Author Topic: Track and Field Wico Trackball to PS2 mouse hack?  (Read 4828 times)
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
« on: September 27, 2002, 11:49:33 am »
Does anyone know how to correctly wire an old "Track and Field" Trackball up to a PS2 mouse?  The trackball says its by Wico.  I've read several topics, but everyone seems to be using Happs trackball optics (expensive!).  I figured out the PS2 mouse from reading up, but I don't know where to connect the wires to the pins on the trackball optics.
I know there is a 5v, ground (both y-axis and x-axis have one each which are eventually connected), 2 signals for the x-axis, and 2 for the y coming from the trackball.  Is there a diagram out there somewhere to show how to wire these to a PS2 mouse hack? ???
(By the way, I'm new to making controls, and BYOAC has been an EXCELLENT ;D resource!!!  I built my own control pannel-2 ball-head joysticks, 6 buttons each side, player 1 and 2 start.  Coin 1 and 2 are set up like a pinball style on the sides.  I'm using an I-PAC usb interface.  My uncle gave me a Track and Field control panel, and I'd like to hook up the trackball to my panel!)
Any help would be great!!  Thanks in advance!!
...they only live twice!...
(>")>----MAME----<("<)
BobA
  • What Me Worry?
Re:Track and Field Wico Trackball to PS2 mouse hack?
« Reply #1 on: September 27, 2002, 05:17:33 pm »
Here is info on my Wico trackball to ps2 mouse hack.
http://www.members.shaw.ca/bakaye/tballhack.htm
Hope that helps.
BobA
MrBond
« Reply #2 on: September 27, 2002, 06:22:41 pm »
Thanks a bunch Bob, your write up really helps.  I still have two questions though.
1) How do I find out where to connect the +5v and Gnd wires to the mouse circuit board?  (is it directly where the ps2 wires connect to the mouse?: there are four wires there)
2) Do I hook both red wires to the +5v and both black wires to the gnd?
By the way, my wires are Blue, Purple, Green, and Yellow.  I'm assuming my purp is your brown.
« Last Edit: September 27, 2002, 08:57:10 pm by MrBond »
BobA
  • What Me Worry?
« Reply #3 on: September 27, 2002, 11:15:50 pm »
The PS/2 mouse connector has the following pinout when looking at the connector on the back of the computer:
6 Pin PS2
1   DATA
2   No connection
3   GND
4   +5V
5   CLK
6   No connection
The PS2 on the computer is numbered as follows:
     6   5
    4     3
      2 1
When looking at the connector on the mouse it
is nmbered as follows:
     5   6
   3        4
      1  2
I just followed the lines from the connector back to the mouse to establish the +5V and GND
I connected the +5 and GND of both optical boards to the +5V and GND of the mouse.   I checked this with a Volt meter to make sure.
BobA
MrBond
« Reply #4 on: September 28, 2002, 09:16:12 am »
Thanks BobA!  That's exactly what I needed!  :)  I'll give it a try as soon as I get some solder.
MrBond
« Reply #5 on: September 28, 2002, 10:31:48 pm »
Just wanted to say I got my trackball hack working! ;D  It is a little slow in windows, but I can jack up the sensitivity.  Marble Madness, Centipede and Missile Command all played great when I turned up the sensitivity.
1 question:
Is there any way to set the analog sensitivity for all the trackball games at once, or do I have to set them one by one (what I did for the games listed above)?
Thanks again!  :)
BobA
  • What Me Worry?
« Reply #6 on: September 28, 2002, 11:10:22 pm »
Glad to hear that you got it working.
Under Windows you can increase the speed of your pointer under Mouse in the control panel.  I am not sure how this will affect your overall performance if you are using a windows based MAME or how it interacts with the individual game sensitivity settings.
BobA
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: September 30, 2002, 05:30:51 am »
1 question:
No.  :(
Well, I guess you can edit each game's driver in mame source and recompile, but mame is not designed to set global analog settings. :-\
Robin
Knowledge is Power
