Author Topic: Fceu Ultra question  (Read 2027 times)
mhoward211
  • Last login:April 09, 2003, 10:31:25 am
Fceu Ultra question
« on: September 13, 2002, 01:10:31 pm »
I have been using Fceu Ultra and have a question about it.  I currently have it located at c:\fceu but for some reason it keeps adding files and folders to the c:\  Is there anyway to get it to stop doing this and save\write to it's own folder instead of the c:\?
Thanks,
Michael
John
  • Last login:June 07, 2004, 06:03:19 pm
Re:Fceu Ultra question
« Reply #1 on: September 13, 2002, 01:36:11 pm »
I am running .76 of FCE Ultra.  If you goto Config, then Directories, setup Base Directory override to your FCE Ultra Directory and you can even check the box for save extra nonvolatile game data
that should do it.
mhoward211
« Reply #2 on: September 14, 2002, 10:11:58 pm »
I found it after I tried running Fceu.exe just on it's own instead of going through Game Launcher.  It lists various options one of which is subase which when enabled tells it to write to the base directory.
Thanks for the reply.
« Last Edit: September 15, 2002, 11:28:08 pm by mhoward211 »
