Author Topic: Getting Colour Problems  (Read 2482 times)
Led Zeppelin Rock
  • Last login:January 07, 2005, 04:59:10 am
« on: September 26, 2002, 08:21:51 am »
Hi
I was using ADVV for AdvMame and I noticed that the colours on the Arcade Monitor has gone funny, ADVV normally shows up red but it is more of a dull green now, also white is like a murky green/grey. I am using AdvMame through a J-Pac so I will re-connect everything, but if that does not work, what is likley to be the problem, and how hard would it be to fix???
Thanks, Simon
StephenH
Re:Getting Colour Problems
« Reply #1 on: October 20, 2002, 11:48:12 pm »
Check your wiring.   You may have one or more colors swapped.
Also, if the monitor is from an older Nintendo arcade unit, you may need a video inverter.   Nintendo used Negative Logic Video in their VS Series, and Playchoice-10 systems.     All the arcade companies used positive logic video.
Also, try a different game, or a real board.   If it does the same thing, it may be a bad monitor circuit.
Hi
Thanks, Simon
