Author Topic: Dam these layout files  (Read 1682 times)
Predator
  • Last login:November 13, 2004, 07:19:49 pm
« on: November 08, 2004, 08:02:40 am »
Hi all
Newbie here, I have setup mamewah and mame and they work Fine. I now want to change the look and have D/Led a new Layout from http://home.comcast.net/~cpviewer
I have read http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=9717&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1&new=1098083008
And still no new layout .... it does not even try to load, all i get is the default one..
PLease help .....Thanks
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re:Dam these layout files
« Reply #1 on: November 08, 2004, 08:43:19 am »
Did you change the directory mamewah.ini points to to get the new layout?
Predator
« Reply #2 on: November 08, 2004, 08:52:01 am »
yep sure did
Goz
  • KOTA
« Reply #3 on: November 08, 2004, 09:08:16 am »
Has the layout file name been renamed to match the emulator name (assuming you are using mamewah 1.5+)? If so, you may need to look in the layout file for paths to grahoics, etc as well.
-Goz
« Reply #4 on: November 08, 2004, 09:52:08 am »
Sounds like you have something wrong to me.  Read \mamewah\docs\layouts.txt & see if that sheds any light.
Also, read \mamewah\mamewah.log to see if any problems have been recorded there.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #5 on: November 08, 2004, 10:32:47 am »
all you should have to do is rename thes file properly, see the doc Minwah mentions.
In a few instances of my own layouts, the background picture was specified inside the layout itself, so i had to edit the .lay file with notepad and change the name there, but that was about it.
jcrouse
    • CPViewer
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #7 on: November 08, 2004, 08:28:53 pm »
Have you searched here for the MAMEWAH FAQ?
Tritoch84
  • Last login:January 22, 2006, 12:31:27 am
  • Parry!
« Reply #8 on: November 11, 2004, 11:06:26 am »
I'm having this same problem, and it's driving me nuts, I'm new to mamewah, so forgive me if I'm doing something retarded.
I just made one up in it's editor, saved it, told mamewah's ini file where to find it, and it won't work. at all. all I get is that annoying default layout.
Overly Strict Father: "Here son, YOU can finish up this Street Fighter game while I get the pizza"
Me(age 10) "REALLY? *Mashes buttons like crazy* OH AWESOME *has heartattack*
« Reply #9 on: November 11, 2004, 04:30:13 pm »
I can't really say anything that hasn't been said already...
But make sure you are not pointing to the .lay file in 'layout' part - just the folder name, eg 'myskin' which should look as follows:
\mamewah\layouts\myskin\layouts.lay
Crazy Cooter
« Reply #10 on: November 11, 2004, 05:48:46 pm »
