Author Topic: Power off Compaq 5BW130 computer via DOS  (Read 2814 times)
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« on: September 20, 2002, 05:17:54 pm »
Anyone know how to power down a Compaq 5BW130 computer via Dos?   I'm trying to shut down my computer when I exit Arcade os.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Power off Compaq 5BW130 computer via DOS
« Reply #1 on: September 20, 2002, 07:41:23 pm »
I saw this tidbit on glaunch mailing list...
this place has a freely available power off thingie for DOS
hope that helps...
rampy
« Last Edit: September 20, 2002, 07:42:35 pm by rampy »
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #2 on: September 21, 2002, 12:11:14 am »
when ur in dos hit the power switch dos is preety much what old pcs used to shutdown
Slow In Fast Out
creatine28
« Reply #3 on: September 23, 2002, 05:40:46 pm »
I'm able to shut down the computer with the power button, but I've just been trying to figure out how to do it through a command, so when I exit Arcadeos, it just turns everything off.  Thanks for help though!  I'll let everyone know if I can get it working!
Steve
mhoward211
  • Last login:April 09, 2003, 10:31:25 am
« Reply #4 on: September 23, 2002, 06:22:48 pm »
Use the program like the previous post links to, place it in a folder on your c: and then add the line to your autoexec.bat file right after your ArcadeOS line.
For example
CD ArcadeOS
ArcadeOS
CD DOSPower
power
This means it should run once you have exited out of ArcadeOS.
creatine28
« Reply #5 on: September 26, 2002, 01:12:38 pm »
Tried both Dos Power down programs and both give me the message "No APM"  or something like that present? Any idea's?
ampapa
  • Last login:August 04, 2002, 09:59:21 pm
« Reply #6 on: September 26, 2002, 04:24:48 pm »
I think this might work....
Copy from windows the file win.com and place it in your c:\ directory. Then put this in a batch file: "c:\win /z" and give it a whirl...
:D
AJM,
http://ajmmame.webajm.com
