Author Topic: Cocktail top latch question  (Read 3395 times)
currygoat11
  • Last login:May 04, 2018, 11:10:02 pm
  • She's doing it right now!
« on: October 27, 2004, 01:59:16 pm »
http://www.arcadeshop.com/pics/latch.jpg
I bought 2 of these for my cocktail cab. Well, where do these mount?  On the inside of the cabinet?
If so, how do I latch/unlatch the thing once the top is closed. Are you supposed to reach through the coin door? Of course I didn't plan on having a coin-door at all so this may be a problem!
thanks
currygoat
cg
whammoed
  • Last login:November 25, 2025, 03:34:11 pm
  • Crack don't smoke itself
    • NiceMite
Re:Cocktail top latch question
« Reply #1 on: October 27, 2004, 02:01:51 pm »
yes, on inside
yes, through coin door
If you don't want a coin door just don't use latches.   The weight of the monitor is enough to keep the cab closed in a home environment
currygoat11
« Reply #2 on: October 27, 2004, 02:53:13 pm »
ack! thanks for the quick reply... I'll most likely just leave the latches out of the picture. Either that or go ahead and install a coin door.   hmmmm. Dont wanna spend $90!
cg
currygoat11
« Reply #3 on: October 27, 2004, 03:03:49 pm »
do you guys have any other creative suggestions on how I can latch the top down, avoiding a coin-door installation?
cg
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #4 on: October 27, 2004, 03:12:15 pm »
You could use a some small angle brackets under the rim of the cocktail's top. On a Midway style cocktail, they're pretty easy to hide (one either side of each control panel). Just screw 'em in and wa-la!
On another note, is there another name for that kind of latch? Is it the kind of thing that I could find in Home Depot or McMaster?
whammoed
    • NiceMite
« Reply #5 on: October 27, 2004, 03:28:26 pm »
I see it called a panel clamp a lot.  Couldn't find em at home depot or lowes...just online
whammoed
    • NiceMite
« Reply #6 on: October 27, 2004, 03:38:00 pm »
You could fashion an "L" bracket with a slot in it attached to the inside top of the cab.  Put a barrel lock on the front that when locked the arm slides into said "L" shaped piece.
whammoed
    • NiceMite
« Reply #7 on: October 27, 2004, 03:53:49 pm »
how bout a brand new three door coin door for $40?
http://www.mantisamusements.com/coindoor.htm
whammoed
    • NiceMite
« Reply #8 on: October 27, 2004, 03:56:59 pm »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #9 on: October 27, 2004, 04:40:41 pm »
Or do what Atari did and make one side of your cocktail a door that you can open, or keep closed with a lock. Opening this panel should give you access to the clamps.
NO MORE!!
currygoat11
« Reply #10 on: October 27, 2004, 04:58:30 pm »
wow you guys rock - thanks for all the ideas... the barrel lock idea is good.  The blank door is another great idea - I may go with that if I could somehow adhere some type of artwork to the door  - just a thought to make it look less plain!
cg
ericball
  • Last login:March 13, 2025, 11:01:47 am
« Reply #11 on: October 28, 2004, 12:01:00 pm »
I'm planning on using some casket latches (B in the picture) from
http://www.leevalley.com/hardware/page.asp?page=41996&category=3%2C43659&SID=&ccurrency=1
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25% (discarded)
2004 Tempest cabinet & CP > 75% (sold)
2017 Raspberry Pi Zero W w/ Lakka microconsole 50%
2021 Vertical Bartop - in progress > 80%, 100% functional (sleeping)
lo_cash
  • Last login:October 05, 2004, 12:59:55 pm
    • Built4Mame.com
« Reply #12 on: October 28, 2004, 01:16:49 pm »
I've been thinking about something like this knock-down fitting: http://www.leevalley.com/hardware/page.asp?page=40049&category=3,41306,41319&abspage=1&ccurrency=1&SID=.
How do those casket latches work?
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #13 on: October 28, 2004, 03:13:41 pm »
I made the side of my cocktail open. I used these locks from Home Depot....
ericball
« Reply #14 on: November 08, 2004, 12:18:26 pm »
Hmm, I have some IKEA stuff which uses those fittings on drawers and the cam part works itself loose after a while.
The casket latches are easy.  You put a small slot under the strike plate (top).  The thumb catch (middle) is held under the strike plate by one of the screws for the strike plate.  The latch flange (bottom) is then screwed into the other piece.  The flange slides into the slot in the strike plate, and the catch holds it in place.  Hmm, I just realized it will be easier to attach the strike plate and thumb catch to the lid and screw the flange into the edge of the sides rather than trying to mitre into the edge.
