Author Topic: Mame cab... Question about Jamma  (Read 778 times)
mbmsog
  • Last login:September 22, 2006, 01:04:23 pm
« on: December 02, 2004, 05:19:09 pm »
Hey i've built a mame cab.  but would like to be able to hook up a jamma board to it... is this possible?
LsLSpamMatt
  • Last login:December 25, 2019, 09:45:46 pm
  • Yeah, I drink Diet Coke
Re: Mame cab... Question about Jamma
« Reply #1 on: December 02, 2004, 06:31:39 pm »
mbmsog,
I'm wondering the same thing, as I have a jamma board.
I think you can only do this if you have an Arcade monitor in your cab.
Someone will correct me if I'm wrong.
Matt
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
« Reply #2 on: December 02, 2004, 06:41:33 pm »
Yes, arcade games require arcade monitors.
You'll only be able to run a JAMMA board in your home built cabinet if you built your cabinet as a JAMMA cabinet, then installed a PC in there using something like a J-PAC.  Would require a standard resolution arcade monitor, proper arcade power supply and JAMMA spec'd wiring harness, first and foremost.
Short answer: if you built the cabinet yourself and you're having to ask this question, you can't run a JAMMA board in your cabinet.
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
