Author Topic: ROTOTRON 7-sided dual rotating CP cabaret -- VIDEO Added  (Read 8778 times)
rdagger
« on: November 19, 2004, 01:54:14 pm »
Please check out my first cab:
http://rototron.info
If that link doesn't work try this one:
http://www.rototron.info
« Last Edit: September 02, 2006, 01:15:54 pm by rdagger »
mpm32
  • Cheesecake Master
  • Last login:November 20, 2018, 09:25:14 pm
Re:ROTOTRON 7-sided dual rotating CP cabaret
« Reply #1 on: November 19, 2004, 02:16:26 pm »
Nice, new rotation concept.
Flat screen?
« Reply #2 on: November 19, 2004, 02:18:50 pm »
Funky.  You could use some more explanation on the rotation of the panels, took me a few minutes from the pics to figure out what is going on there with the removable panel pieces.
Star Wars vector on an LCD makes Baby Jesus cry.
Will
  • Last login:April 08, 2012, 03:32:27 am
  • Finished Lurking.....
« Reply #3 on: November 19, 2004, 02:24:04 pm »
When I look at your cab I keep waiting for it to transform into Optimus Prime ;DNice work and I like your p360 to tron hack.
rdagger
« Reply #4 on: November 19, 2004, 02:27:19 pm »
Click on the Rotating Panels link under Projects.  There are some good shots of the rotation (also under Artwork there is a link to a vector CP demo).  I'll try to take some better photos.
The monitor is a 17.5" LCD and the vector games look great.
« Last Edit: November 19, 2004, 05:07:46 pm by rdagger »
unclet
« Reply #5 on: November 19, 2004, 02:29:13 pm »
Yes, I could not agree more ...... please please add pictures of the rotation in progress.   I am assuming the side pieces come up as well for rotation but would love to see it in action.    Do the side pieces fold up or do they have to be removed in order to rotate.
Also, how do you lock down the controls once you rotated to a set of controls you want to use.
Also also .... how do you stop rotating so the wires do not get completed twisted ......
great work by the way !
« Last Edit: November 19, 2004, 02:30:09 pm by unclet »
« Reply #6 on: November 19, 2004, 02:35:35 pm »
Ooh, that's pretty much what I was looking for and how I'd concluded it works.  Nice stuff.  What's going to happen when one of those controls eventually fails, though?  All that stuff crammed into that tiny triangle could be a BIIIIITCH to work on.
rdagger
« Reply #7 on: November 19, 2004, 02:38:18 pm »
The side pieces swing up on on concealed Soss hinges.
The weight of the lowered side panels keeps the square and tri-panel tightly in place.
In terms of wiring:
The square panel is fed with a single CAT5 wire that wraps around the axel out the back.  It only allows enough slack to make a complete rotation.
The tri-panel is fed with 2 USB cables sheathed in hard plastic wrap.  The tri-panel is centered on the yoke and can only rotate 1  position to each side.
« Last Edit: November 21, 2004, 01:43:02 pm by rdagger »
rdagger
« Reply #8 on: November 19, 2004, 02:42:37 pm »
The panels can be removed, but you're right the tight fit makes repairs challenging.
« Last Edit: November 19, 2004, 06:12:40 pm by rdagger »
unclet
« Reply #9 on: November 19, 2004, 02:46:58 pm »
I looked into your Dual Strike photos and explanation of the mappings.    I am not sure if this matches with my mappings.   You might want to check out my site and see how I wired up to all the buttons and Dpad directions.
Not quite sure I agree with how you should wire the Dual Strike to get X and Y and other buttons... but it may be that I just misunderstood your mapping explanation.
Anyway, check out how I wired my Dual Strikes...
http://unclet.arcadecontrols.com/MomsArcade/MomsArcadeDualStrikePics.html
Also, how many Dual Strikes hack did you do?    I did seven for my 6 rotating panel driving cabinet.
http://unclet.arcadecontrols.com/MomsArcade/MomsArcadeMain.html
« Last Edit: November 19, 2004, 02:48:41 pm by unclet »
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #10 on: November 19, 2004, 02:47:18 pm »
You just gotta love that name and marquee!
