those ATM, I was hoping for a diagram or some info..
thanks anyways!!
