Author Topic: Anyone NOT using carriage bolts for joysticks?  (Read 8146 times)
1UP
  • Token Junkie
    • 1UPArcade
« on: September 13, 2002, 04:59:50 pm »
I've seen a  lot of posts here about which size carriage bolts to use for mounting joysticks and whatnot.  I keep thinking, why use carriage bolts at all?  I've been using #10 wood screws, screwed in from below the sticks, and haven't had any problems yet.  I know that others must be doing the same, since I've seen many a panel without any bolts visible on the surface.
Has anyone actually broken their sticks loose from the panel because of using wood screws?  Or are the carriage bolts just for looks?
My other job...
hyiu
    • www
Re:Anyone NOT using carriage bolts for joysticks?
« Reply #1 on: September 13, 2002, 05:09:27 pm »
I do use bolts.... (nuts and screws...) however, I route the top a bit so that the screw top sinks into the wood... and then use artwork and lexan on top....
so.. the artwork and lexan will cover the 4 joystick bolts....
works out pretty nice.... (but will only work if you put something on top....)
you can check out my pic....
http://www.geocities.com/hyiu/pics/DigiCam/
click on nice_stick.jpg....
sorry.... still using nuts and screws... not exactly what you asked... but hope it helps....
;)  ;D
SNAAAKE
  • -Banned-
« Reply #2 on: September 13, 2002, 05:16:50 pm »
the abuse and madness of video games  ;D
bolts add nice touch to your stick and i had problems when i used just screws..
the stick just sank in the box after a week or so...
its called rough play  ;D
i followed the usual way for the bolts..it does make your stick look professional though.and its a good investement because your stick would probley last forever with the bolts. :)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: September 13, 2002, 05:19:53 pm »
http://www.geocities.com/hyiu/pics/DigiCam/orig_cab_parts.jpg
scan the bezel in.  give it to either me or preferably HowardC and we will put it in mame:)
« Last Edit: September 13, 2002, 05:22:25 pm by SirPoonga »
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #4 on: September 13, 2002, 05:24:12 pm »
Not me, but I've seen examples (no link sorry) of people using t-nuts underneath and regular bolts. from below...
*shrug*
rampy
J_K_M_A_N
« Reply #5 on: September 13, 2002, 05:34:53 pm »
To answer your question 1UP, I used sheet rock screws from under my cp. I have been abusing it for about a year and haven't had a problem yet. I have seen the bolt and nut also but I don't really like the look of it myself. I don't know, maybe I don't beat the cp enough to break them loose. It works fine for me.
J_K_M_A_N
1UP
  • Token Junkie
    • 1UPArcade
« Reply #6 on: September 13, 2002, 05:52:56 pm »
OK, I'll just go with screws for now.  If they ever break loose, I'll drill bigger holes and use the carriage bolts.  :)
My other job...
PCC
  • Last login:April 07, 2003, 04:12:28 pm
    • PC Cab
« Reply #7 on: September 13, 2002, 05:53:29 pm »
*shrug*
rampy
E-mail: info@pccab.net
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
« Reply #8 on: September 13, 2002, 05:54:02 pm »
This guy used t-nuts and bolts. http://www.pccab.net Nice clean look in my opinion.  I've done a couple of projects this way too.
Doug
My Control Panel
http://www.doughansen.net/arcade/boltsvsnobolts.jpg
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
chanson
  • Last login:August 21, 2003, 01:09:57 pm
  • Finished 1 MAME machine, working on #2!
« Reply #9 on: September 13, 2002, 09:34:56 pm »
My cab has a totally different approach for the CP.  I have a PacMan replacement joy which won't work through 3/4" wood.  So, here's what I did.
The CP is 3/4 MDF but I routed the TOP of that board out to fit the Joystick (cut all the way through for the center portion).  I then screwed (regular screws) the Joystick to the MDF from the top down into the MDF.  Then I covered the whole thing with a 1/8" hardboard (you know, like what they make pegboard out of) with only a hole for the handle of the joystick.
Of course I had to drill through both boards for the other buttons.
The nice other feature of this setup is that the hardboard with a carefully placed hole serves as the "mounting plate" for my trackball also.  The TB is mounted in a hole in the MDF board with the ball just passing through a hole in the overlying hardboard.
The whole thing was a fairly inexpensive way to mount the controls and seems very stable.
  • Last login:February 21, 2026, 05:58:33 pm
« Reply #10 on: September 13, 2002, 10:44:50 pm »
I wouldn't reccommend screws.... I used big nasty screws in leu of bolts on my very first cp (back in the day)  Not only did they work loose from my mad playing skillz but they took a large chunk of the bottom of the cp with them... Yup that's right I played so hard it ripped the cp apart.
Now this wasn't puny mdf or 5/8 inch board, it was 3/4 plywood and it freakin tore the botttom two layers completely out!  I had the crazy
misconception that I could screw up from the bottom up to just below the surface of the cp and the strenght of the cp would hold it in place.  Well yeah it did, but unfortunately plywood is in layers and I actually ended up ripping the glued layers apart.
You can get flush mounted bolts if you don't like the look of the carriage type, remember that.
ddebuss
  • Last login:January 20, 2015, 07:48:10 am
  • Stuck in the 80's
« Reply #11 on: September 14, 2002, 09:25:28 pm »
I have three units with screws from the bottom, nothing on the top.  Worked fine for me.  I play Robotron a lot and I play hard without a problem.  I figure if I do have a problem I will install bolts then.
If it breaks through, no big deal, I have removable control panels so it's no big deal to make a replacement.  After making my last bunch of cabs I had a 1/2 sheet of 5/8" isoboard left over so I made another dozen blanks for control panels.  That way if I get the whim for another layout, I just need to drill the holes.
(I use 5/8" because when you add the Lexan it's 3/4.  I use 3/4 T-molding so it transitions nicely from the T-molding to the top.  Trick to that is to be sure you route the slot with a 3/4" setting from the back of the panel (so it's off center until the Lexan is added.)
hyiu
    • www
« Reply #12 on: September 16, 2002, 10:39:42 am »
Hi SirPoonga:
I have no pblm to give that bezel to you for free.... I have no use of it and not planning to use it... (I only need the plexiglass...)  I'm located in Brooklyn, NYC... are you close by ??
scanning it.... I don't have a scanner... but 1 of my friends does... I think I can only scan it in pieces.... if I do... would you mind pasting it back together ??
mailing it would means folding it which is no good, right ??
plz let me know....
ps: my friend is currently working and going to school... so.. scanning it might take something like 2 wks before I can get back to you with the images.... is that ok ??
hope I can help....
;)   ;D
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #13 on: September 16, 2002, 12:31:52 pm »
I wouldn't reccommend screws.... Yup that's right I played so hard it ripped the cp apart.
Oops! I guess I don't play that hard. My sticks are mounted with 3/4 inch drywall screws into MDF. I don't have any problems.
Bob
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #14 on: September 16, 2002, 02:05:43 pm »
I use carriage bolts...they are also good as a reference for the corners of the joystick (for certain fighter moves).
-Dave
1UP
  • Token Junkie
    • 1UPArcade
« Reply #15 on: September 16, 2002, 03:33:21 pm »
OK, all things considered, I'm going with countersunk bolts underneath the CPO artwork.  I have plenty of graphics that let me see where the corners are.  I don't play that hard, but I noticed some of my guests do.  Thanks everyone.
My other job...
SirPoonga
  • Puck'em Up
« Reply #16 on: September 18, 2002, 01:07:15 am »
Find someone with a scanner.
