March 06, 2026, 09:01:31 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Main
Monitor/Video Forum
No Green on WG25
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: No Green on WG25 (Read 1844 times)
DaemonCollector
Trade Count:
0
Full Member
Offline
Last login:December 26, 2009, 07:02:16 pm
All your base are belong to us.
No Green on WG25
on:
October 16, 2004, 04:45:08 pm »
Just got a cab and upon firing it up I found that on the color test screen there is nothing in the green, yet when I mess with the pots I can get the entire screen to tint green...but cannot get a green bar to show on the test screen. Anyone think its fixable?
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Last login:October 12, 2021, 12:25:59 am
Technician
Re:No Green on WG25
Reply #1 on:
October 16, 2004, 11:34:45 pm »
What model is the monitor? Wells makes 100's of different models each with their own quirks/problems.
What is the manufacturer and tube number of the picture tube?
Logged
DaemonCollector
Trade Count:
0
Full Member
Offline
Re:No Green on WG25
Reply #2 on:
October 16, 2004, 11:55:05 pm »
its a Wells 25k7191 with a Zenith tube, i think the model is a E1A 1101. Thanks for any help in advance.
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Re:No Green on WG25
Reply #3 on:
October 17, 2004, 12:13:37 am »
The Zenith tube is known to go bad. Wells had major problems with Zenith and switched tube manufacturers.
I must have had 4 or 5 of these tubes go bad over the past 2 years. Rejuvenating sometimes helps, but I've had to replace a couple of tubes. I bought new replacements straight from Wells and got a good price.
However, you could have a bad driver transistor on the neckboard for the green color. I've also seen the trimpots go bad on the neckboard.
Logged
DaemonCollector
Trade Count:
0
Full Member
Offline
Re:No Green on WG25
Reply #4 on:
October 17, 2004, 12:26:47 am »
Hmm, so which do you think would be the first place to look? As I said I can get a green tint by adjusting the green trim pot and the cut off, so the driver transistor? In that case where would it be, I'm new the whole monitor thing.
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Re:No Green on WG25
Reply #5 on:
October 17, 2004, 12:59:49 am »
On the neckboard, transistor Q202 is the green driver. Working backwards from there the green signal goes to pin 19 of chip IC1 (UPC1397C) on the main board. Pin 4 of that chip is the green input fed from capacitor C5 (10 uf @ 25 volt BI-POLAR). Then to Q2.
Logged
DaemonCollector
Trade Count:
0
Full Member
Offline
Re:No Green on WG25
Reply #6 on:
October 17, 2004, 01:08:38 am »
Is there an easy way to check if its bad? I remember reading somewhre about using a jumper wire and tapping it to the case and if it flashes green that means its fine...is that not safe? is there a better way?
Logged
DaemonCollector
Trade Count:
0
Full Member
Offline
Re:No Green on WG25
Reply #7 on:
October 17, 2004, 05:17:26 pm »
I FIXED IT
Was the stupidest thing and I should have checked it first. The green signal wire from the game board was cut in half, reconnected it and the monitor looks like new.
Thanks for your help
Logged
Grauwulf
Trade Count:
0
Full Member
Offline
Last login:July 27, 2009, 03:42:44 pm
Button Masher
Re:No Green on WG25
Reply #8 on:
October 17, 2004, 08:28:15 pm »
If only all problems were so easy to fix, eh? The easy things to fix are sometimes the easiest to overlook.
Logged
www.wolfelectronics.ca
Cap Kits for Canadians!
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
No Green on WG25
