Author Topic: Act-Lab Light Gun Help  (Read 2377 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: November 15, 2004, 12:04:30 pm »
Anyone help me out.
I am not sure why in mame but I have to reconfig the act-lab light gun every game??? how do i set it in mame to be used by default ...the triggers always have to be reset...
big pain
thx
JIM
menace
Re:Act-Lab Light Gun Help
« Reply #1 on: November 15, 2004, 12:32:28 pm »
Are you unplugging it each time?  if you are--the computer is repolling the usb ports and assigning them as joystick numbers--this can change if you remove the gun and then plug it back it.  I assume you have changed the default values for each game you want to play (will have to do this once but there aren't that many trigger games) after you do it once (and never unplug it) it should always come back as the same input ont he same joystick
Demon-Seed
« Reply #2 on: November 17, 2004, 07:02:13 pm »
I am not unplugging it....
Is there a setting in the command line to make it work -lightgun or soemthing???
JIM
fixumdude
  • Last login:July 23, 2021, 10:02:08 pm
  • Getting Better at Arcade Controls
    • Arcade Controls
« Reply #3 on: November 19, 2004, 12:06:08 pm »
which version of MAME are you using?
Demon-Seed
« Reply #4 on: November 20, 2004, 07:30:38 pm »
it is the athlonxp version
