Author Topic: Soft power-up with I-PAC  (Read 768 times)
currygoat11
  • Last login:May 04, 2018, 11:10:02 pm
  • She's doing it right now!
« on: October 10, 2004, 11:41:02 am »
I have my BIOS setup such that I can powerdown and if I press space-bar, the computer will startup. This is not "Standby" mode but the computer actually completely shuts down the OS (linux).
so then all I gotta do is press the Space bar (specifically as set in the BIOS) and the computer powers up.
question: will the I-PAC behave similarly to a keyboard? In other words, I should be able to just press Player 1 3rd button (space bar) and have the system boot.
I would test my theory I just do not have the I-PAC and buttons wired....
cg
cg
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
Re:Soft power-up with I-PAC
« Reply #1 on: October 10, 2004, 11:44:00 am »
Yep, works like a charm. That's how I have my system set up.
currygoat11
« Reply #2 on: October 11, 2004, 09:58:56 am »
Thanks - that's good.  I think this will eliminate the need to hook up a central power switch on the cabinet. =)
cg
nathan118
  • Last login:November 16, 2008, 09:32:51 pm
  • Blarg
    • The Blarg
« Reply #3 on: October 11, 2004, 08:01:13 pm »
i assume this doesn't work when it's setup USB does it?  :(
DaemonCollector
« Reply #4 on: October 11, 2004, 08:55:02 pm »
it actully depends on your motherboard, some will work, some won't
nathan118
  • Blarg
    • The Blarg
« Reply #5 on: October 12, 2004, 06:08:04 pm »
crossing my fingers. :)
