Author Topic: Eye Candy Power  (Read 1276 times)
Jkawch
  • Last login:September 21, 2004, 03:49:29 pm
Eye Candy Power
« on: October 12, 2004, 01:14:52 am »
Im trying to find a good button to use for powering on my cab. I bought a rocker and a toggle switch, only to discover (which i should have known) that they wont work properly. The button on my computer was pushbutton so it would Close Circuit/Open Circuit quickly. So now Im looking for a neat pushbutton but I have no idea where to start.
If anyone knows a great site for buttons/switches or a good store I should try visiting thatd be very appreciated.
Secondly, Im wanting to wire a trackball and a spinner to my Opti-pac. The trackball is easy since ultimarc has the step by step for the happs trackball off of their site, but I dont see anywhere how to install my Slikstik spinner, since its a straight USB, Im not sure which wire goes where. Im just hoping someone has experience doing this.
Also, Im wondering if its possible to wire both and use both in mame (not necessarily at the same time). Also, one of the optical devices will ALWAYS be off while the other is on.
Thanks for any help!
JKawch
skid_68
  • Last login:December 29, 2022, 07:25:30 pm
  • Hmmmmmmmm....
Re:Eye Candy Power
« Reply #1 on: October 12, 2004, 01:19:48 am »
« Last Edit: October 12, 2004, 01:20:54 am by skid_68 »
KeeWay
  • Last login:September 07, 2012, 07:57:21 pm
  • My MAME Woody
    • My Ultimate MAME Woody
Re:Eye Candy Power
« Reply #2 on: October 12, 2004, 02:32:19 am »
this is what i did on my cabinet i just finished this past weekend..(just finishing up my website to post as a new project)
Lighted On / Off Button
this is a happ lighted eliptical button and i printed the "on / off" on my computer then inserted the cutout text. for the wiring i wired the switch to the motherboard power switch header then took a old cpu fan and used the cable by cutting off the fan and attaching it to the 12v light.... this is all you need if you also get one of the Bits Limited power strips..
as for the slikstik i had the same problem, i had originally purchased the opti-pac for my trackball and 2 tornado spinners i ordered but i did not look carefully enough on the slikstik site and they say it is not compatable with the opti-pac. i hooked them up as they were and on one of the spinners i had to switch the axis but they all three worked like a champ all at the same time in windows xp which i am using....
KeeWay
Check out my Ultimate Woody
JustMichael
  • Mmmmm!! Cheesecake!!
Re:Eye Candy Power
« Reply #3 on: October 12, 2004, 02:59:56 am »
I think I used #275-618  from Radio Shack.
I did add a label to the face of the button though:
Re:Eye Candy Power
« Reply #4 on: October 12, 2004, 09:37:45 am »
I just used an arcade pushbutton (from www.ultimarc.com).
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
Re:Eye Candy Power
« Reply #5 on: October 12, 2004, 09:54:09 am »
I just used a momentary contact switch similar to what JustMichael suggested he used mounted out of sight with the speaker volume control as well.
As others indicated, an arcade button/microswitch would work as well.
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
Re:Eye Candy Power
« Reply #6 on: October 12, 2004, 11:22:57 am »
I just used an arcade pushbutton too.
dag2000
  • Last login:May 21, 2020, 12:27:05 pm
  • One piece at a time.
Re:Eye Candy Power
« Reply #7 on: October 12, 2004, 11:23:50 am »
« Last Edit: October 12, 2004, 11:25:31 am by dag2000 »
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
Re:Eye Candy Power
« Reply #8 on: October 12, 2004, 11:30:45 am »
I purchased a momentary toggle switch from mcmaster.com and replaced the stock switch on my cab.
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
Knoxximus
  • Last login:December 19, 2011, 12:22:58 am
  • Young Frozen
    • Beat-TECH Productions
Re:Eye Candy Power
« Reply #10 on: October 13, 2004, 12:50:39 am »
Dumb questions deserve dumb answers.
