Author Topic: Splicing an earphone wire..  (Read 3995 times)
MuscleSprout
  • Last login:Never
« on: May 24, 2002, 04:50:36 pm »
How do you splice together an earphone cable.  I've tryed striping the end off, separating the two wires, and taping it together, but it didn't work.  What am I doing wrong?
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
Re: Splicing an earphone wire..
« Reply #1 on: May 24, 2002, 04:57:50 pm »
If your trying to splice it down towards the plug you should see 3 wires not 2. If it is stereo headphones there should be a positive for the right, one for the left and a shared ground for both of them. If your splicing it up by the earphone then I don't know what your doing wrong. An easier way to do it is to go buy a cheap splitter from radio shack.
