Author Topic: New Product: Versa-Ball Joystick Replacement Shafts  (Read 39405 times)
whammoed
  • Last login:December 18, 2025, 10:30:53 am
  • Crack don't smoke itself
    • NiceMite
Re: New Product: Versa-Ball Joystick Replacement Shafts
« Reply #80 on: February 18, 2005, 10:00:04 pm »
But I was curious as to the plastic spacer.
quarterback
« Reply #81 on: February 19, 2005, 02:29:40 am »
OK, heres the news on the versaball and Ms Pac base:
Is this the 1 3/8" dark red shiny Versa-Ball?
Also, it looks like there a ridge around the 'equator' of this ball top.  Is there?  Can you feel it?
« Last Edit: February 19, 2005, 02:34:07 am by quarterback »
-- Chad Tower
whammoed
    • NiceMite
« Reply #82 on: February 19, 2005, 05:48:45 pm »
spidermonkey
  • Bombjack junkie
« Reply #83 on: February 19, 2005, 09:41:51 pm »
I've made extra grooves by putting the joystick shaft into a drill chuck just as you would a bit. I then *carefully* clamp the drill down in a vise. I then engage the trigger lock so that the drill stays running. I then make a mark where I want my groove and take a fine tooth hacksaw just hold it down on my mark and let the drill do the work for me. Keep trying the e-clip several times during the process so that you don't cut any deeper then necessary. Lastly I take a fine piece of emery cloth and buff off the burrs while its still spinning in the drill. Thats it.
"Sinistar has bad breath"
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #84 on: February 19, 2005, 09:51:55 pm »
Original Ms. Pacman / Galaga reunion stick.
Old and new handle pic.
JODY
« Reply #85 on: February 19, 2005, 09:55:06 pm »
Stick with new handle.
Pic showing how noticeable the new e ring is with the original dust washer.
I'll get new dust washers (Randy T sells them) or put the original black e ring on.  As noted in other threads, the dust washer for these sticks have a hole that is too big.  The new shiny e ring is very obvious with the big hole.
« Last Edit: February 19, 2005, 09:56:39 pm by JODY »
quarterback
« Reply #86 on: February 19, 2005, 10:27:22 pm »
Looks sweet.  Are you diggin' the translucent balltop, JODY?
-- Chad Tower
JODY
« Reply #87 on: February 19, 2005, 10:30:19 pm »
Yeah, they are nice.  Got one red and one blue.  My kids think they are very cool.
SaiNRuB
  • Last login:November 26, 2024, 07:30:53 pm
  • Pluck your magic twanger, Froggy!
« Reply #88 on: February 19, 2005, 11:08:17 pm »
Oh wow Jody that looks awesome, I could really go for a Charms POP right now :)
juggle50
  • Last login:July 18, 2024, 07:25:48 am
  • Your either on the bus or off the bus
« Reply #89 on: February 21, 2005, 05:10:10 pm »
Are the actuall ball tops interchangable on the versa and reunion?
whammoed
    • NiceMite
« Reply #90 on: February 21, 2005, 05:17:32 pm »
Nope, tried.  Thread size is different.  Versa is 3/8" and Ms Pac is 5/16".
jmelan
  • Last login:May 23, 2025, 12:54:10 am
« Reply #91 on: February 22, 2005, 01:41:46 pm »
for anyone who has already purchased one of these:
how is the gameplay on the Ms. Pacman / Galaga reunion stick with the new handle?
I would like to purchase one of these to enable me to mount the joystick under a wood panel, but I am worried that these replacement handles may add an unnecessary amount of height (1.5 inches added height versus the .75 inches normally added by a wooden CP plus plexi)
JODY
« Reply #92 on: February 22, 2005, 07:04:20 pm »
« Last Edit: February 22, 2005, 10:21:14 pm by JODY »
JODY
« Reply #93 on: February 22, 2005, 07:19:06 pm »
Just did another measurement in relation to my Happ competition sticks.  The height of the reunion stick with the new handle is exactly the height of the competition sticks.  I was surprised...it looks taller...but the ball on top makes it appear top heavy.
spllbnd2
  • Last login:July 05, 2025, 08:17:32 pm
« Reply #94 on: March 04, 2005, 11:20:28 pm »
Randy T
 Curious if these will work with the p360's. I thought I'd seen where you were going to test fit them on a p360. Any word as of yet?
Life is short... Play Pinball
JODY
« Reply #95 on: March 04, 2005, 11:26:53 pm »
I've got one I can check.  My understanding though is that the P360 uses Wico size handles and they won't work.  I'll double check.
JODY
« Reply #96 on: March 05, 2005, 02:06:15 pm »
Randy T
« Last Edit: March 05, 2005, 10:52:15 pm by JODY »
JODY
« Reply #97 on: March 05, 2005, 02:16:38 pm »
BTW - Just thought I'd mention that every time I pull out another type stick and compare the parts that came with it to what Randy's product comes with there is a big difference.  His parts really are industrial duty.
spllbnd2
« Reply #98 on: March 05, 2005, 06:52:25 pm »
Thanks Jody for the confirmation that these will not work. I would have hated to buy them to find out they don't.
evlbeaver
  • Last login:February 13, 2011, 10:42:53 pm
« Reply #99 on: March 06, 2005, 09:03:14 pm »
RandyT,
Can you just order the ball tops?  My bright red's came yesterday and I dont really care for the size of the ball.  They are a bit smaller than those in my Wicos.