Awesome cab!
Dare I say that 1up has been... one upped???  :o
« Last Edit: November 23, 2004, 02:10:51 pm by Gunstar Hero »
rdagger
« Reply #11 on: November 19, 2004, 02:56:37 pm »
My mappings are different from yours, but they work very well.  I tried to set up the matrix with the least amount of wires.  I am using 1N4148 diodes to prevent masking.
I have 2 Dual Strike hacks.  1 for the yoke and top fires and 1 for the gas & brake pedals.
« Last Edit: November 19, 2004, 03:50:03 pm by rdagger »
fredster
  • It's all good!
« Reply #12 on: November 19, 2004, 03:49:31 pm »
Slick, very slick
unclet
« Reply #13 on: November 19, 2004, 03:57:34 pm »
BTW:   I nominated you for a Mamey!
Witchboard
« Reply #14 on: November 19, 2004, 06:30:58 pm »
Can't access the page.  You use all your bandwidth already?  ;)
rdagger
« Reply #15 on: November 19, 2004, 06:48:24 pm »
My domain is hosted by GoDaddy.com for $1.95 per year.  I guess you get what you pay for.
« Last Edit: September 02, 2006, 01:16:30 pm by rdagger »
Witchboard
« Reply #16 on: November 19, 2004, 07:43:51 pm »
That fixed it.  Niiiice.  Thats a new "spin" on the rotating control panel. <ducks incoming objects for bad joke>
tbombaci
  • Last login:October 31, 2024, 01:32:56 pm
« Reply #17 on: November 19, 2004, 08:04:20 pm »
That is sick!
Nice job!
-Tom
brihoo2k
  • Last login:April 23, 2005, 08:40:31 pm
  • zzzzzzzzzzzzzz
« Reply #18 on: November 19, 2004, 10:39:30 pm »
Excellent job. Probably the best control panel I've seen so far. Your site really makes me think. I never thought how simple it would be to program an avr but you site shows probably the simplest programmer I've seen. Very nice job on the cabinet too.
Is the voice in my head bothering you?
Matt, GoC
  • Last login:August 18, 2005, 02:00:07 am
  • Must... stop... itching!!!
    • GameOn!
« Reply #19 on: November 20, 2004, 12:32:35 am »
Twitch...
Twitch...
Sweetness!
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #20 on: November 20, 2004, 02:42:30 pm »
The cab looks awsome man! Would you be willing to share some schematics and the code for that RGB light board?
rdagger
« Reply #21 on: November 20, 2004, 04:06:19 pm »
I added schematics and I will post the code soon.
DaemonCollector
« Reply #22 on: November 20, 2004, 06:36:19 pm »
Thank you much man, using that for trackball lighting will be sweet. :) You wouldn't happen to have another one of those chips on hand would you?
Also, I just looked at the schematic and could see what everything did besides the .01 cap? It appears to be wired in parralel to the main circuit, what purpose does it serve? Please pardon if this is a stupid question, I only have a basic working knowledge of electronics.
« Last Edit: November 20, 2004, 06:40:36 pm by DaemonCollector »
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« Reply #23 on: November 20, 2004, 06:40:57 pm »
Just fantastic.  Mamey.  Hall of Fame.  Down in History.  Awesome.
rdagger
« Reply #24 on: November 20, 2004, 08:26:29 pm »
Sorry, I don't have any extra AVR's.  I'm using the Atmel AT90S2313 chips which I bought on Ebay for $2.70. These chips are almost always available on Ebay.  Also check Froogle  because the chips are often sold new for under $4.  Despite the confusing documentation, these chips are very easy to work with.
The cap is connected in parallel to the power.  This is a common application to smooth and filter.  Feel free to IM me if you have questions.
