Author Topic: wiring I-PAC2 for an esc button  (Read 2522 times)
shorething
  • Last login:December 01, 2004, 12:24:14 pm
« on: October 18, 2004, 01:50:05 pm »
I have everything wired, except the esc key.
I have 6 buttons per player, so they are wired to the position 1-6 on my I =PAC 2.
I have 2 open spots on each side of the I-PAC 2 (positons 7 & 8)
Where should I wire my esc button?
Do I just do it to 7 or 8 and adjust it using the software?
Or is there a default on the I pac for esc (without shifting)?
What is the default shifting combination for esc?
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
Re:wiring I-PAC2 for an esc button
« Reply #1 on: October 18, 2004, 02:04:14 pm »
shifted player 2 start is the default for esc
shorething
« Reply #2 on: October 18, 2004, 02:37:16 pm »
I hate to sound like a putz...
but what do I press along with player 2 to get the shifted
esc to work?
Bgnome
  • Who's da gnome?
« Reply #3 on: October 18, 2004, 02:50:22 pm »
you must hold down player 1 start, which is the default shift key, to gain access to the shifted functions.  and if you wanted to sound less like a putz, you could always try reading the manual ;)
IncrdblHulk7
  • Last login:February 21, 2024, 09:26:53 pm
« Reply #4 on: October 18, 2004, 02:50:29 pm »
I beleive that Player1 doubles as the Shift key on the default IPAC settings
shorething
« Reply #5 on: October 18, 2004, 03:09:58 pm »
manual?
what manual?
Bgnome
  • Who's da gnome?
« Reply #6 on: October 18, 2004, 03:16:18 pm »
i was under the impression that you always got a cd full of everything you needed to know when you ordered these from ultimarc.  the website is very informative as well, along with the ultimarc forums..
http://www.ultimarc.com/ipac1.html
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: October 18, 2004, 03:26:26 pm »
Lots to cover here:
Manual - http://www.ultimarc.com/ipac2.html - Start there and the links should cover most everything you need to know.
I like a dedicated Pause and Escape on the panel.
Note that the shifted Escape method mentioned below may give you problems in a 2-player simultaneous game when both player want to continue playing at the same time and the game quits.
A better option if you only want one additional button is to set a button for pause, re-map it to be the shift key, and then have another shifted button for Esc.  So for example, pressing Pause and holding it and pressing P1Start (or P2Start, etc.) quits the game.  This requires reprogramming the I-PAC, though.
If you just want to add a button for escape, just wire a new button to P1Button 7.  This is "C" by default.
Now you have two options -
Option 1 - If you will only be using MAME, just go into TAB - Inputs (all games) - and change the key for UI CANCEL to "C" (or "Esc or C").  This avoid re-programming the I-PAC, but you will have to do this for all the programs that you want to use the I-PAC with (and if some of them don't allow you to re-assign keys, it won't work).
Option 2 - Re-program the I-PAC so P1B7 send "Esc".  Now the I-PAC will work with most of the programs out there and you don't have to adjust MAME or your other software.
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
« Reply #8 on: October 18, 2004, 11:22:52 pm »
I kind of got used to the "hold player 1, press player 2" to exit using the shift method.
The pause key as the shift key sounds appealing though.  Much less room for accidental shifting problems.
...they only live twice!...
(>")>----MAME----<("<)
