Author Topic: 25k7191 voltages *UPDATE* Hula no more!  (Read 2720 times)
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
« on: October 27, 2004, 08:57:45 pm »
I've been working on repairing a WG 25K7191 monitor and I'm still having a small problem. The monitor is doing a slight 'hula' so as per the troubleshooting chart on Randy Fromm's site I checked the B+ voltage at the ceramic resistor on the side frame. Now if I'm reading this right I got measurements of 155-157v DC on one side of the resistor and 105 on the other. The low side voltage dropped off to the mid 80v range after about 30 seconds or so and stayed fairly conatant ranging between roughly 85-90v. The monitor also has a blossoming problem when there's flashes on screen, or the screen switches. So the way I'm reading this is the higher voltage side of the resistor is the input to the voltage regulator and the low side is the output, and since I don't have the +130v at the output side I likely have a voltage regulator problem.
Can someone confirm this for me?
« Last Edit: October 31, 2004, 12:44:37 pm by Grauwulf »
www.wolfelectronics.ca
Cap Kits for Canadians!
Ken Layton
  • Guru
  • Technician
Re:25k7191 voltages
« Reply #1 on: October 28, 2004, 01:39:08 am »
That large white ceramic resistor is R301 and yes one side (with the red wire) is the input side. It should measure anywhere over 145 volts. The other side (blue wire) is the output side of the regulator. It should read +123 or +130 volts depending on what # the regulator is that's installed. The last 3 digits of the regulator's part number is it's output voltage (123 or 130). It could read plus or minus a volt or two depending on the quality of your voltmeter. If the output voltage is not within those specs then the regulator is shot and needs to be replaced.
« Last Edit: October 28, 2004, 01:41:53 am by Ken Layton »
Grauwulf
  • Button Masher
Re:25k7191 voltages
« Reply #2 on: October 28, 2004, 06:17:41 am »
Thanks Ken, looks like I'm off to the parts store after work tonight. :)
menace
Re:25k7191 voltages
« Reply #3 on: October 28, 2004, 07:36:19 am »
I posted ohm readings from a new voltage regulator in the FAQ--you could also compare your regulator values to those and see where you come out.  Note ken's message following the values (I forgot to add that tidbit of info in my original post)
Ken Layton
  • Guru
  • Technician
Re:25k7191 voltages
« Reply #4 on: October 28, 2004, 10:49:36 am »
For reference here are the NTE replacement numbers for the various regulators that Wells-Gardner uses on the k7000 series:
STR3123 = NTE 15021
STR30123 = NTE 1776
STR30130 = NTE 1777
Grauwulf
  • Button Masher
Re:25k7191 voltages
« Reply #5 on: October 28, 2004, 07:58:25 pm »
Well I picked up a new voltage regulator tonight, but I got the wrong one. I got the right voltage, wrong style regulator though. *grrrrr* I guess I should have checked to make sure I had the right part number, I got a STR30130 and I actually need a STR3130. So I get to go back to the parts store tomorrow after work. I have the pinouts for both and I know I could make the STR30130 work, but I just want the right one.
Ken Layton
  • Guru
  • Technician
Re:25k7191 voltages
« Reply #6 on: October 28, 2004, 11:54:27 pm »
This chassis has some jumper wires you have to move (and resolder) to use a different style regulator. The jumpers are on the schematic. I find it easier to just replace with like for like.
Grauwulf
  • Button Masher
Re:25k7191 voltages
« Reply #7 on: October 29, 2004, 07:07:43 am »
Thats exactly my mentality as well. I'm not messing around with this any more than I have to. I've already had to repair someone else's shoddy repair work on this chassis in addition to changing some incorrect parts. So I'm not in the mood to try and substitute parts unless I have no choice! So we'll do it all over again tonight and hopefully have a fully working monitor!
Grauwulf
  • Button Masher
Re:25k7191 voltages *UPDATE* Hula no more!
« Reply #8 on: October 31, 2004, 12:51:57 pm »
Well I have the right voltage regulator now and I have no more hula and bossoming problem! Yay! So this concludes the saga of my first monitor repair! So now I'm on the hunt for a second 25k7191 chassis for my spare tube so I can have a second complete monitor. Thanks to everyone who has offered information and advice for all my questions. Thanks also go out to Bob Roberts and Randy Fromm, if it wasn't for all the information on their sites I probably wouldn't have attempted to do these repairs myself. ;D
Ken Layton
  • Guru
  • Technician
« Reply #9 on: October 31, 2004, 01:10:43 pm »
This is great news! :) Glad it's working. And don't forget the information at www.jstookey.com/arcade/WG_25k7191/
This is one of the best chassis Wells-Gardner ever made. Why they discontinued it is beyond me.
« Last Edit: October 31, 2004, 01:13:44 pm by Ken Layton »
JoeB
  • Last login:September 18, 2025, 12:42:30 pm
  • NES Fanatic
« Reply #10 on: October 31, 2004, 06:22:47 pm »
I second that Ken!  with a bid of TLC, the chasis should last forever!
Grauwulf
  • Button Masher
« Reply #11 on: October 31, 2004, 07:08:18 pm »
Thanks Ken, I don't think I actually had that link yet. I also just got a 19" k7000 monitor in a cab I picked up at an auction yesterday. :)
