Author Topic: updated rom sets? [NOT a rom request]  (Read 1403 times)
johnnysmitch
  • Last login:November 16, 2006, 02:22:05 pm
  • I want you to MAME me as hard as you can
« on: October 14, 2004, 02:44:36 pm »
this is probably a stupid question, but how much changes between rom sets?  I got my set from the freemameroms project, but it's a .82 set (shoulda checked before i got it apparently)... is there a lot that has changed since then?
SirPeale
  • Green Mountain Man
Re:updated rom sets? [NOT a rom request]
« Reply #1 on: October 14, 2004, 02:51:12 pm »
Well, some things.  A lot not.  If the games you want to play are running okay, then you're doing okay.
Sometimes games can be redumped, and that signifies a redownload of a set you might already have.  Or they change the name of either the set or the ROMs within.  In this case, use ClrMAME to audit and make those changes.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #2 on: October 14, 2004, 03:06:50 pm »
Yup.  Learn to use ClrMamePro proficiently, and you will do yourself (and us!) a huge favor.  If you knew how to use ClrMamePro, you'd be able to tell all by yourself, within minutes, exactly which ROMs have been updated or changed between ANY two versions of MAME.
  Aside from that, anywhere from 15-50+ ROMs can change between versions.  Now, whether they're changes worth worrying about or even changes to games you'd play is, for most people, the deciding factor on whether to update or not.
  As Peale said, there's no reason to upgrade/update either MAME or your ROMs if you're perfectly happy with what you've already got.
-Steve
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #3 on: October 14, 2004, 09:50:42 pm »
I'm still back at 0.58  8)
Runs what I want it to.  if I find something I need later, I'll update.  Until then, I'll chill.
GGKoul
  • Cheesecake Apprentice
« Reply #4 on: October 15, 2004, 12:11:06 am »
This site gives you a version, by version breakdown of what was added.
http://www.mameworld.net/maws/
johnnysmitch
« Reply #5 on: October 15, 2004, 09:53:22 am »
I downloaded clrmamepro last night and ran it against my romset; i'm missing something like 200 rom sets, so I'm probably just gonna get a .87 set and be done with it - i have noticed that there are several games that aren't running well/correctly that I would like to play, so I might as well update.  Thanks for the info, all
