Author Topic: Multiple Control Panels, 1 IPAC  (Read 3317 times)
  • Last login:Yesterday at 01:12:23 pm
« on: November 11, 2004, 07:47:21 am »
Well, I got my IPAC VE in the mail the other day, and decided that I really wanted to have the ability to have multiple control panels, while only using one IPAC.  So I dug around in my box of electronics goodies, and found a few 50 pin male and female dsub connectors.  Here is a picture after soldering some wires:
Re:Multiple Control Panels, 1 IPAC
« Reply #1 on: November 11, 2004, 07:48:09 am »
The same dsub sonnector now connected to the IPAC:
« Reply #2 on: November 11, 2004, 07:48:36 am »
Different view:
« Last Edit: November 11, 2004, 07:49:02 am by HarumaN »
« Reply #3 on: November 11, 2004, 07:50:41 am »
I then soldered wires to the female dsub, and connected that to the outside of my control panel.  From there I wired the controls using spade connectors and quick disconnects (courtesy of Peale).  :)
« Last Edit: November 11, 2004, 07:51:05 am by HarumaN »
« Reply #4 on: November 11, 2004, 07:53:47 am »
Here is the finished (more or less) panel.  I have to add T-molding still.  This is the fighter panel, obviously.  I am gonna create a classics panel with a dedicated 4-way, spinner, trackball, all those goodies.  I am going to  build a DDR pad, so I'm gonna wire that up so it can connect to the IPAC in the same way.
armax
  • Last login:July 12, 2017, 07:20:15 pm
  • Game Not Over
« Reply #5 on: November 16, 2004, 01:49:12 am »
Where did you get the wiring blocks in order to mate two different guages of wire?
« Reply #6 on: November 16, 2004, 11:11:37 am »
I had these on hand, but you can get them (terminal strips) at Radio Shack, or somewhere similar.
« Reply #7 on: November 16, 2004, 11:13:49 am »
The terminal strips came in handy when I was making my one player controller.  It's a USB gamepad hack.
