Author Topic: Mini Williams (non-rotating version)  (Read 3140 times)
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« on: November 29, 2004, 11:37:37 pm »
I finished this earlier this year but sold it.
« Last Edit: November 29, 2004, 11:53:36 pm by Nannuu »
Next I'll be on fries, and that's when the big money starts rolling in.
Nannuu
Re: Mini Williams (non-rotating version)
« Reply #1 on: November 29, 2004, 11:39:11 pm »
Front panel
Nannuu
« Reply #2 on: November 29, 2004, 11:40:33 pm »
Monitor and Bezel
Nannuu
« Reply #3 on: November 29, 2004, 11:41:25 pm »
Dark shot
Nannuu
« Reply #4 on: November 29, 2004, 11:43:28 pm »
Start and Exit graphics to match the marquee style
SaiNRuB
  • Last login:November 26, 2024, 07:30:53 pm
  • Pluck your magic twanger, Froggy!
« Reply #5 on: November 30, 2004, 12:24:01 am »
Nannuu Nannuu, that is awesome!!  ;D
Looks like it was alot of meticulous little attention to detail and it really shows. You da man!
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« Reply #6 on: November 30, 2004, 04:16:52 am »
The exit button looks although it might be easy to lean against which could be annoying if making a top score in a game   :o
I love the life I lead. I wish I could afford it.
Grasshopper
« Reply #7 on: November 30, 2004, 03:10:51 pm »
Very nice indeed.
mtalkington
  • Last login:May 31, 2010, 05:02:19 pm
« Reply #8 on: November 30, 2004, 06:29:39 pm »
OK, don't laugh, I have a really stupid question. When you put a graphic like that on the glass that covers the monitor, is the graphic actually:
A) sticking to the outside/front of the glass (in which case the sticky side is the back of the graphic)
B) sticking to the front of the plastic bezel (sticky side still on back of graphic)
or C) sticking to the back of the glass (sticky side on graphic front). Thank you!
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
« Reply #9 on: December 01, 2004, 07:51:09 am »
If I was to do that, I'd probably just have it printed on non-adhesive paper with it simply slotted in-between the bezel and glass.  As my glass/bezel are on an angle, I can't see that it moving/slipping about
« Last Edit: December 01, 2004, 07:52:59 am by ras2a »
fredster
  • It's all good!
« Reply #10 on: December 01, 2004, 01:21:07 pm »
If you don't mind me asking, How much did you get out if it?
Nannuu
« Reply #11 on: December 01, 2004, 01:37:36 pm »
Craig:
Yep, I could see that happening for some kids.  If you're an adult sitting down and playing it probably wouldn't.
mtalkington:
Uh D.  The print is glued to black posterboard and laminated.  Which is sandwiched between the lexan and monitor structure.  It also lays on the monitor glass toward the center.
