Author Topic: Can you identify this component?  (Read 1129 times)
Apollo
    • Eight Bells
« on: October 11, 2004, 01:23:59 am »
Ok so my new cab has what looks like a blown component, it should be fairly easy to replace but can you identify it for me?
It is white and seems to be ceramic, it is approx 20mm tall and 8mm square. On one side it has the symbols
3W 330ohms J
I'm assuming it's a big assed resistor, it has a lot of brown crud on the side so I guess this is the fault with the monitor board.
Any advice?
holdennut
  • Last login:January 16, 2015, 04:53:06 am
  • Aussie lowboy cab finished!
    • Australian Cocktail Pac-Man Project
Re:Can you identify this component?
« Reply #1 on: October 11, 2004, 03:38:20 am »
Yes indeed it is a resistor, a ceramic resister actually, they carry a lot more power than the standard small round ones.
Only problem is, something else probably caused it to blow.
Just get another 330ohm 3 watt resister and give it a go.
Apollo
    • Eight Bells
« Reply #2 on: October 11, 2004, 03:59:07 am »
Yeah I was wondering why it would blow and kinda thought there might be another problem. I'll give it a whirl, cheers.
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
« Reply #3 on: October 11, 2004, 07:19:20 am »
A BIG ground downstream of the resistor?
Hoagie_one
  • Um....whats a cabinet
« Reply #4 on: October 11, 2004, 07:31:37 am »
or it was defenctive
danny_galaga
  • Last login:Yesterday at 07:30:04 pm
    • dans cocktail lounge
« Reply #5 on: October 11, 2004, 09:05:01 am »
look for obvious shorts and other damaged components first. normally its not the best idea to replace components without knowing why it died in the first place. although normally its not recommended because the component is expensive. in this case itll cost you bugger all!! maybe a buck fifty tops and you can get ceramic resistors at any ol electronics shop...
