Author Topic: Syncrhonizing Audio on Two Recievers  (Read 3670 times)
TVNut
  • Last login:December 04, 2004, 09:31:06 am
« on: December 03, 2004, 01:26:43 pm »
I am looking for a solution and have searched high and low... maybe someone here can help.
I want to play the same audio simultaneously on both receivers.
Lilwolf
Re: Syncrhonizing Audio on Two Recievers
« Reply #1 on: December 03, 2004, 02:08:15 pm »
why not have the home theaters output plugged into the 'entire system' input?
But you should only have one item producing the music.  syncing other then that would be hard.
TVNut
« Reply #2 on: December 03, 2004, 02:17:20 pm »
I have thought of this. But, running line level outputs long distances is problematic. Not to mention pulling the cable. Leveraging my network seems easier. You may be right, this could be the only solution.
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #3 on: December 03, 2004, 02:48:21 pm »
Wouldn't you just need another NetGear MP101 receiver for your other sound system?
In this setup, your PC is the server.  So you don't need a separate "UPnP server".
*Edit*:  Okay, I've been to NetGear's website and see the MP101.  You wouldn't need another one of those, necessarily.  You would need a box similar to that, but one that just receives the signal from the network, not one that allows you to choose songs like the MP101.
I'll do some hunting...
« Last Edit: December 03, 2004, 02:52:22 pm by RacerX »
TVNut
« Reply #4 on: December 03, 2004, 03:05:18 pm »
Unfortunately not. The MP101 grabs and plays music tracks from the server. Two MP101s would work asynchronously (from the same PC Server). I need the Home Theater receiver to play and broadcast to the Living Room receiver so it can play the same music at the same time.
RacerX
« Reply #5 on: December 03, 2004, 03:55:06 pm »
Correct.  That's what I said in the second part of my post.  You need just a receiver for your other sound system.
*Edit*:  If you plug your output from your MP101 into this:
http://www.smarthome.com/7656.html
You should be able to accomplish what you want to do.
« Last Edit: December 03, 2004, 04:07:10 pm by RacerX »
