Author Topic: Hagstrom KE72 vs. IPAC  (Read 2985 times)
DZuroff
  • Last login:January 05, 2019, 10:36:44 pm
  • . . . A wizard arrives precisely when he means to.
« on: September 17, 2002, 05:53:16 pm »
I know the obvious choice in a keyboard encoder for an arcade cabinet is the IPAC, however about a year ago I thought I would begin to buy parts I would need to build a cabinet so when it comes time for me to build I would have a big head start.  Unfortunately, I didn't learn about the IPAC until after I purchased the Hagstrom KE72.  I have seen a lot of good things about the KE72, however one post I can recall has me a little nervous.  Someone mentioned there is a small delay between when a button is pressed and when that key press is encoded.  Is this true?  If so, is there a way to work around this?  Or should I accept the $120 loss and go out and buy an IPAC?   :o  Are there any other issues with the KE72 I should know about before getting started?
Lilwolf
Re:Hagstrom KE72 vs. IPAC
« Reply #1 on: September 17, 2002, 06:06:04 pm »
I've never heard a bad thing about hagstroms other then they cost more.
Ipac's with their new config on the fly makes it my first choice... but the hagstroms are great also.
btw, the hagstoms are considered the down right best by many if money is not option.
btw, do you have any problems getting chun le to do her leg kick?  Or can you run fast in track&field?  Quick checks there
Darkade
  • Last login:November 10, 2003, 06:40:10 pm
  • We Are 138.
    • Darkade Mame Arcade
« Reply #2 on: September 20, 2002, 01:47:48 am »
I bought the Hagstrom KEUSB-36 and I love it.  The only problem is that it can only support 6 simultaneous button presses.  Later on, I plan to upgrade to the KE-72T and use my USB-36 for a cocktail cab since it would be running mostly classic games and have no need for 6 buttons at a time.  Hagstrom's customer service and product documentation is fantastic and I wouldn't go anywhere else.
clok
  • Last login:April 03, 2018, 10:58:39 pm
  • I can play PacMan till the screen splits!
« Reply #3 on: September 23, 2002, 12:26:23 pm »
Using the KE72-T and have nothing but good to say about it. (dont like dos programing, but oh well)
No delay that i can notice.. all the games seem to play fine to me.
Clok
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #4 on: September 23, 2002, 10:54:15 pm »
I use the KE72-T and I absolutely love it.  No delays or any other problems that I've seen.
Dave Dribin
  • Last login:May 26, 2007, 11:17:39 pm
  • ugh... yeah
    • Dave Dribin's Home Page
« Reply #5 on: September 24, 2002, 12:41:16 am »
I concur.... got a KE-72 and no delays.  Works awesome!  The only drawback, IMO, is the lack of a "shift" function, like the I-PAC.  I *really* like the shift function 'cause you can really reduce clutter on the control panel while increasing functionality. :)  If Hagtrom had this, I'd say go with the KE-72, hands down.
-Dave
