Author Topic: ipac wiring  (Read 1429 times)
nels
  • Last login:October 20, 2021, 06:09:59 pm
ipac wiring
« on: November 29, 2004, 09:05:11 pm »
i wired my boards up but cant access the 2nd player mode even though the buttons are registering during testing.ive got seven player
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
Re: ipac wiring
« Reply #1 on: November 29, 2004, 09:41:18 pm »
First off, welcome to the board. You're at the right spot to get the answers you need to your questions. Here is a picture of how I wired the control panel to the IPAC.
http://www.garry.ca/images/Day18_CP_Layout1.JPG
Green = Ground
White = Joy Stick
Red = Buttons
I grounded P1 and P2 loops separately. Easier to debug.
I'm sure there are plenty of other examples in the Examples section on the left hand side of the message board for you to look at.
I'm not sure what you mean by "can't access the 2nd player mode" though. Does this mean P1 buttons are working and not P2? Some or none of P2 buttons are working? How did you test the connection? If you open Notepad, press the buttons and see what Notepad shows. Could be a configuration problem with MAME/ the game. Please post a little more information so we can help you better. A picture would be best. Worst case, there *may* be a problem with the IPAC, in which case, Andy W, the owner of Ultimarc will come along shortly I'm sure.
BTW: The search function on the top is an excellent way of getting more answers to your questions without waiting for feedback. There is a wealth of information contained in the posts of people who had similar problems as yours. Search for the word IPAC.
« Last Edit: November 29, 2004, 09:55:15 pm by Jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
rsoandrew
  • Last login:February 24, 2018, 09:02:10 am
  • Worldwide travelling Mame Machine
    • Andrew's Arcade
Re: ipac wiring
« Reply #2 on: November 30, 2004, 01:00:19 am »
Also don't forget that in many older games there was one set of controls and the players alternated. Only the player one controls are used.
You could configure the game in mame to use both but they would both be active all the time.