Patent Doc
  • Last login:March 25, 2021, 12:07:33 pm
  • My wife says I'm the fastest man alive :(
« Reply #25 on: November 20, 2004, 10:22:36 pm »
 :o  That is simply the most amazing rotating panel i have seen.  I love how you solved the problems of layouts and artwork.  I agree this needs to go into the HoF.  That cabinet is awesome.
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #26 on: November 20, 2004, 10:31:58 pm »
Just when I think I have seen it all, one of you guys goes and does something else that makes my chin hit the floor.  Amazing!   :o
pocketbikez
  • Last login:January 16, 2005, 06:23:36 pm
  • INSERT COINS
    • my arcade cabinets
« Reply #27 on: November 20, 2004, 10:52:29 pm »
ill admit im not a big fan of rotating inspector gadget control panels but this is the best looking one so far. im amazed that you could even think up the design and make it come together so nice. the only way someone could top this is to make a 6 sided 9 pod rubiks cube cab  ;D
Matt, GoC
    • GameOn!
« Reply #28 on: November 20, 2004, 11:23:47 pm »
Ya, like anyone could get the controls they want without being a puzzle genius.  The only way I can solve one of those bad boys is to take all the stickers off and re-arrange them.
Zakk
  • Last login:March 04, 2026, 08:31:59 pm
« Reply #29 on: November 21, 2004, 12:50:21 pm »
MAMEY!
Got the last e-mail back today, it was a unanimous vote.  I asked which category it should go in, and we all agreed that since it has good artwork, design, contraptions and whatnot, it goes in the "everything else" category.  Congrats!
http://www.mameworld.net/massive/Awards/Misc/misc.html
menace
Re: ROTOTRON 7-sided dual rotating CP cabaret
« Reply #30 on: November 23, 2004, 12:59:49 pm »
So where can I get 3' x 5' glossy poster prints of that uber-sexy cab to replace the natalie portman posters hmm?  absolutely beautiful work there man--good job! and rotating movies are a must on your site--bandwidth be damned ! ;D
« Reply #31 on: November 24, 2004, 06:02:50 am »
Awesome cabinet, well done :)
I am also a little surprised by your monitor choice, but then I am just an LCD-hater  ::)
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #32 on: November 24, 2004, 01:01:54 pm »
rdagger
« Reply #33 on: November 24, 2004, 02:29:00 pm »
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #34 on: November 24, 2004, 05:05:06 pm »
Holy C :-[ :-[P!....that's amazing!...do you work for NASA? ....
this cab makes the MameMaster feel so small....sigh.....I must go back to the lab!......maybe I can have mine shoot laser beams!....yeah, that's it, Lasers!!! (insert creepy manic scientist laugh here).
Seriously...very very cool. Amazing all around. I wish I had the brains/ability to do something that slick.
Enjoy your amazing cab!
MameMaster!  8)
danny_galaga
  • Last login:Yesterday at 08:10:56 pm
    • dans cocktail lounge
« Reply #35 on: November 27, 2004, 01:27:19 am »
danny_galaga
« Reply #36 on: November 27, 2004, 01:31:01 am »
had to look at the pics twice to see that the side panels hinge up. this is exquisite work
« Last Edit: November 27, 2004, 01:35:18 am by danny_galaga »
rdagger
Re: ROTOTRON 7-sided dual rotating CP cabaret -- VIDEO Added
« Reply #37 on: December 02, 2004, 02:20:14 am »
I just added a 1
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« Reply #38 on: December 02, 2004, 07:15:32 am »
WOW, that cab rocks!
Love the animated GIF and video, best video I've seen since the Paris Hilton one.
Do you have stops on it so the cables don't get tangled?
Awesome job.
BobbyG66
Half of the people you meet are below average.
rdagger
« Reply #39 on: December 02, 2004, 12:05:24 pm »
Awesome job.
BobbyG66
The triangle panel has stops.  The square doesn't but you can feel the tension long before the cable gets tangled.
