Author Topic: Stupid ROM Question (not a request)  (Read 2338 times)
  • Last login:September 15, 2025, 10:44:52 am
« on: October 24, 2004, 09:17:26 pm »
I have a stupid ROM question - it's not a request or anything like that.   If I have xmvsf.zip, for example, what are the xmvsfa.zip, xmvsfb.zip, etc. files for?  They are significantly smaller than the "original" xmvsf.zip file.  Thanks.
SirPeale
  • Green Mountain Man
Re:Stupid ROM Question (not a request)
« Reply #1 on: October 24, 2004, 09:19:17 pm »
They're 'clones' ie other versions of the same game, say the version released in Korea or Japan or the US.  Those are that particular releases ROMs.
« Reply #2 on: October 24, 2004, 11:09:01 pm »
Thanks, so I'm assuming for something like xmvsf you need to have the "original" (large) file and the smaller file to run the "clone" game?
ften
  • Last login:March 06, 2022, 10:20:43 pm
  • Beep Beep
    • Fathertom.net
« Reply #3 on: October 25, 2004, 12:03:28 am »
Yup
paigeoliver
  • Awesome face!
« Reply #4 on: October 25, 2004, 12:23:42 am »
THe smaller file contains only the rom chips that have different data than the main release.
In mame the last version released is always considered the parent rom, no matter which version is most common.
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: October 25, 2004, 08:14:28 am »
For your setup, yes.
What you probably have is what is known as split sets.  This is the most common method in which all files are included in the parent set, and only files different from the parent files are included in the clone sets.
Another variation is merged - in this method, all roms for the clone and the parent set are contained in the parent.zip file and there are no clone.zip files.  This is less popular, because you can't look at your rom list and know if you support xmvsf.
Finally, there is Not Merged - which is where all rom .zip files contain all the files needed to play the game.  This is VERY unpopular now b/c you would need about 4-5 times the disk space (just an estimate) for rom storage.
Also you can use a mixture of these.
Final Notes - MAME doesn't really care how you set it up.  I'm pretty sure if none of the files have the same name, you could unzip all your roms to the rom directory and MAME will still find what it needs and run.  (Bad, bad idea, though).
Also, you can manually edit the files if you want to.  For example, let's say xmvsf is the parent, but doesn't work, so you always play xmvsfa.  You can unzip both files to separate directories, copy the xmvsf to the xmvsfa folder and re-zip and then delete xmvsf.  Now MAME will work but your front-end might not (or might) see the files for xmvsf.
