Author Topic: MameWah Setup tool not compatible?  (Read 2349 times)
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
« on: October 20, 2004, 02:49:15 pm »
im have the most recent version of mamewah installed, but the setup tool still insists that i do not and asks me to go to the mamewah site to get a version that clearly does not exist..
and these are the versions i downloaded. the main and the update..
« Last Edit: October 20, 2004, 02:56:49 pm by DYNAGOD »
Enjoying the fruits of technological obsolescence one game at a time...
DYNAGOD
Re:MameWah Setup tool not compatible?
« Reply #1 on: October 20, 2004, 02:59:24 pm »
OK ,i understand.. i need an old version of mamewah
where can i get a crusty old version thats compatible with the setup tool,mamewah only host the latest and greatest..
« Reply #2 on: October 20, 2004, 03:30:33 pm »
Email me & I'll send it to ya...
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #3 on: October 20, 2004, 04:21:04 pm »
  Seriously, MAMEWAH 1.51 is by far the easiest version of MAMEWAH to set up. If the reason you're going to an old version of MAMEWAH is because you're scared of the setup involved, just give it a shot first.  You'll save yourself the aggravation of converting later!
  Not to mention making it easier for Minwah to help you when you have a problem.
-Steve
« Reply #4 on: October 20, 2004, 05:01:58 pm »
Very true, which is basically why I no longer offer it as a download.
I appreciate there are a few reasons why you may want to run v0.97 tho, which is why I will mail it out if anyone really wants it...
DYNAGOD
« Reply #5 on: October 21, 2004, 07:21:00 am »
ill give it a shot first then..
if i fall on my face, ill come begging back for an older version  ;D
« Reply #6 on: October 21, 2004, 10:23:06 am »
OK...
If you get stuck setting up emulators, check out JCrouse's assortment of ini files: http://home.comcast.net/~cpviewer/downloads.htm
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #7 on: October 21, 2004, 11:07:38 am »
I'll second the "don't get used to an older version of things" theory.
I started setting up mamewah about 2 weeks before the new version came out, the newer one is much easier. It DOES still have a learning curve, but you just have to accept that fact that you WILL need to read the .docs :)
BYOAC users get 5% off with coupon code byoac5
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #8 on: October 21, 2004, 12:00:50 pm »
If you ever get everything setup in .97 then decide you want to upgrade remember that you'll have to re-do your custom lists over again. Something you won't have to do anymore with the new versions
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #9 on: October 21, 2004, 12:03:41 pm »
Is there a way to import your 0.9x configuration and list files into the newer 1.51 or do I have to start over?
(I just downloaded 1.51 and haven't installed it yet)
Edit: what about layouts? I have 5 emulators with custom layouts, can those be imported or must they be re-done?
Can the two version co-exist while I bring 1.51 up?
« Last Edit: October 21, 2004, 12:14:07 pm by papaschtroumpf »
« Reply #10 on: October 22, 2004, 05:07:04 am »
You have to configure from scratch :(
They can still be used, but you'll need to rename everything from emux*.* to emuname*.* (see the new layouts.txt).
Sure, just install to a different directory :)  And you may as well use v1.52 now ;)
DYNAGOD
« Reply #11 on: October 22, 2004, 12:42:25 pm »
ok , i got it working..
does mamewah not work with zipped snap shots?
i cant get any of my snaps to show.
« Reply #12 on: October 22, 2004, 01:32:01 pm »
Nope, sorry.
DYNAGOD
« Reply #13 on: October 22, 2004, 03:08:50 pm »
oh sure and release a new version the day after i set up :P
you did that on purpose lol   ;D
fair enough,ill just unzip em..
