Author Topic: Wood Suggestions for CP?  (Read 2153 times)
Andy
  • Last login:February 04, 2024, 10:28:02 am
« on: September 13, 2002, 06:13:18 pm »
Hello,
I'm not sure about what type of wood to use with my control panel.  My CP will be 15" X 20" X 7.5" when finished.  The wood I use should be light and strong, and I plan to paint it when finished.  I think I'll be going with 3/4" thickness.  Any help would be greatly apreciated!
Thanks,
Andy
P.S.  Everyone has been quite helpful so far, thanks alot!
SNAAAKE
  • -Banned-
Re:Wood Suggestions for CP?
« Reply #1 on: September 13, 2002, 06:34:58 pm »
MDF if you are painting.if you are using lexan or plexi then route the bottom to get right height.
luck  ;)
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
« Reply #2 on: September 13, 2002, 06:35:36 pm »
It's really hard to beat mdf (Medium Density Fiberboard)
It is not light ,But if your building a desktop controller then you will want it pretty heavy to keep it from moving around.
If it's a CP for a cab you probably don't care how heavy it is unless your doing swappable panels.
MDF machines real well ,IT will hold a real nice curve without chipping if you decide to route the edge over.
It also takes paint really well. The only drawbacks I can see are that it may be prone to sagging if you have too large of an un-supported span with weight on it. Also MDF generates a ton of dust.
                     Hope this helps
                            Slug54
Andy
« Reply #3 on: September 14, 2002, 04:39:22 pm »
I keep going back and forth between a heavy or light controller.  I've pretty much decided that if I go heavy I'll use 3/4" or 5/8" MDF.  Any wood suggestions for a light controller that will paint nicely?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: September 14, 2002, 04:55:26 pm »
1 or 2 player?  It isn't THAT heavy!  Just heavier than other stuff since it is more dense.
You could look at 1/2" MDF too.  I use 3/4" MDF on my cabinet.  It is probably the easiest woodlike material you will ever work with.
